Help with keyless entry
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Todd Stepp, Jun 1, 2023.
  1. Todd Stepp
    Todd Stepp Junior Member
    Rio Rancho, NM
    We've had this 2004 for about 5 years and the keyless entry as been intermittent at best to the point that we had a key cut just to open the doors.
    What I've done:
    • Checked the lockout button under the steering wheel.
    • Replaced the batteries and verified the voltage.
    • Tried to reprogram the FOBS. I get the car in program mode, no problem but when I press the lock/unlock on the FOB, nothing happens except the little read light on the FOB blinks.
    With two FOBs behaving the same, I'm thinking there's a lose connection some place. Where should I look and is there an antenna to check?
  2. JC91006
    16,637
    8,495
    Has the keyless buttons ever worked? Lock and unlock?
  3. Todd Stepp
    Rio Rancho, NM
    Very intermittently. They haven't work for a couple months.
  4. JC91006
    16,637
    8,495
    I would suspect the batteries are the culprit if it's intermittent. Do you have SRS keyless ignition? If you have SRS and can start the car (or open the doors), then it shouldn't be the battery.
    I was thinking if the lock/unlock NEVER worked, then it's a keyfob problem.
  5. mr_guy_mann
    mr_guy_mann Senior Member
    3,921
    1,888
    NJ-USA
    Assuming that you have SKS (small black button on each exterior front door handle and tailgate release, + silver Toyota logo on the fob), then you need one fully functional fob if you want to add another (brand new) one.
    My first thought would be to replace the batteries in both fobs then recheck function. You might need a fully "Prius capable" scantool to check the SmartKey System ecu for codes.
    Here's a scantool review thread.
    https://priuschat.com/index.php?posts/3290690
