Headrests
Discussion in 'Prime Main Forum (2017-2022)' started by MNdriver, May 15, 2017.
  1. MNdriver
    MNdriver Senior Member
    549
    577
    having had my car for less than 48 hours, one gripe I have is that the headrest is uncomfortable. It feels like it's forcing my head too far forward. Is this true for anyone else? In another Prius forum (not Prime) I read that some people turn them around so they have the less curved side behind their heads.
    I've discovered that you can flip the headrests down in the rear seats for better visibility. I have people lined up who want rides, so I'll probably have back seat customers for a while. After that I may remove them altogether.
    jaqueh and priuscatprimeguy like this.
  2. alexcue
    alexcue Active Member
    346
    311
    So Cal
    guess it must be how I have my seat setup but my head doesn't even touch the headrest. Heck in most any cars I've ever had the head rest doesn't touch my head unless I purposely lean back to rest it.
    HPrimeAdvanced likes this.
  3. huskers
    huskers Senior Member
    2,544
    2,487
    Nebraska
    My head does not touch the headrest either. Maybe tilt the seat back a notch.
  4. MNdriver
    549
    577
    Wow, I must be a freak! Weird. I'll play with the tilt, thanks.
  5. Lee Jay
    Lee Jay Senior Member
    5,850
    4,029
    Westminster, Colorado
    Do you know what they're for?
    In a heavy rear-end collision, your body will be accelerated forward by the sudden acceleration. This will leave your head behind which at best will cause a minor neck injury and at worst will decapitate you. The head rest is there to prevent that.
  6. alexcue
    346
    311
    So Cal
    Lee i think technically you car is pushed forward but your body will be slung backwards. My parents were rear ended at a stop sign by a car that didn't stop (30+MPH). My dad's seat literally broke the back of it when he was thrown backwards by the force. My moms held at one side by did break on the other support. I'm sure if the headrest wasn't there they would have broken their necks.
  7. Lee Jay
    5,850
    4,029
    No, your body is attached to the car (through the seat) and is thus pushed forward by the car. Anything that isn't connected to the car is not moved forward and thus moves backwards relative to the car (but stays stationary relative to the ground) This is why the head rest is there - to push your head forward along with the car so it stays connected to your body.
  8. alexcue
    346
    311
    So Cal
    I guess we are saying the same thing, though you phrased it better ;). Your body isn't going to move as fast forward as the car will.
    at 1:22 you could see the backwards push. I can see why my dads seat broke completely.
    Regardless, the headrest is to keep our heads on our bodies during an accident not necessarily to relax against it while driving.
    sonomac, Son of Gloin and Lee Jay like this.
  9. huskers
    2,544
    2,487
    Nebraska
    Damn, back under the bed.
  10. Lee Jay
    5,850
    4,029
    Your body goes forward relative to the ground, and backwards relative to the car. It's a "relativity" thing - frame of reference matters.
    And, yes, your head rest is primarily a safety device.
    HPrimeAdvanced and alexcue like this.
  11. Janice N
    Janice N Member
    51
    58
    Redwood City, CA
    The headrests from prior prii (2015 for sure) will fit the prime and have less forward angle. I call the seats softex covered torture devices. I'm away on business but plan to eBay a headrest and swap when I get back. Most seats of recent manufacture were not designed for a 5'2" woman who prefers to sit up straight.
    I tested a head rest from a 2015 when I took a test drive.
    Prius from Dad likes this.
  12. MNdriver
    549
    577
    Thanks, Janice. If changing the tilt of the seat doesn't help I may go that route also.
    To others - yes, don't worry, I do know what headrests are for. I won't remove them if I actually carry passengers in the back. But actually, with all of 48 hours experience, it looks like tilting them forward when not in use is going to work just fine. I also sat in the back and found the head rest a lot more comfortable than in the front. I need to do some more experimentation with positioning the front seat, I guess.
  13. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,304
    3,519
    Anaheim, CA
    Not exactly on the same topic, but I adjusted my (obfuscating) rear seat headrests to tilt forward to improve my rearward view.
    Fantastic!! I can now better see to the sides when using my interior rearview mirror. . I never have passengers, so this is perfect for me!
  14. MNdriver
    549
    577
    Yes, I did that as well. That's a nice feature.
    Tilting the seat back more helps with the headrest. I still don't like it touching my head but at least now it's not uncomfortable.
  15. Janice N
    Janice N Member
    51
    58
    Redwood City, CA
    I got a used head restraint from ebay (2011-2015 prius) and took some pictures. The new-to-me head restraint is grey cloth. You'll notice that the padding isn't as far forward from the stems. I also show it installed both backwards (straight line with seat back) and forwards (tilts forward but less than original). I'm trying it facing forwards for now.
  16. MNdriver
    549
    577
    Thanks Janice. They look a lot more comfortable than the headrests provided with the car, which feel as though they were designed for tall men. I'm surviving by tilting my seat back, but I prefer to sit upright so may swap them out at some point.
    Janice N likes this.
  17. Janice N
    Janice N Member
    51
    58
    Redwood City, CA
    I used an old donut cushion, a few inches thick, on the driver's seat with the '15 head rest. It was almost ... comfortable! When sitting up, not just my head and sacrum touched the seat but my shoulder blades brushed the back too! I was surprised that the pedals were still comfortable and the steering wheel was still 10" away and only had to be raised a little. I still can't see the front of the car, but I think I'm getting closer to a usable setup.
    A co-worker once pointed out that being more than 2 sigma away from the mean of the distribution can be troublesome.
    One size fits some.
  18. Yankee3
    Yankee3 Junior Member
    17
    Bartlett TN
    I tried moving the back seat head restraint forward last night based on the instructions but it doesn't seem to budge. Is there any trick to it. I assume they are made to fold forward in order to clear the front seats when you need extra luggage space and the front seat are back as far as they go.
  19. Lee Jay
    5,850
    4,029
    I like to just remove them and put them under the front seats.
    They have to be all the way out to tilt then down.
    #19 Lee Jay, Oct 24, 2017
  20. FuelMiser
    FuelMiser Senior Member
    1,330
    917
    Monument, CO
    FYI, the OEM Gen 4 headrests will install "backwards" giving more room to lay your head back. Janice N shows a picture above, albeit with an aftermarket headrest. If you have moonstone, the color will not match, but you'll be comfortable.
    pilotgrrl likes this.
