Have you had to add oil between 10,000 oil change?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Dusty Chips, Mar 24, 2011.
  1. Dusty Chips
    Dusty Chips New Member
    85
    Laughlin NV
    I've owned my 2011 for less than two months. How is the oil consumption?
  2. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
    I've owned my for almost a year and I've not had to add oil. I've not heard of anyone having to add oil. Have you had to add oil? If so, is it because of leaks, underfilling, or consumption?
  3. DetPrius
    DetPrius Active Member
    545
    92
    Southeast Michigan
    I just had my 25,000 mile change done, and I did not have to add any during that 10,000 mile period. If it dropped any on the dipstick, it was negligible, as in less than 1/8 of an inch..
  4. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,342
    Wilmington, NC
    +1 Same as above, just completed the 25k mile change and have not had to add any oil to date. Hope it stays that way.
  5. Mark57
    2,945
    2,738
    OK
    I just did my 30,000 oil change. I've never had to add oil and I check it weekly. My last change was the first 10,000 interval. It was 5,000 before that.
  6. CTpriusV
    CTpriusV Junior Member
    70
    Bristol Ct
    Haven't had to add oil in my 2010 Prius or to my 2011 Rav4, hope it stays that way!
  7. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    20,000 miles, not a drop.
  8. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    ditto
  9. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    43k miles and never ever had to add oil. Trouble is I'm getting slack at checking the oil now as it never differs.
  10. tumbleweed
    tumbleweed Senior Member
    4,067
    690
    Eastern Oregon
    I too have never added any oil between changes.
    When I change my oil I fill it to within 1/8 inch of the full mark, when I change it 10K miles later it may be another 1/8 inch below that.
  11. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    I too haven't added any oil between 10k. mi. changes. I've got 45k. mi. and mostly highway driving.
  12. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    421
    Whereabouts Unknown
    We drive two Gen III Prii, one with 12K and the other with 17K miles. Both have a little over a year of faithful service. Other than regular oil change (first Prius at 7K and second Prius at 5K, 11K & 17K miles), we have never needed to add a drop of oil.
  13. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    I'm at 20K miles, check my oil level monthly (when I check tire pressure), and have never had to add any oil (I do 5K miles oil/filter service, not 10K).
  14. Dusty Chips
    85
    Laughlin NV
    Thanks for the feedback guys! :)
  15. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    ^ so now the question is have you?
  16. Dusty Chips
    85
    Laughlin NV
    Well, it's got about a thousand miles... if I had to add oil already, I'm taking it back.....
  17. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    I change oil, Mobil One 0w20, every 10,000
    miles and use only 4 quarts, so I will not overfill.
    I have not had to add any extra oil. In fact nearly
    4 quarts drains out when I change it.
    I now have over 46,000 miles.
    Al
