HELP, SIRIUS Lifetime Member, no way to use it in Prius v II
Discussion in 'Prius v Audio and Electronics' started by detrw97, Dec 1, 2011.
  1. detrw97
    detrw97 New Member
    I am getting ready to purchase the prius v II tomorrow. I don't think it has Sirius/XM. I have a lifetime scubscription for Sirius. WHere is the best place to put a radio in the Prius and where can I buy the mounts?
  2. 2sk21
    2sk21 Member
    138
    22
    Teaneck, NJ
    This is a little complicated. Even though Sirius and XM have merged, they are not fully integrated. If you have an XM radio things work a little differently than if you have a Sirius radio.
    The Prius v most certainly does have SiriusXM but note that it is an XM radio not a Sirius unit.
    I have been a Sirius subscriber for many years. I had expected that I could simply switch to the built-in sat radio in my Prius v but it was not that simple. I had to call up SiriusXM and cancel my old Sirius subscription and switch to an XM subscription. Most of the channel line up is about the same.
    In my case, I had to switch packages because the default pack on XM does not include Howard Stern (an acquired taste I admit but if you live in the NY area, you get used to him :) ). Th package for XM that includes Howard Stern is a bit more expensive than on Sirius.
    Hope this helps.
  3. supra90
    supra90 New Member
    30
    florida
    2001 Prius
    What sirius tuner you have ?
  4. homegameroom
    homegameroom New Member
    37
    Cleveland, OH
    I also have a lifeftime subscription to Sirius. I was told that, for a small fee, I could transfer my subscription from my "lifetime" unit to another unit.
    I have not done this, but it should be possible. (I asked when I was concerned about the longevity of the hardware I had bought. Nothing lasts forever!)
    Maybe you could transfer the subscription to the built-in unit in your car?
  5. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Check this out
    SIRIUS Satellite Radio Interface Adapter for Toyota, Lexus, Scion | TOY-SC1 | SIR-TOY1 | SIRIUSConnect Factory Radio Tuner
    It's converter that receives Sirius then plays it through your XM radio, display and all.
    I have no experience with it.
  6. detrw97
    detrw97 New Member
    I am a huge Howard fan and that was the reason I got Sirius. I ended up installing my Sirius unit in the car and am using the Aux cable. It works fine. I purhcased a hardwire unit so I did not have to use the cigarrette lighter. Looks nice and works perfectly. Thanks for the help
