Hello! Questions about the 19-inch wheels and tires of the XLE trim
Discussion in 'Gen 5 Prius Accessories and Modifications' started by YELLOW PRIUS KOREA, Mar 28, 2024.
  1. YELLOW PRIUS KOREA
    YELLOW PRIUS KOREA New Member
    KOREA
    2024 Prius
    I live in Korea.
    I like the Prius design
    I signed an XLE trim yellow.
    The problem is the wheels and tires.
    The tire size I don't like!
    It's not easy to get anywhere and it's expensive..
    So I want to go to 17 inches or 18 inches
    19X6.5J 114.3 홀 +40 HUB BORE : 60MM
    Is our size right?
    But I want a high ground height.
    There are many speed bumps in Korea.
    There are so many of these weirdos! I don't know why they install it!
    Therefore, I would like to raise or maintain the ground height.
    Tesla Model 318-inch wheels are easy to get and inexpensive
    It looks fine. What should I do?
    I'm looking for 17 inches and 18 inches.
    For example... I want the same size as 215 55 17.
    Should I wear the right hub ring?
    According to the original size...
  2. RandyPete
    RandyPete Active Member
    368
    150
    Santa Margarita, CA, USA
    2024 Prius Prime
    XSE
  3. YELLOW PRIUS KOREA
    KOREA
    2024 Prius
    Pure wheel on 2024 Prius Prime? 17 inches. Wheel on LE trim I think.
  4. Blackat
    Blackat Active Member
    387
    244
    Colorado
    2023 Prius
    Limited AWD-e
    I'm ditching the 19's and getting 17's with a 225/55/17 tire. It will be the same height as OEM but more tire for potential road hazards.
  5. Approximate Pseudonym
    106
    55
    Colorado
    2024 Prius Prime
    XSE Premium
    I don’t think ride height has been addressed in those other threads yet.
    You might have trouble finding a wheel size that increases the ground clearance but also fits within the wheel wells. There is not a lot of clearance vertically for taller wheels from what I can tell. It seems to be possible to fit wheels that decrease ground clearance on the 2023-2024 Prius, but I haven’t seen viable options that increase ground clearance. The stock 19 inch wheel combination fills the wheel well almost completely. I don’t know if it’s possible to get much additional ground clearance without modifying the suspension.
    If you are serious about getting noticeably more ground clearance, this exists: PRIUS 2023-2024
    Do not choose a 215/55R17 wheel/tire combination if you want more ground clearance. It will decrease your wheel height by 1.5% on average, which will probably result in a few millimeters less ground clearance.
  6. Mendel Leisk
    40,235
    The above is comparing the Toyota spec'd 195/50R19, and 215/55R17, an alternate to the Toyota spec'd 195/60R17:
    Using this site:
    Tire Size Comparison
    For comparison, the two stock sizes:
    Worth noting: the Toyota spec'd 17" tire is 26.2" OD, and the aforementioned alternate 17" tire OD is 26.3" Also, the spec'd 17" tire's OD is 1/2" less than the spec'd 19" tire's OD.
    #6 Mendel Leisk, Apr 1, 2024
    Approximate Pseudonym likes this.
  7. YELLOW PRIUS KOREA
    KOREA
    2024 Prius
    Did you mount it to the wheel of the LE trim?
  8. Blackat
    387
    244
    Colorado
    2023 Prius
    Limited AWD-e
    I'm buying new wheels off TireRack
