Hatchback liftgate struts broken
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Kcbeachy, Nov 21, 2008.
  1. Kcbeachy
    Kcbeachy New Member
    Metairie, Louisiana
    The liftgate on our 2005 Prius became increasingly difficult to use. The dealer told us the struts are broken. (1) how? (2) they are going to cost $125-150 each to repair-seems expensive?. Has anyone else experienced this?
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    You can probably replace them yourself for less...they can't be too complicated.
    Why? They're hydrolic...seals can go bad, fluid leak, increasing build-up can cause stiffness.
    Are you sure it's not just the cooler weather (yea, Metairie shouldn't be that cold, but it's worth asking).
    Akramahmad1 likes this.
  3. bjjb99
    bjjb99 Junior Member
    22
    Northern VA
    Are they talking about the pneumatic lifters that raise the liftgate? They slowly lose pressure over time. I recently replaced a pair on the cap of my old pickup truck. If you can obtain the specifications of those lifters, you could probably find a replacement at your local auto parts supply. I don't know about the Prius, but replacing them on the truck was pretty easy, requiring only a flathead screwdriver and some time.
    BJJB
  4. CBarr31
    CBarr31 Active Member
    434
    225
    Charlotte, NC
    As posted by Evan and others the cylinders can lose pressure over time and fail to lift or hold the hatch open. It is not a common problem but has been known to happen.
    One word of caution is sometimes they can be difficult to remove. My sister's Celica had one fail and needed it replaced under warranty and the Toyota Dealership tried "tapping" it off with a hammer, missed and put a dent right square on the crease of the hatch line. Ooooppps, they took ownership and fixed it but even though the bondo man and painter did a very good job if you look you can still tell.
    Chris
  5. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    +1 for what BJJB says. There are many universal lift supports available. It would maybe take some looking to find the correct one. They generally range from $20-$50, depending on the brand name and application.
  6. ThePackage
    ThePackage New Member
    74
    Can you give us a link to their web site or other information about it?
  7. Lithium
    Lithium HyMotioned Member
    17
    U.S
    Watched the video. So if I have a bag of groceries in one hand and I'm opening the hatch with the other hand, then I need a third hand to tighten the Mighty Tighty stut stopper. Also, what happens if you have the hatch open for a while and you get distracted and forget that you tightened your Might Tighty. Does it just break off or cause damage to the strut itself when the hatch is closed.
  8. C. T. Ostler
    C. T. Ostler New Member
    Utah
    Interesting comments. Might Tight has sold thousands in the likes of Discount Auto Parts, K-Mart, and other big box retailers under a different brand name. Never has one been returned, nor has a consumer had an issue with the product. In fact, we have received numerous calls thanking us for the low cost simple solution to their problem. Why don't you give it a shot, you just may like it.
  9. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    Damn, this thread turned into "Lets reinvent the wheel thread" I just called my local dealer. The price for the struts is $122 each. You might find them cheaper online. Why don't you just pick up a set and replace them yourself.. you do not need to add fancy shaft locks when a pair of properly working struts will hold the hatch nicely by themselves!!!
    Just a thought
    KK6PD
  10. patsparks
    10,664
    567
    Adelaide South Australia
    I'm sick of spammers. If you forget about your mighty tighty you bend the hatch in the middle, but that's better than buying new struts.
  11. johnp
    johnp New Member
    35
    Moses Lake, WA
    About $90 each at www.toyotapartsales.com go to 2005 Prius and search "lift cylinder". You can get aftermarket for probably half that but personaly I'd go with Toyota parts on this one. I have ordered parts for my 4Runner these guys a number of times and there have never been any problems.
    A saggy hatch is really annoying! :(
    Good luck, John
  12. dasterndastern
    dasterndastern Junior Member
    Northampton Massachusetts USA
    Any thoughts on where to go for 2009 parts - other than a Toyota dealer?
    It burns me that for previous years they're $121 each from authorized, and $59 for the pair from the ebay seller above (who can't find equivalents released to the aftermarket yet for my year).
    Great source of info, by the way - this forum. Glad I stumbled onto it.
  13. elock
    elock Junior Member
    Houston, TX
    Does anyone know if these lifts are covered under warranty? I have a 2008 Prius that is still under 36k miles. I have to lift my hatch about half way before the lifts kick in. Also when closing the hatch, it doesn't catch properly. About 1/2 the time I have to open and close it a second time. Appreciate any advice.
  14. Patrick Wong
    18,200
    6,490
    Both issues are covered under the 3 year / 36K mile warranty. However note that the hatch does require a reasonable amount of force to close.
  15. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Also I think it seems fairly normal to have to lift the hatch about half way before the gas strut lift fully overcomes the hatch weight. I don’t think it's meant to spring all the way open from a near-closed position.
    Gas strut are there to :
    1. reduce the force needed to lift the hatch (not necessarily to make it pop-up).
    2. To hold the hatch in the fully open position without further assistance. While struts may gradually lose pressure over time I don’t consider them worn out and in need of replacement until they fail to adequately hold the hatch in the fully open position without assistance.
  16. elock
    elock Junior Member
    Houston, TX
    Thanks to everyone for their replies. Update: With 35,951 miles, I decided to take it in to ask. They said the struts were worn out and covered them under warranty!
  17. paivinen
    paivinen New Member
    San Martin, CA
    I just went through replacing mine and thought I'd summarize what I found out. (The flathead screwdriver hint above and a comment about a clip from a different post helped me figure out how to do it. I'm pretty much auto-repair-challenged.)
    Toyota wants you to spend $150 per strut because they not only want to sell you the lifter but the brackets that mount the lifter to the hatch and the body. You can buy just the lifters at any auto parts store. I bought mine for $39 each, $78 for the pair.
    Then, I had to figure out how to replace them. (I'd recommend having someone else hold the hatch while doing this, but I managed to do it by myself with only a couple of nervous moments.) Once I figured out how to do it, it only took a couple of minutes per lifter to replace them.
    The lifters attach to the mounting brackets as a ball and socket connection. The mounts have the ball and the lifters have the socket. The socket is held onto the ball with a clip that is exposed on the back of the socket.
    o Start by fully opening the hatch.
    o There is an indentation that allows you to slide a small screwdriver between the clip and the back of the socket on the lifter. A gentle tap with a hammer on the screwdriver will pull the clip out. Do this on both ends of the lifter before attempting to separate the lifter from the mounts.
    o Once done on both ends, the lifter can easily be separated from the mounts. (You or someone else should be holding the hatch open before removing the lifter and you should have the new lifter within easy reach. I don't know which end should be unclipped first for maximum safety. I unclipped the end attached to the hatch first.)
    o Then, while continuing to hold the hatch open, the new lifter can be pushed onto the ball on each mount. Hand pressure should be enough to cause the clips on the new lifter to lock onto the balls on the mounting brackets. I attached mine to the body mount first and then to the hatch mount. Doing it that way, I had to rotate the lifter slightly and push in a second time to get the clips fully engaged on the hatch mounts.
    MikeP
    NiallS, dogfriend, horizons and 3 others like this.
  18. Mylar
    Mylar Member
    163
    36
    Cincinnati, OH
    2019 Prius
  19. ibcs
    ibcs New Member
    351
    31
    Englewood , Ohio
