Have I Blown My Factory Warranty?
Discussion in 'Gen 2 Prius Technical Discussion' started by BexarWolf, Jun 26, 2007.
  1. BexarWolf
    BexarWolf New Member
    35
    We got the '07 about two month or so ago. We've already topped almost 9,000 miles. I just realized, we are WAY over on our first serivce (oil change) so I have it scheduled for this coming Thursday. I know, I know. "Read your manual" or "Your manual is your friend" but I'm not the one primarily driving it.
    So, have we shot the warranty or did we just set ourselves up for it being voided if something happens in the distant future?
    Thanks in advance.
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    Nah, you're fine, just get it in as soon as possible. You're extremely unlikely to suffer an ICE failure within the warranty period anyway even if you never changed the oil.
  3. MickeyA
    MickeyA New Member
    81
    No real answer unless the car blows & u have to ask for warranty service.
    Long term damage could have occurred.
    I'd say do an AutoRx cleansing & oil change.
    Cross your fingers.
  4. Swanny1172
    Swanny1172 New Member
    666
    <div class='quotetop'>QUOTE(MickeyA @ Jun 26 2007, 03:09 AM) [snapback]468152[/snapback]</div>
    Don't be such an alarmist! Going 9,000 miles between oil changes is not that big of a deal because today's oils are better engineered than they used to be. In fact, many car makers have adopted extended service intervals. I only change the oil once every 10,000 miles in my Mercedes...
    The correct answer here is to just get the oil changed. The Prius ICE doesn't have any known sludging problems, so flushing with AutoRx is overkill at this point. If you are really concerned about the condition of your oil and any damage that might have been done, take a sample of the oil when you change it and have it sent for analysis. I think you will be pleasently surprised by the results.
  5. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Oi
    I suppose every Prius in the EU - with their normal 12 month or 10,000 mile oil change interval - must have this "Auto RX" thing performed??
    I have posted numerous times on the subject of extended oil changes, and the quality of various oils. Perhaps if the crap dealer oil is used, that might be cause for concern. I have had a lot of used oil analysis done on my Prius, and can confirm that Mobil 1 0W-20 run 16,000 km is nothing, no sweat at all.
  6. BexarWolf
    35
    <div class='quotetop'>QUOTE(jayman @ Jun 26 2007, 07:38 AM) [snapback]468190[/snapback]</div>
    That's the part that concerned me and peeved me the most when I found out it was over the service period. The oil in it right now is the oil it left the factory with. I'm not as concerned about engine damage as I am the warranty issue. We'll have the service done right at the 9k mark and after that, I'm taking over the "maintenance watch" on it. I generally go 4-5k between oil changes in most of my vehicles (with the exception of the motorcycle). Once we're back on track, it'll be kept current.
    Thanks for all the insight.
  7. priusFTW
    priusFTW Gen III JBL non Nav
    434
    White Mtns New Hampshire
    <div class='quotetop'>QUOTE(BexarWolf @ Jun 26 2007, 09:07 AM) [snapback]468206[/snapback]</div>
    Did your "maint" light come on to warn you to have your car serviced at your 5k interval? I'm just curious and if it did... what did you do? ignore it? I don't believe 9k is any major concern tbh. Don't worry about it.
  8. Winston
    Winston Member
    614
    SF Bay Area, California
    A $20 oil analysis would be worth the insurance. Plus, I would really like to see what the original oil would look like after 9k miles.
    Did you ever check the oil level? Is it still at the full mark?
  9. tochatihu
    tochatihu Senior Member
    9,456
    3,654
    Kunming Yunnan China
    2001 Prius
    I second Winston's suggestion. In the very unlikely event of engine problems during the warranty period, a clean bill of health from analysis of the first oil change could simplify discussions with Toyota.
    Separately, just to be clear, no other aspect of your Prius warranty could be affected by not (precisely) following Toyota's oil change recommendations.
  10. Swanny1172
    666
    Toyota can't void your entire warranty for failing to change your oil at the specified interval. At best, they could deny warranty coverage for any mechanical failure which could be attributed to the oil. This, however, is very unlikely, as they would have to prove that the oil was no longer doing its job and was what caused the failure. Think about it this way, when was the last time you heard of an engine failure due to oil?
  11. JSH
    JSH Senior Member
    2,605
    140
    PDX
    I have no concern about the car running 9K miles on an oil change. My only concern is that is is the first oil change which is the most important oil change that you will ever do. This is because as the engine "breaks in" the mating surfaces wear together and small pieces of metal are worn away and suspended in the oil. Changing the oil the first time gets rid of the small metal particles.
    That said, modern engines have much tighter tolerances and don't wear together nearly as much so this is not as big a deal is it might have been say 10 or 20 years ago. I agree that an oil analysis would be good insurance to deal with any future warranty problems you might have with Toyota.
  12. SaintStephen
    SaintStephen New Member
    32
    I believe that the last time I heard of oil ruining an enginer was when Quaker State was fooling with their chemical composition. They managed to ruin quite a few motors, but it hasn't happened again since that I'm aware. Modern oil is excellent.
    SS
  13. BexarWolf
    35
    <div class='quotetop'>QUOTE(priusFTW @ Jun 26 2007, 08:26 AM) [snapback]468212[/snapback]</div>
    Yup, the light came on but I t'weren't the driver at the time. I didn't see it until it was already close to 8k miles. It's not my primary mode of transportation so I'm behind the wheel very little.
    <div class='quotetop'>QUOTE(Winston @ Jun 26 2007, 09:42 AM) [snapback]468243[/snapback]</div>
    The level is still full. It's getting taken care of in the a.m. so all will be right in the world of oil changes once again. :D
  14. apriusfan
    apriusfan New Member
    6,050
    205
    S.F. Bay Area
    <div class='quotetop'>QUOTE(Swanny1172 @ Jun 26 2007, 05:19 AM) [snapback]468180[/snapback]</div>
    You might want to do the used oil analysis for peace of mind purposes as well as a defensive measure in the event of a possible denial of warranty issue in the future. You are probably fine, but a used oil analysis will confirm it. If the analysis comes back with any bad news, it will give you guidance on what follow-on steps to take (such as AutoRx flush).
  15. desertbriez
    desertbriez New Member
    376
    and why do we have to change our oil at 5000 if the SAME car doesn't have to change it til 10000 in europe?
    BALDERDASH!
    (and don't worry about your engine..... i've gone way longer than i'm supposed to in many of my vehicles with no damage! too many alarmists/chicken littles in this thread!)
  16. jayman
    13,439
    641
    Winnipeg Manitoba
    <div class='quotetop'>QUOTE(jhinton @ Jun 26 2007, 10:34 AM) [snapback]468279[/snapback]</div>
    I'm unaware of any EU car - with their much longer oil change intervals - requiring an early initial change. Some dealers may still insist on it, but the vast majority do not.
    Even the big trucks no longer require an early initial service. Those from MAN and Scania usually have the first oil change at 80,000 km.
    <div class='quotetop'>QUOTE(desertbriez @ Jun 28 2007, 10:00 AM) [snapback]469380[/snapback]</div>
    Ah, a like-minded individual.
    I'm sure you've had a lot of fun searching this forum for my posts regarding oil quality and oil change intervals. The EU members must just roll their eyes at all the folks who dread going to even 5,000 miles.
    The folks who insist on Mobil 1 and change at 3,000 miles ... oi
  17. BexarWolf
    35
    45min and $31.29 at the dealership later and all is well. I'll be checking the mileage on a regular basis now (if I can pry her away from her car).
    Thanks to all for the input.
  18. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    BexarWolf-Quick Question. Where did they record the oil change in you car?
  19. BexarWolf
    35
    <div class='quotetop'>QUOTE(FL_Prius_Driver @ Jul 2 2007, 08:06 PM) [snapback]471950[/snapback]</div>
    I've got absolutely no idea, my friend. I'm going to assume (we know how that always comes out great) that it's in the stealership's computer with mileage, date and service performed. I didn't even look at the windshield to see if there's one of those "next oil change" stickers on it. I'll have to check into that though.
    BW
  20. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    Thanks greatly for answering. The reason I ask is that my '99 Camry is has a mixture of dealer oil changes and my own. It usually goes like this:
    1) I change to oil with a 5W-30 Synthetic at let's say 50,000.
    2) One of the other drivers takes the car to the dealer (while I'm out of town) to get a sticking ECR valve fixed at 51,000.
    3) As part of the 3,229 point free inspection program, the driver gets a call saying the oil needs changing since blah, blah, blah. The poor driver may not be able to contact me (think military), or see my records (which are in the car), and says OK to the dealer, which is the right answer given the circumstances.
    4) I come back to an oil change replacing clear 5W-30 with something that looks darker than black paint.....and no clue to what it is....but not synthetic!
    5) All of which makes it a big advantage to the dealer since he keeps you (apparently) in the dark so that your or the next driver is trapped in the same situation.
    6) I am now MUCH better trained to handle this situation and others. Your answer adds another datapoint to help seperate the good dealers from the bad.
    P.S. Record all dealer actions in your owners manual or something, initial and date. This makes it a legal document that can only aid you. Great lesson learned in my battles.
