Headlight housing fogging over
Discussion in 'Gen 2 Prius Technical Discussion' started by Skarka, Jul 2, 2009.
  1. Skarka
    Skarka Junior Member
    24
    San Francisco Bay Area
    I have a 04 Prius and the HID headlight housings on both sides are fogging over like cataracts. Is this bad design with a costly replacement?
  2. Patrick Wong
    18,200
    6,490
    The clear plastic housing ages with exposure to sunlight. Try using plastic polish on the exterior to see if that helps.
  3. snijd
    snijd DIY or die
    243
    52
    PNW
    I've had good luck with Meguiar's plastic cleaner and plastic polish. Use the white bottle first, followed by the blue bottle. For extreme cases, there are kits using fine sandpaper, which is followed up by polishing compounds. You can search youtube for some impressive demonstrations on pretty degraded headlight lenses.
    After they've degraded once, it seems the plastic is more susceptible to future clouding, but that doesn't mean you can't clear it up again with a little elbow grease!
  4. Sandy
    Sandy Hippi Chick
    860
    53
    Ocala,Fl
    go to your local carlot and talk to the detailer mine did it for 10 bucks and looks good as new:)
  5. patsparks
    10,664
    567
    Adelaide South Australia
    Always mask around the lights to protect the paint before attempting any headlight polishing operation.
  6. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    All depends on what you mean by fogging over. If there is a crack or hole in the plastic lens, moisture gets in. Small cracks or holes may be repaired, otherwise replacing the housing is in order
    For fine scratches that resemble hazing, that can be buffed out with the appropriate plastic cleaner. All plastic headlight lenses will become hazed/scratched/yellowed with age
    I've had very good luck with this product
    Sporty's Windshield Care Kit - Sporty's Pilot Shop
    You can also get automotive-style products, like this one from Eastwood
    Clear Plastic and Headlight Restoration Kit
    Hope this helps
  7. The Banks
    The Banks Junior Member
    Here you go.
    http://www.spadepot.com/shop/Novus-Spa-Scratch-Removal-Kit-P757C57.aspx
    I've used it on the headlights on my 2000 Camaro and cleared them right up. The plastic polishing compounds made by Meguires (Plastx) and Mother's (Plastic Polish) are excellent polishes as well, but to get off the road grime on the plastic you need to use a progression of abrasive compounds in order to get off the grime and remove the abrasions made by the previous compound. That is all included in the Novus 3 step scratch removal kit.
