1. Christina.cmb
    Christina.cmb Junior Member
    38
    16
    Bay area Ca
    Hi. I have a 2007 Prius with about 260,000 miles. (This is a completely different issue from my other prius)
    Recently once i open the door a buzzing high pitch noise stays on the enite time. The brakes become hard. The car runs fine though.
    I know this can be the ABS system or a bad battery. Right? I did the battery test through the dash/navi screen and these are the readings
    12.2- after sitting for 4 hours.
    11.9-11.6 accessory mode.
    11.8-11.4 when open door.
    14.1-14.2 when started the engine.
    Could it be my battery? Or does the readings seem normal?
    Also, does anyone know of a good hybrid mechanic in Connecticut?
    Thank you
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,830
    Clearwater, Florida
    Although the 12 volt battery does not look that good its tired its not going to cause what your seeing and hearing that's a bad abs actuator as you surmised. Classic high alert and hard brake pedal. Do not drive the car until its fixed.
    use the search forum button up top and search
    abs actuator
    there's hundreds of posts about it lots of info.
    SFO and jerrymildred like this.
    51,015
    christina, it is time to move on to a newer vehicle.
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,136
    Tampa, FL
    You're right, Christina. Most likely a bad brake pump. The battery is a little weak, but not weak enough to make the pump take that long to shut off. My 12V on my 2005 got down to about 8.5 volts before I realized what what happening.
  5. bisco
    51,015
    you're going to be dumping a lot of money into a worthless car to keep it running
  6. SFO
    SFO Senior Member
    5,302
    4,245
    Northern California
    How many Prii do you actually have? o_O
    One might surmise that you're looking for a part-time mechanic :whistle:
  7. frodoz737
    frodoz737 Top Wrench
    4,503
    2,426
    33
    Don't ya just wish all cars would go 260,000 reliable miles before it's time to start shopping again. ;)
    jerrymildred likes this.
  8. bobodaclown
    bobodaclown Member
    216
    72
    A new brake accumulator for Toyota list $1700 but can be found online for $1200. A rebuilt can be found for approx $700. I just paid $525 for labor to install.
    SM-T700 ?
    scona and bisco like this.
  9. bisco
    51,015
    one in ct and another in ca, i got the inside scoop
    Raytheeagle likes this.
  10. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    Both coasts covered:).
    Glad someone is in the know:cool:.
  11. bisco
    51,015
    i wish i had one in each, i wouldn't be in ct right now, that's for sure :(
    scona, SFO and Raytheeagle like this.
  12. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    Sunny and 60 here today:).
    Spent most of the day outside;).
    Definitely helps with getting energy out of the kids(y).
    SFO and bisco like this.
  13. bisco
    51,015
    yep, you gotta run 'em ragged. that's why you have kids when you're young, i can barely keep up with my grandson one day a week.
  14. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    The family that we visit near Palm Springs is up until tomorrow and they have twin girls the same age as my son, so there is plenty of energy to burn going around;).
    Just happy it wasn’t raining this weekend as penning up this energy would be bad:cool:.
    My kids even slept in this morning so hoping for a repeat of that(y).
    #14 Raytheeagle, Dec 29, 2018
  15. Christina.cmb
    38
    16
    Bay area Ca
    Hi. I have 2. Same years.
    SFO likes this.
  16. Christina.cmb
    38
    16
    Bay area Ca
    It will cost be 600.00 to fix with a used part. I rather do that then pay for a new car, do you think?
    SFO likes this.
  17. Christina.cmb
    38
    16
    Bay area Ca
    You are located in CT? Do you know any good Hybrid mechanics?
  18. bisco
    51,015
    sorry, no. i'm the boston metro west. i don't keep my cars long enough to need more than oil changes
    i just meant i would be in cali this time of year.
  19. Christina.cmb
    38
    16
    Bay area Ca
    I see. Funny thing is, I am in Cali right now. But I leave end of month so I want my Prius up and running by time I return.
  20. bisco
    51,015
    gotcha, coming back for the weather. :cool:
    SFO likes this.
