Heater blasts hot air on "HI", but the heat stops with one click to a lower temperature. Blower work
Discussion in 'Gen 3 Prius Main Forum' started by XFi fan, Mar 2, 2023.
  1. XFi fan
    XFi fan Junior Member
    Grand Rapids, MI
    2001 Prius
    I
    2013 Prius V heater blasts hot air on "HI", but the heat changes to cool air (not cold) with only one click to a lower temperature. The blower work fine with any heat setting. In other words, the blower always works. But I get no heat when the heat temperature is set from 70 degrees to the highest temperature number which I think is 85. But when I click the temperature setting one more click to the right, which sets it at "HI", I get all kinds of hot air. Any ideas? - I've done lots of Google searches and haven't found one instance of this situation. Have any of you experienced this and know what the problem is?
    Thank you for your time.
  2. XFi fan
    Grand Rapids, MI
    2001 Prius
    I
    FWIW, it was probably about 30 degrees outside when this was occurring and I did more than an hour of freeway driving.
  3. XFi fan
    Grand Rapids, MI
    2001 Prius
    I
    3/3/23 update:
    I was really hoping there was someone out there that had experienced this as I don't think I'm the first one. At any rate, I think this relates to all GEN 3 Prius models. And as I mentioned, the fan blower blows at all speeds. But I only get heat when the temperature setting is on "HI". Turning it down even just one click, to 85, will cause the air coming out of the blower to no longer be hot.
  4. Tombukt2
    Tombukt2 Senior Member
    13,036
    2,336
    Durham NC
    And you've had no temperature light pop up on your dash? And after this hour of driving if you were to lift the hood and touch related rubber hoses the ones that are an inch or better and they are all reasonably warm and similar temp? If yes I would say maybe it's the electronic dash portion that allows you to do this temperature setting by temperature they used to go bad and Cadillacs and other vehicles like that all the time. Maybe it even has its own heat ECU..
  5. XFi fan
    Grand Rapids, MI
    2001 Prius
    I
    Thank you for your response. When the temperature knob is set to "HI", it blasts heat. But when I turn the knob to the left one or more clicks to an actual temperature degree setting (anything from 85 on down to 70) the heat goes away. But the blower keeps blowing. So something happens when the knob is turned down from is highest setting, "HI", to a lower heat setting. So I need to find out what causes this to happen.
  6. ChapmanF
    18,249
    That's nearly pathognomonic of a problem in the wiring to the cabin temperature sensor.
    The temperature settings you can select are LO (blast me cooling no matter what), HI (blast me heat no matter what), and all the numbers in between, where it looks at the cabin temperature sensor to see if cooling or heating is needed.
    So if the temperature sensor is giving a bogus high reading, then HI will still blast you heat no matter what, but no actual number setting will give you any heat.
    The other way that can go is if the cabin sensor gives a bogus low reading; then the LO setting will still blast you cooling no matter what, but no actual number setting will give you any cooling.
    Toyota tends to use negative-temperature-coefficient thermistors for these sensors: the resistance goes down as the temperature goes up:
    So a bogus high reading from the sensor would mean the resistance is too low, as would happen if the wires going to the sensor got damaged and shorted.
    (If the wires got damaged and broken, or someone did work in the dash and left the sensor unplugged, the resistance would be too high, it would look like a low temperature, and you'd have the "only cools on LO" situation).
    If you had a scan tool you could connect and look at the a/c system data list, you would probably see a fixed, bogus high reading for the cabin temperature, and that would confirm this is the problem. But this is that kind of problem where the symptoms you've already mentioned pretty much nail it.
    You might have an a/c system trouble code B1411, which is supposed to tell you about an open circuit or a short going to that sensor. If you hold down the AUTO and FRESH/RECIRC buttons while powering the car on, you might see code 11 in the a/c display. Or you might have an issue where the wiring isn't completely shorted, so it gives a reading that is bogus high but not as high as the 135℉ a true dead short would look like, and doesn't quite trigger the code.
    In any case, you can find troubleshooting workup steps you can follow if you look up the B1411 troubleshooting section in the repair manual.
    Toyota Service Information and Where To Find It | PriusChat
    #6 ChapmanF, Mar 3, 2023
    Johnny Cakes, Mr. F and Brian1954 like this.
  7. Tombukt2
    13,036
    2,336
    Durham NC
    Also check where that sensor is the little vents right below the key slot or wherever it is in your car Make sure that's not completely plugged with dust bunnies or something a piece of tape over it I don't know
  8. XFi fan
    Grand Rapids, MI
    2001 Prius
    I
    ChatmanF, that was an awesome, detailed response.
    I ran the test you suggested and got a code "00" in the display.
    So then I thought, I have two 2013 Priuses. This "V" and a Prius 4. So I removed the glove box on both Priuses to compare the two, and noticed that the black gear that moves the blend door (?) functions differently as I move the temperature settings from “HI”, to 85 and on down to lower settings in the two Priuses. So I was thinking, based on the info you provided, the likely issues might be either the cabin temperature sensor (the thermistor) is faulty, or the blend door actuator is defective, or there is a problem with the wiring between these two. So I thought I would first swap the thermistors between the two and if the same car continued to have the same issue I would then swap the blend door actuator and see if that made a difference. But I soon realized these are not easy things to do(!), especially as it is cold outside. (It's Michigan). So I realized it would be best if I threw in the towel and brought it to the dealer..., which is what I was hoping to avoid. But it's a bit beyond my skill level.
    Thank you, though, for your detailed response. It really helped my understand what the likely problems were and I am sure it will help others.
    Best regards.
  9. ChapmanF
    18,249
    The actuator would be a more likely suspect if you either had heat all the time whether you want it or not, or no heat all the time whether you want it or not.
    If the actuator is able to zip right to full heat when you request HI (heat no matter what), but then zips right back to no heat as soon as you ask for any controlled temperature, then that tends to confirm the actuator works, and the problem is with what the system thinks the cabin temperature is.
  10. XFi fan
    Grand Rapids, MI
    2001 Prius
    I
    ChapmanF,
    Based on what you just wrote then it appears the actuator works, and, as you said, the problem is with what the system thinks the cabin temperature is.
    Tomorrow it will be in the shop. I'll post what they find but am guessing, based on what you have said, there is something wrong with what the system thinks the cabin temp is. I'm hoping it is the thermistor because that will be a simple thing (for them!) to replace.
  11. XFi fan
    Grand Rapids, MI
    2001 Prius
    I
    Thanks, Tombukt2. I found the vents. They are in a 2 inch by 3 inch section of plastic molding. They do not appear to be plugged. - I wish there were a simple way (for me...) to pop out that little piece of molding. I'm sure it would be a simple thing to then replace the sensor.
    I'll update both you and ChapmanF on what the dealership finds. (And what it cost me to have it fixed...)
  12. ChapmanF
    18,249
    I'll bet it turns out even simpler than that. Thermistors are too simple to go bad much. My money's on a bit of damage to a wire to the thermistor.
  13. XFi fan
    Grand Rapids, MI
    2001 Prius
    I
    Well, a service advisor called and said they followed the Toyota diagnostic steps and along the way determined the "Illumination rate" to be 2,162 which is normal. Therefore the only remaining possibility is that the Main Body ECU needs to be replaced for $1.050 plus tax. So I asked, what happens if they replace that and I still have the problem? She said, "well, you'll have a new ECU". - I kid you not. - So then I asked, more specifically, if they replace the ECU and the problem still exists do I have to pay the $1.050 plus tax. She said let's cross that bridge it we come to it. So I said, I want to cross that bridge now, so we're all on the same page if that ends up being the situation, and suggested she contact her manager and ask that question. So I am waiting for a reply.
  14. ChapmanF
    18,249
    "followed the Toyota diagnostic steps" ?!? Yeah, for some other problem!
    The only "illumination rate" PID that I know about is the one in the Body ECU that tells you the reading from the solar sensor on the dash that is used for the auto headlight feature.
    Did you say, by any chance, anything to them about a problem with the auto headlights? Does your Gen 3 even have the auto headlights?
    The same sensor on the dash that supplies the "illumination rate" to the Body ECU also supplies a "Solar sensor" PID that can be read from the A/C ECU. (It comes out on separate wires; that sensor is really two distinct sensors. I don't know the details, but the one for the auto headlights might be tuned more for visible light and the one for A/C more for radiant heat.) The A/C ECU "solar sensor" PID will be shown as a value 0 through 255.
    Neither of those has anything at all to do with the room temperature sensor. For that, they should be looking at the "room temperature sensor" PID from the A/C ECU.
    It's hard to even guess what problem they thought they were diagnosing.
  15. XFi fan
    Grand Rapids, MI
    2001 Prius
    I
    Ok, now the dealerships service advisor is telling me "the blender actuator temperature plummets" when the temperature dial is turned from "HI" to 85 or lower, instead of decreasing at a steady rate. So they want to replace the blender actuator. And they say if that doesn't solve the problem they want to replace the main body ECU.
    They seem to imply that they somehow ruled out the possibility that the room cabin temperature sensor is bad, but am not sure how they tested that.
    So "if" the room cabin temperature sensor is working as it should, where does it send its reading? Does the reading go directly to the blender actuator which then reads the temperature signal and reacts accordingly or does the sensor send its signal to some sort of ECU that then sends the appropriate signal to the blender actuator?
    Also, they want over $800 to replace the blender actuator.
  16. ChapmanF
    18,249
    The ECU that controls the HVAC has an odd name: it's called the "A/C amplifier" for historical reasons. In a modern car it's just an ECU like any other. It lives below the HVAC unit, near the firewall, just above the center hump in the floor.
    So the room temperature sensor is wired to that ECU. That ECU reads the temperature (and will happily tell you what temperature it reads, if you plug in a scan tool), and that ECU decides what to tell the blend (also known as air mix) actuator to do.
    There is no "blender actuator temperature". There are two PIDs called "Air Mix Servo Targ Pulse" and "Air Mix Servo Actual Pulse" and they give the position of the door, counted in pulses. The target pulse is where the ECU wants the door to go, and the actual pulse is where the door currently is.
    The purpose of the door is to direct air flowing through the box, so that it either all goes through the heater core (and gets heated), or it all goes around the heater core (and doesn't get heated), or goes partly through the core and partly around it (and gets partly heated).
    The door positions range from pulse 6 (all air going around the heater core, adding no heat) to pulse 93 (all air going through the heater core, to pick up maximum heat).
    If the ECU thinks you want a temperature that's below the current room temperature, it's perfectly normal for the ECU to send that door all the way to position 6. No point adding any heat at all, if you want the cabin cooler.
    Likewise, if the ECU thinks you want a temperature that's above the current room temperature, it's perfectly normal for the ECU to send the door straight to position 93. It will give you all the heat that it can, until the room temperature starts getting close to what you've set.
    Only when the room temperature is getting pretty close to your setpoint will you start to see the ECU sending the blend door to positions in between 6 and 93, as it tries to fine tune just the amount of heating needed to stay at your setpoint. You can think of the blend door position as a very S-shaped curve: whenever the actual room temperature is more than slightly above or below your setpoint, the door will be at one extreme or the other, and it only modulates to middle positions when the room temperature is very close to your setpoint.
    So, as already kind of covered in #6 and #9, all the behavior they're seeing is completely consistent with the room temperature reading appearing to be higher than 85 ℉. When you select HI the ECU says "ok, the human wants max heat no matter what, I'm sending the blend door to position 93." As soon as you select one notch down to 85 ℉, the ECU says "whoops, the cabin is hotter than the human wants, I'm sending the blend door to position 6."
    It is all behaving exactly as it would be supposed to behave, if the cabin temperature really were above 85 ℉.
    If the techs at this dealer were surprised by the blend door behaving exactly the way it would normally behave in that situation, it's possible they just aren't the right people to solve this problem.
    Edit: the specific pulse counts 6 and 93 I'm using here are from the Gen 3 liftback manual. Details like that could be a little different in a v, without changing the basic way the system works.
    #16 ChapmanF, Mar 7, 2023
    Mr. F likes this.
  17. XFi fan
    Grand Rapids, MI
    2001 Prius
    I
    Update:
    I gave up on the service garage at the dealership and said I would pick up the car as is. When I did, I discovered it no longer produces heat when the temp is set to "HI", meaning now I have no heat. So I called the service advisor the next morning and they had no answer. But before I called I had opened the hood and found the oil cap was not on. It was laying on the "tray", under the hood by the passenger windshield wiper. Oil had sprayed about the engine compartment. The service advisor accused me of doing that. Rather beyond the pale. So I contacted the general manager who said they will have a more experienced tech look into the heat issue. (I resent #16 and #6 above to the gm, asking that it be printed out and given to the tech who will work on it. I assume it will only take him a minute or two to read.) So we shall see what the coming week brings. I'll add an addendum to this in a moment.
  18. XFi fan
    Grand Rapids, MI
    2001 Prius
    I
    One other really strange thing and that is my headlights no longer work when I have the stick set to Auto. I always have it set there, so my headlights stay on for a while after I pull into my garage. But when I picked up the car this week that setting was no longer working. So as I go through the paperwork I see they reported a b14a2 code (driver's side solar sensor short circuit) which is why they were talking early on about an "illumination rate" (#13 above) being ok so therefore the main body ECU needed to be replaced. (And they assumed replacing it would fix the heat issue.) Odd timing for this to occur just after I brought it in for diagnostics. - I wonder if the ECU can be reset, versus having to be replaced. And in saying that, I am wondering if this could also be a wiring issue. (I think there were mice in the car after having looked at the cabin air cleaner and seeing it appear having been chewed on, and this after I replaced that filter a couple of months ago.)
  19. ChapmanF
    18,249
    Ah, so you do have the auto headlights. Yes, that would explain why they'd have been talking about illumination rate. That reading comes from the little dome sensor in the dash under the windshield. The same little dome also has a sensor wired to the "A/C amplifier".
    If there were rodent teeth involved, lots of things could have happened. Another thing that could have happened would have been techs checking out that sensor and leaving something unplugged.
    I'm still not sure why they got interested in the solar sensor or the illumination rate in the first place, when you showed up with a question about the room temperature sensor.
  20. XFi fan
    Grand Rapids, MI
    2001 Prius
    I
    Update: The new service tech inspected it and came to the conclusion there was damage done to the wiring, and to at least part of the case that contains the fan. - I had seen the damage to the fan case, and thought it strange, but it never dawned on me an animal could/would chew on that hard plastic. So now this becomes an insurance claim which will help. And, at this point, I am assuming the main body ECU and blend door actuator will prove to have been just fine all along. So both issues are likely due to damage to the wiring, which is pretty much where you were pointing to all along. - I'll hear more once they have approval from the insurance company to remove the dash so they can determine the extent of the damage, and will update you accordingly. Thanks, again, for all your help and advice!
