Help! Prius won't start without key
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Dipena, Jun 28, 2008.
  1. Dipena
    Dipena Senior Member
    1,567
    68
    Massachusetts
    My 08 is about 3 months old and has <4000 miles on it. My daughter drove it today. She apparently had it in auxiliary power mode to use the Nav system (ie, not fully powered up). She thinks she left it on only 15-20 minutes or perhaps less. After that she couldn't get the car to turn on, but she saw the icon with the key flashing, looked it up in the manual, and then got it to start using the key. Drove it about a half-hour after that without problems.
    But it still won't start without the key engaged. What happened? How do I fix this? I love my keylessness and just want my baby to be OK again...
    Thanks for your help.
    Dianne
  2. JOS
    JOS New Member
    25
    Fort Worth, TX
    Look under the steering wheel, see a button labeled "KEY"? (assuming the button is in the same spot on your '08 vs. my '06) Is it depressed? If it is then you have the keyless entry locked out (no pun intended). Simply reset it and all should be back to normal (keyless entry and starting available).
  3. Dipena
    1,567
    68
    Massachusetts
    Wow! This is the second time you guys have bailed me out. That was it, exactly, JOS. Thank you.
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    One other piece of information: the little red flashing key has nothing to do with needing the key. It shows that the immobilizer is active, which is part of the anti-theft system.
    Tom
  5. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    Good call, JOS. It's not the first time someone's bumped the button with their knee or something.
  6. Bear68
    Bear68 Member
    373
    72
    West Palm Beach, FLA
    Bear in mind there are TWO lights which have a key symbol. One is red and simply shows the immobiliser is active. The other is a larger amber light which indicates the SKS (Smart Key System) has not detected the key in the car. Checking the SKS button located below the steering wheel is the first step and usually solves the problem. The main purpose of the button is to allow you to deactivate the SKS when leaving the car for an extended time (two weeks or more) It helps to avoid running down the 12V aux battery.
