HELP with Gen I 2002 Prius!
Discussion in 'Generation 1 Prius Discussion' started by brianandlauriec, Sep 13, 2010.
  1. brianandlauriec
    brianandlauriec Junior Member
    17
    Oregon
    2002 Prius
    I have just had the unfortunate occurance of having the READY indicator on my 2002 Prius NOT come on when I turn the key to On.
    This is accompanied with the red triangle ! indicator on the center dashboard (where the READY is displayed) and a car ! indicator along with "Problem" displayed on the center display.
    This is not the cold weather starting issue that many of us are familiar with.
    Interestingly, the ICE may be started and the car may be driven; however, when backing up the car has perhaps 50% of the power it normally has. Also the main batter charge indicator flutuates a lot and the car seems confused about having to charge the main battery--often now turning on the ICE to charge it then quickly turning the ICE back off.
    Has anyone seen similar symptoms??
    I'm hopeful this may only be a sensor of some kind, and not a major component--which would be fatal for this car with just over 100k miles. Thank you for your time and help!
    The ready indicator does come on after turning the key to Start, and it stays on.
    What could cause this failure?
  2. Patrick Wong
    18,200
    6,490
    I do not understand how the car can be driven, if it is not READY. In any event the problem is serious and you should visit your local Toyota dealer so that the DTC can be read and a diagnosis performed.
  3. bwilson4web
    15,930
    This sure sounds like a bad traction battery but to confirm the diagnosis, we need codes.
    GETTING CODES
    1. Get it to a dealer - their service department has scanners that can diagnose the problem. Ask for a listing of the codes and bring them here for any backup.
    2. Rent Graham miniscanner ($150 instrument deposit, $10/mo. rental) - allows reading error codes and critical traction battery values.
    3. ScanGauge II ($175) - thanks to w2co and vincent1449p, we can use it to read HV and battery codes. From the battery we can read the 19 module-pair voltages and make and confirm a diagnosis. Works best with a well documented adapter.
    4. Auto Enginutity ($400 and your laptop) - allows reading just about everything although some obscure data is marginal. Regardless, it has fairly complete coverage.
    5. Techstream Lite ($1,200-1,500 and your laptop) - Toyota's offering for independents and do it yourself mechanics.
    6. Over the counter scanners ($50-$200) - little more than junk, they barely cover emissions data and don't know about the different ECUs. If it doesn't show "ISO-9141 KWP2000," don't even bother. . . . junk.
    FIXING BATTERY
    1. Toyota ($2,200-$3,000) - turn key, one stop shopping.
    2. Re-InVolt ($1,400-1,700) - two people can swap the traction battery in about 4 hours. I've been one of the two people and it isn't that difficult. Alternative, have an independent mechanic shop (or ask the Toyota service center if they do) to swap the battery.
    3. Do It Yourself ($500+) - this is not a trivial task because you'll need: smart chargers, access to replacement modules, and some skill and instrumentation. It can and has been done successfully by technically skilled individuals but it is not a trivial, 'do it in a week' job. The car will be down during this period and there are new skills to master.
  4. freidawg
    freidawg Prius Recycler
    111
    35
    Denver, CO
    2003 Prius
    The only way to do anything is to scan the codes and pull data from the car.
    Eric
    Eric
  5. brianandlauriec
    17
    Oregon
    2002 Prius
    Okay I have borrowed a reader -- a basic one and can read two codes:
    P3125 and P3009
    These I think point to high voltage battery and inverter connection problems.
    Any suggestions? Also do I need a more advanced reader? (More information probably couldn't hurt)
    Thank you for your help!
  6. bwilson4web
    15,930
    This is what we've found:
    • P3125 - generic code for the inverter. There are several dozen sub-codes associated with the inverter and to date, only the TechStream ($1,200-1,400) or shop scanners are known to read them out. However, w2co and vincent1449p have done excellent work and it may be possible to read out an inverter subcode. Without the subcode, you're faced with an exhaustive debug of each signal.
    • P3009 - means there is a high voltage leak, usually in the traction battery. We know the older style modules have weak terminals and the electrolyte can make a path to the traction battery case. There have been some reports of clearing this but it is also the signature of a failing traction battery.
    What is most needed is reading the voltages of the 19 modules or getting the maximum and minimum voltages. If the difference is 1.2 V or greater, then one module has failed and it is only a matter of time before the car becomes inert. Your options for reading these critical values are:
    • Toyota service center (~$100) - ask for a diagnostic analysis and printout with all the codes and traction battery voltages. There have been some reports of difficulty getting this from some Toyota service centers.
    • Graham miniscanner rental ($150 deposit, $10/mo.) - I have two available and can take a PayPal payment or invoice via PayPal for the $150 tool deposit. This scanner reports minimum and maximum voltages and block numbers as well as 50 other critical vehicle measurements.
    • ScanGauge II ($175) - with an adapter and using vincent1449p table, this can read all 19 module voltages as well as minimum and maximum module voltages. The adapter can be made from ethernet parts bought at any hardware store or I can fabricate one for cost of parts ($20).
    • Auto Enginuity ($400) - can read measurements for all controllers but not the inverter subcodes. It has mostly full coverage but their support is terrible and is leading their product into a bad place. You have to provide your own laptop with USB.
    • TechStream Lite ($1,200-1,500) - provide your own laptop, a Toyota product.
    As for the traction battery, there are seveal choices:
    1. Re-InVolt or other known rebuilders ($1,400-1,700) - a turn-key solution that you or an independ shop can install. They deal with bad buss bars from corrosion automatically (i.e., no additional charge.) Now there are reports that some Toyota Service Centers can or will install their traction batteries but we've also heard less favorable reports. It really depends upon the local shop policies and not all are enlightened.
    2. Toyota ($2,200 parts + $800 labor) - we've seen postings of even higher costs and it depends. Certainly replacing the buss bars ($200) is a reasonable approach.
    3. Salvage battery ($500-$1,000) - a pure gamble as there is no assurance it will work.
    4. Do-It-Yourself-Rebuild ($200-$1,000) - requires unusual technical skills, a work bench, and special battery charger ($150). This is not recommended for non-technical folks as there is a steep learning curve in electric and battery based technology.
    As for the P3125 code, please measure the voltage of the auxillary battery with the car running. If it reads 13.8-14.0 volts measured at the terminals, the DC-to-DC converter that powers the 12 V battery is good.
    Also, measure the 12 V battery before starting the car. If the voltage is below 12 V (~12.3 V is the target), then it is weak and this can induce a large number of pernicious symptoms. Replace the battery and then we can work on the car. The 12 V battery powers the control computers and if it sags too much it can induce a lot of random problems.
    joedirte and andyprius like this.
  7. brianandlauriec
    17
    Oregon
    2002 Prius
    Thank you! This is all very helpful!
  8. jk450
    jk450 New Member
    Actually, the codes as well as your symptoms point away from, rather than toward, the HV battery.
    In the absence of diagnosis, knowing the three-digit information code or codes accompanying the P3125 code may help to narrow an educated guess. But without diagnosis, it's still a guess.
  9. brianandlauriec
    17
    Oregon
    2002 Prius
    Additional pieces of the puzzle:
    measurement of the 12V battery reads 13.8V with the car running. With the car off the 12V battery reads 12.7V (and is slowing couting down) I'm guessing that with enough patience it will eventually run down to 12.3V
    Using my reader I cleared the P3125 error just to see if the code would come back.
    The problem cleared for a minute and I started and idled the car for a minute. It was charging the HV battery in park then the center dashboard indicated problem and the car with the exclaimation point. The yellow check engine light came on as well.
    So, I attempted to read the codes again to see if P3125 came up again, but this time no codes were present in the Prius computer (?) Do you need to drive the car for a period of time for codes to register?
  10. bwilson4web
    15,930
    Excellent! The 12 V system is in good shape.
    No, the codes would be readable but we've learned the commercial, over the counter scanners are . . . junk. There is no need to drive the car to get the codes.
  11. w2co
    w2co Member
    366
    81
    Longmont, CO.
    I've got a quick idea, since your 12v system is good, and you have logged a P3125 - with the ignition to on (not start yet) is the inverter coolant pump running? You can see turbulence in the inv. coolant reservoir, and you may be able to hear the pump (just behind and slightly lower than the drivers side headlight. If no turbulence or pump noise, the inv. may have cooked, but if there is turbulence -never mind carry on gents.
  12. brianandlauriec
    17
    Oregon
    2002 Prius
    More info:
    While driving the car will sometimes also (in addition to the check engine and main fault indicators) illuminate the BRAKE red indicator on the dashboard and will rev the engine very high. However if you shut off the car, and restart it -- the BRAKE indicator will be off and the engine will return to normal rpm.
  13. bwilson4web
    15,930
    We need codes to understand what is going on.
    Our Prius has a suite of computers that operate the different systems. These error lights let you know something is wrong but they do not give us the specific diagnostic trouble codes.
  14. bwilson4web
    15,930
    Ok, the Graham miniscanner is on the way programmed:
    Column 1 Column 2 Column 3 Column 4 Column 5 Column 6 Column 7 Column 8
    0 slot 1st line 2d line usage
    1 7 Batt. SOC % Current A traction battery charge and current
    2 1 Aux Bat. V Batt. V. 12 V system health and traction battery voltage
    3 2 Max. Batt. Blk Max. Batt. V the best pair 1-19 and voltage
    4 3 Cell Temp Max Cell Temp Min looking for overheating in modules
    5 4 MG1 Temp MG2 Temp looking for excessive heat MG2 should be less than MG1 unless MG2 has a problem or very high speeds
    6 5 Engine temp rpm lets us know the engine is running OK sorta
    7 6 Min. Batt. V Min. Batt Blk identifies weakest module pair if 1.2 V below max is bad stays on same module is bad
    There are about 50 different things we can look at but the Graham miniscanner is not easy to program, the first time:
    It is 'modal' software so having this sheet handy will help. BTW, I forgot it is an RJ-11 (telephone jack) for the RS-232 signal. I had to use a resistor network to connect it to my Macintosh.
    For more detailed information from the inventor:
    ECROS Technology - Z8 Encore! Products
    Thanks,
  15. brianandlauriec
    17
    Oregon
    2002 Prius
    Okay, I have rented the ecrostech scanner.
    A useful device--which would have been more useful if it had come with the user manual (which is still available at ecrostech.com, luckily), and it woud have been helpful if it had come with the RJ11 connector to serial port for data logging. Without it, I'll have to get access to the schematic so I can wire from the RJ11 (phone cable) port to the 9 pin serial port for connection to a PC.
    Here are the trouble codes:
    engine ecu
    P0000 P0000 P0000
    hybrid veh ecu
    P3000 P0000 P0000
    battery ecu
    P3006 P3009 P3026
    Addition info:
    max B blk 16.59
    max bat blk #1
    (sometimes this toggles to #15)
    Battery SoC 52.5%
    inverter mg1 39C
    aux battery 13.9
    bat voltage 326V
    The bat voltage seems oddly high--isn't this 2002 prius supposed to have a battery voltage of 273.6 V (38 x 7.2)
    I can not find out how to read out the individual battery cell voltages.
    Please feel free to comment and offer suggestions. If I need to pull more data or inspect something I can do that (and post pictures as well)
  16. bwilson4web
    15,930
    I figured with the manual online, it would be easy enough to pickup. As for the RJ11:
    You'll need to wire up a connector so the Tx from the Graham scanner goes to the Rx of the 9-pin D and the ground pins. There is no handshake so CTS is not needed and the RJ11 Rx is used only for software upload. Please do not try to change the software as if this is done badly, the unit will become unusable.
    When recording the data, it reports the "n" data items based upon the "n" of "Option 2" setting the to top from the current display line. When capturing data, I set line 7, 1, and 2 to the values I want to record. The unit comes up reporting these values but if you manually change the line displayed at the top, it also shifts the data reports.
    The data is displayed <TAB> delimited with a relative time-stamp in seconds and single items per row. Save the recorded data as text and use excel or an equivalent spreadsheet and the data can get loaded into columns. It is not the easiest format but usable.
    My experience is data recording is a 'stream' and of most useful if doing an engineering study. Lets get a diagnosis and correction of the Prius problems because if it stops running, there really won't be any engineering data. Once the repairs are underway, we can work out a swap. I have a second Graham scanner with a 9-pin "D" connector. I've never tested the 9-pin "D" because I don't have a computer with a connector.
    Ok now we have something. You can clear the codes and this allows us to find out if they are permanent or intermittent codes:
    • P3006 "Battery SOC Are Uneven" - the VMAX and VMIN exceeded. The signature of a failed module
    • P3009 "Leak Detected" - typically due to electrolyte cause a current path to ground. Humidity tends to increase the leakage. Normally the all traction battery terminals are isolated from vehicle ground. In effect it has a built-in, "ground fault" and it has found a leak.
    • P3026 "Battery Block # Malfunction" - the modules are numbered 1-19 and P3011 is block #1. So this means block#16 has a problem
    For confirmation, use the Graham scanner and touch the middle button so "01" shows. Then tap the right button until the minimum voltage is shown with the block number. The Graham scanner can not survey all 19 module pairs. However, it does report the minimum voltage and block number and the maximum voltage and block number. This is enough to confirm the diagnosis.
    There are a total of 14 items that can be displayed by cycling through the 7 lines. The remaining 50 items can be displayed by programming new data fields for any of the lines, replacing the others.
    This typically is seen in the morning when the car is first started. However, a failed or failing module can lead to higher voltages. I typically don't pay any attention to total battery voltage or even SOC as long as the VMAX and VMIN for the 19 modules are within ~0.3 V. In a series battery, balance is the first priority.
    What happens is a 'more charged' module when being charged is driven into overcharge which damages it by generating gas and high temperatures. During discharge, the 'less charged' module is reverse charged which destroys it. By having all modules in equal charge or close enough so the guard-bands keep them in operating range, the battery returns years of service.
    Sad to say, the Graham scanner won't read out the 19 monitored, pairs of modules. However, it isn't necessary to diagnose a failing battery.
    The ScanGauge can read out the 19 voltages and module-pair resistance. However, it doesn't handle the engine parameters like the Graham scanner. Also, the ScanGauge has its quarks too although thanks to w2co and vincent1449p, we are finding ways to work around them.
    Please cycle through the other lines, especially looking for the VMIN and block number.
    Also, clear the codes and see what comes back. I suspect you have hard traction battery failures which means 'the clock is ticking.'
    On the traction battery, you have options:
    • Toyota replacement ~$3,000 - if you are not 'do-it-yourself', this returns the car to operation and you're good to go with a one year warranty.
    • Toyota battery, you rebuild, $2,400 - recently an owner in NY ordered the replacement battery and swapped the electronics to replace his pack. He reported it took about 5-6 hours, which seems a little 'optimistic'.
    • Re-InVolt battery, shop swap, $1,400-1,700 + labor (4-6 hours) - there is a growing list of independent hybrid shops and some enlightened Toyota shops that can do this work. One year warranty.
    • Re-InVolt battery, you swap, $1,400-1,700 - either old style NHW11 modules or newer NHW20 modules. Personally, I would go with the $1,700 pack as the NHW20 modules are significantly better than the NHW11 modules. One year warranty.
    • Other rebuilders - I understand Lucsious Garage in San Francisco does this but I don't have the details. There are others but I've got no direct experience with them and can't really say one way or another . . . sorry. BTW, Arts Automotive is also well known shop.
    • Self-rebuild - this is a technically challenging task and should not be undertaken lightly. You'll need special chargers, a good work bench, and time measured in weeks to do the job right. I've seen a significant failure rate, ~50%, with those not having adquate workspace, tools and technical background often having poor results. But I'll offer what little advice I can to anyone. Just don't underestimate the effort.
    • Single module swap - well if you are trying to sell the car . . . uck. It means the next owner will probably be here in three or four months.
  17. brianandlauriec
    17
    Oregon
    2002 Prius
    Are there detailed instructions on how to access the traction battery in a 2002 prius?
    Soon I will likely need to access it for inspection and possibly even swap it out.
  18. bwilson4web
    15,930
    The maintenance manual is pretty detailed but I suspect if you Google around, you can find somewhere it has been photographed.
    I helped Daryl swap his and it was pretty straight forward. Just remove the rear seat and the covers in the trunk. The connectors are on the driver side and mostly easy to remove. There is one tricky interlock but otherwise, no real show stoppers.
    Any luck on the other lines, in particular the minimum voltage module-pair and block number?
  19. jk450
    jk450 New Member
    Not in this forum. Start here: Installing a Prius HV Battery
  20. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    Some really great information and detail Bob. Hopefullly I will never need it, but it makes for facinating reading. Thank you for your effort.:)
