Help the Technician
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by andyprius, Nov 24, 2005.
  1. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    CND stands for Could not duplicate (malfunction) If you in any way can deliver the car to the dealer in its defective state, by all means do it. Otherwise you may be back tomorrow with the same problem.
  2. Bill Merchant
    Bill Merchant absit invidia
    4,096
    85
    Is this comment supposed to be connected to someting else?
    Thanks for the definition, I guess.
  3. galaxee
    galaxee mostly benevolent
    9,810
    468
    MD
    thanks for putting this out there, andy. it's a major aggravation to techs.
    that's usually why intermittent problems go back unfixed- ya can't fix what ya don't know is broken.
  4. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    The repair manuals have a pretty good rundown on how to set up
    test conditions and then go around wiggling harnesses and connectors
    to try and find intermittents. Hopefully all the Toyota techs
    read and heed these things. There are enough connectors in this
    car that the occasional bad connection or loose pin is a distinct
    possibility...
    _H*
  5. andyprius
    2,212
    188
    At the service lineup at the dealership I discharged the 12 Bat before leaving the vehicle. The service writer got in the car and then could not start it. It was necessary for him to also jumpstart it. This was easy for me to do as the 12 V Bat was just about shot anyway. That's what I meant by help the Tech and eliminate CND's.
