Help! Overheating caused by Air Conditioning ?
Discussion in 'Gen 2 Prius Technical Discussion' started by alertdriving, Dec 16, 2007.
  1. alertdriving
    alertdriving Junior Member
    Auckland , New Zealand
    If this sounds stupid let me know.
    I purchased a Prius 2002 in Mid July 2007 with 88,267km on it. I have roughly been doing about 1000km per week. Current Speedo is at 116,435. Averaging about 20+km/ltr
    Today I got my first warming light.
    It was a really hot day 24-26’C and I had the AC on low for about 5 hours, done around 200km of driving with about 5 full stops for around 5-10minutes before the warning light came on.
    I was driving up narrow hilly roads, where if you stop on a hill the car would roll back, on the way back down the <!> Exclamation mark in the triangle came one first I thought my door was some how open, but I looked again It was the red temperature warning light.
    I rolled down the hill it beeped about 2 – 3 as I went to the bottom and stopped on the flat surface. Turned it off and did the standard oil, water, coolant, obvious leaks and escaping steam check. The engine bay wasn’t even hot, just warm.
    But couldn’t see anything wrong. (When I got home I check to see if the fan belt was slipping but it was also fine)
    Left it off for about 10 minutes started the car and it was fine. Left it off for another 30minutes just to cool down, and drove back home and it was normal.
    Any ideas what could have caused it?
    The more I think about it the more stupid it sounds that the AC is to blame. I'm take it to the dealer tomorrow, to see if they can find anything wrong with it. :(
    "I am pretty sure I didnt have the gear in B mode"
  2. patsparks
    10,664
    567
    Adelaide South Australia
    Not the AC because the system is designed to cope wit the AC being on. The radiator may be partly blocked causing over heating. Do you have your grill blocked?
  3. alertdriving
    Nothing blocking the grill.
  4. patsparks
    10,664
    567
    You may need the cooling system cleaned out or the thermostat is faulty, not unheard of. AC will load the cooling system as the condensor is in front of the radiator but on its own it wont cause overheating, especially not at 26'C, maybe 46'C.
  5. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    so many possibilities...
    Battery temp, inverter temp, bad gas, MAF sensor, gremlins...who knows.
  6. patsparks
    10,664
    567
    Well that's true I was only thinking ICE temp but it could be other things. The vent on the right end of the rear seat back isn't blocked is it?
  7. jdenenberg
    jdenenberg EE Professor
    3,910
    1,908
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Pat,
    There have been a small number of reports of failing coolant pumps - There are two:
    1. The ICE loop pump is belt driven as in most cars.
    2. The Inverter loop pump is electric (at least on my 2004).
    Either one can be the cause of overheating, but since the AC puts an added load on the inverter, I would first focus on possible Inverter loop problems.
    JeffD
  8. alertdriving
    :):D:eek: Problem Fixed :D:eek::)
    It was the Inverter coolant pump.
    Got it fix.
    Yeah.
