Help with electrical issues - Prius 2002
Discussion in 'Generation 1 Prius Discussion' started by Mit5urugi, Dec 8, 2014.
  1. Mit5urugi
    Mit5urugi New Member
    Oakland, CA
    2002 Prius
    Edit: It's a 2002 Prius - I Gen
    Hola! I have a strange electrical issue with my Prius. When I turn on the headlights, the dash lights along with the speedometer screen shut off (they stay lit, dim for a split second and then black out). It's like they only work in day-mode, but not night mode. I suspect this might be a fuse problem. Anyway I can get away with fixing this myself? Anyone have experience with thsese kinds of issues?
    Cheers,
    ZM
    #1 Mit5urugi, Dec 8, 2014
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,342
    Wilmington, NC
    Check your dimmer wheel switch. If it is turned down this will turn off the dash lights when the headlights turn on.
  3. Mit5urugi
    Oakland, CA
    2002 Prius
    Mind: Blown.
    Thanks jdcollins5! It totally worked!
    Also - I'm an idiot! :ROFLMAO:
    jdcollins5 and ftl like this.
