Help! Left oil cap off, oil splattered about on the top valve cover, now p0351,2,3,4 ignition fault
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Rrrolfff, Nov 16, 2023.
  1. Rrrolfff
    Rrrolfff Junior Member
    77
    Irvine
    So I am an idiot and left the cover off the oil - just running errands, n I lost power.
    I've got P0351, 52, 53, 54 ignition coil circuits. I also have power train faults p3190.
    Anyone with knowledge of this is greatly appreciated
  2. PriusCamper
    PriusCamper Senior Member
    11,869
    4,809
    Pacific Northwest, USA
    How much oil did you lose? Have you cleaned it all up yet? If so, what codes came back after you did that?
  3. ASRDogman
    ASRDogman Senior Member
    7,014
    3,669
    The oil is probably in the spark plug holes and shorting out the coils.
    You can remove the windshield wiper assembly, clean everything off best you can.
    Then carefully remove the coils. If the spark plug holes are full of oil, try to sucktion as
    much oil out as possible before removing the spark plugs. You can spray carb clean all around
    the hole, then start the car and allow the engine to attempt to start. This will blow out the oil/carb cleaner.
    Only let it turn over for 2 or 3 seconds.
    Clean up the plugs and coils, and electrical connectors, then re-assemble.
    Hopefully, that is all you'll need to do.
    Clear the codes, then start the car....
  4. Mendel Leisk
    40,245
    One trick I did, with an engine with sparkplug wells prone to accumulate stuff, was take an old, compatible plug, hacksaw just the thread portion off it, and glue that to a length of of hardwood dowel. After blowing out the well best I could, I'd gently remove the plug, then screw this gizmo in a few turns. Yeah there's still an obstruction in there, but sub'ing a skinny dowel for the wider shoulder of the sparkplug helped a lot: for spraying with say brake cleaner or compressed air.
  5. Tombukt2
    Tombukt2 Senior Member
    11,569
    2,033
    Durham NC
    Lay a towel across the spark plug holes when you go to do the cranking business and it'll blow all of the carb spray and all of that right into the towel instead of all over your engine and hood if that matters to you A Shop-Vac is your friend if you have such a thing the little bit of oil and vapor and whatnot that you're picking up if there's some sawdust in the shop vac it'll absorb it right up no problem.
  6. Tombukt2
    11,569
    2,033
    Durham NC
  7. Leadfoot J. McCoalroller
    7,767
    7,245
    Pennsylvania
    2018 Prius c
    Clean it up as asrdogman suggests. That should clear the P0351-4 errors. The P3190 is a redundant "yo, your engine didn't start" which will also go away once the coils are clean enough to start the engine.
  8. Rrrolfff
    77
    Irvine
    I just pulled everything off the engine n got at the offending coils. Turns out they are somewhat protected with a rubber boot/seal, so there wasn't a mess inside as I had guessed/hoped. I cleaned the coils with carb cleaner, I shot it in the head (plugs), then blew em out with compressed air, cleaned up the areas of oil as best I could, but I'm still getting the same codes. While cylinders A,B,C are now historic, I get a pending fault for D, and a P3190.
    Engine starts, seems to idle, after around 10 seconds it stops with Xmas tree lights all about on the dash . I'm kinda at a loss. I have a new set of coils coming tomorrow am - that's my next step.
    Any more ideas? TIA
  9. Leadfoot J. McCoalroller
    7,767
    7,245
    Pennsylvania
    2018 Prius c
    It's not actually starting. When a Prius cranks to start, it goes at a much higher RPM than a regular car. This is often confused with actually running and then shutting down, but it's never actually catching.
    You only get so many attempts at that before the hybrid battery is depleted, which is a real PITA to get out from under.
    Be very careful with mail-order ignition parts. Amazon and eBay in particular are flooded with low grade counterfeits. Best to get that stuff from a brick-and-mortar Denso distributor if at all able.
    Brian1954 likes this.
  10. Mendel Leisk
    40,245
    There was no ignition problem prior to leaving oil filler cap off, everything looked clean in the spark plug wells; don’t see how it could be the coils. Definitely hang onto the old ones.
  11. rjparker
    rjparker Tu Humilde Sirviente
    9,303
    5,670
    Texas Hill Country
    I might check the ecm connectors
  12. Rrrolfff
    77
    Irvine
    Does anyone know how to accelerate the idle at start? Id like to start it n use the pedal to kick it up to like 2k immediately . I think I've seen this discussed - but I can't find a thread
  13. Mendel Leisk
    40,245
    Maybe flogging a dead horse.
  14. bisco
    50,819
  15. rjparker
    9,303
    5,670
    Texas Hill Country
  16. Rrrolfff
    77
    Irvine
    Omg - it started in maintenance mode, and has been idling a minute. It doesn't accelerate with the pedal, but I will take a solid idle over dead. Next step - a drive with a new set of $52 coils that arrived overnight thanks to Amazon...
  17. Rrrolfff
    77
    Irvine
    Further update - it ran perfectly all the way home 5 miles where I'm now putting the wipers etc back in. Shout out to this guy who made this YouTube which was super articulate and clear - a coil pack replacement seems to be an hour job
    Oddly enough, now the HV battery pack seems to be running much better (it's old, n used to keep the engine running at red lights, now it is shutting down the engine at each stop)
    So far a happy ending thanks to the Priuschat world
  18. bisco
    50,819
    congrats!
  19. Mendel Leisk
    40,245
    Just for giggles try the old coils again?
    kc410 likes this.
