Help - Parking Sensor wiring
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Wavey, Apr 23, 2011.
  1. Wavey
    Wavey New Member
    Alaska
    Hi all-
    I got one of those license plate mounted back up parking sensors and now I need to send the wires up through the liftgate (through the gasket cluster at the hinge?!) and then down to the back up lights. Is this mission impossible or just mission near-impossible?
    Thanks for any suggestions...
  2. cproaudio
    cproaudio Speedlock Overrider
    2,401
    760
    CA
    WD40!! I ran 4 18awg wires and a 14/3 120VAC through that grommet so your little parking sensor wiring should be a cake to fish through.
  3. dopey423
    dopey423 New Member
    77
    16
    Silicon Valley, CA
    just a question but why does it need to be connected to the reverse lights? there is a reverse wire you can tap into near the kick panel by the parking brake.
    otherwise if you are sending wires through the hatch and the rubber tube.. many people on here have suggested using lube. i attached mine to a chopstick with duct tape to fish through the rubber tube. seemed to work :)
