Help with a funky smell
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by austingreen, Dec 31, 2009.
  1. austingreen
    austingreen Senior Member
    13,623
    4,165
    Austin, TX, USA
    Today I smelt something bad coming from my prius for the second time. It smelt like something was burning, maybe electrical. Battery was at full charge and I was braking down hill. I have just a little over 1000 miles.
    Is this something to be concerned about, or just a normal burn in item? I would take it to the dealer to check it out, but since this is only the second time its happened I doubt its easy to recreate.
  2. jim256
    jim256 Member
    317
    69
    Eastern NC
    It might be just undercoating applied at the port or dealer, although that's normally burnt off hot surfaces in the first miles. If you've had it on long drives before the smell occurred, I doubt it's that, so probably worth a trip to the dealer. If it's inside or outside smell, or both, may help the dealer advise you.
  3. Fstr911
    Fstr911 Member
    235
    55
    The odor you describe is very simular to heated or nearly overheated brake pads.
  4. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    There aren't many big hills in Austin is there? I would think it would take a mountain to overheat brakes?
  5. Fstr911
    Fstr911 Member
    235
    55
    Yes, it would take a good size downhill, or a person that had the bad habit of riding the brakes, or maybe driving with the emergency brake on.
    Anyway, I think it's worth a trip to the dealer to check out the problem. One car fire could ruin your whole day.
  6. Bobsprius
    Bobsprius BobPrius
    679
    Buffalo
    There is another post about this, but it appears to be the Hybrid Battery Pack just heating up for the Regen of the brakes.
    I understand from all the postings this is a normal condition from the regen to the HV Battery. It should not be detrimental.
    Were you using B mode at all?
    It could be something of the brakes as well.
  7. austingreen
    13,623
    4,165
    Austin, TX, USA
    I wasn't in B, and I believe I was mainly the regen portion of the brakes both times, the second time a little bit of friction. It didn't smell like conventional brakes.
    We have rolling hills not mountains, I was thinking it might be something with the regen/battery pack/ or inverter. I can easily go down some hills to charge the battery up if you think that will make it repeat. If it does, is there a way to check to confirm where the smell is coming from?
  8. bramesh
    bramesh New Member
    25
    Singapore
