HELP!!!! Please?
Discussion in 'Generation 1 Prius Discussion' started by Dragonfighter, Aug 6, 2009.
  1. Dragonfighter
    Dragonfighter New Member
    2002 Prius
    I disconnected the negative cable on my 2002 Prius to try and clear the Japanese menu on the Nav system and when I reconnected, the car starts, followed by the red triangle illuminating on the cluster, a Warning screen comes up on the display with the silhouette of the car flashing red with and exclamation point and then it shuts down.
    I tried to disconnect again and even jumped the auxillary battery with no joy. This is an emergency. Please help.
  2. Dragonfighter
    2002 Prius
    Okay, panic is over, I disconnected the cable again and put the auxillary on the charger for about half an hour, at that point it only showed a 50% charge.
    I went ahead and hooked it all up and said a little prayer. It all came on with no warnings and I drove it until a recharge of the main battery was complete. Still can't get rid of that Japanese menu though.
  3. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    I think you are stuck with the menu. Was the car originally registered/used in Japan?
  4. Dragonfighter
    2002 Prius
    Negative, according to Carfax it has spent its entire life in Texas. I guess I will have to fix/replace the navigation unit if I want it to go away.
  5. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    there should be a way to select language. wait around for a gen 1 owner to respond...
  6. reverai
    reverai New Member
    119
    Alexandria, VA
    Actually someone who reads Japanese might be better...
    Steve
  7. bwilson4web
    15,930
    We can't rule out a 12VDC problem. If you have a VOM, we need to see 13.9 VDC on the 12 V battery while the car is parked and in "Ready" mode.
    The 12 V system provides power for the six, control computers that run the car. If there are problems here, the car rapidly becomes inert.
    Can you post a photo?
