Here’s how the EPA calculates how far an EV can go on a full charge
Discussion in 'EV (Electric Vehicle) Discussion' started by Trollbait, Jan 3, 2024.
  1. Trollbait
    12,227
    Tideland Prius likes this.
    50,800
    for my use case, the epa # is quite accurate
  3. Rmay635703
    Rmay635703 Senior Member
    2,632
    1,653
    Somewhere in Wisconsin
    2013 Chevy Volt
    Sucks for winter calculations
    hill likes this.
  4. Zythryn
    Zythryn Senior Member
    6,388
    4,379
    Sucks for driving up a mountain calculations as well.
    Luckily, the EPA calculations aren’t intended for either of those.
  5. Rmay635703
    2,632
    1,653
    2013 Chevy Volt
    Your right, in the mountains I was getting +30% better economy than epa but I didn’t race hard up and coasted miles downhill.
    Zythryn likes this.
  6. bisco
    50,800
    Depends on the weather conditions and how toasty you like to be.
    I’m still getting 5 mpk, but winter has mostly been high 30’s to low 40’s so far.
  7. Trollbait
    12,227
    The goals of EPA testing are...
    1. Ensure cars are meeting emission regulations.
    2. Calculate CAFE figures for manufacturers.
    3. Provide level comparisons of efficiency for consumers.
    None of those goals actually require a test that represents what real world driving is to be effective. Take CAFE, it using the unadjusted numbers of the tests, which are far from what a car will return in a consumer's hands. The targets just need to set with this in mind to meet results. The test cycles just need to be representative enough to reflect the fact cars aren't operated like planes and ships; at steady engine outputs for long periods.
    It is different with EV range. Knowing a car goes farther than another doesn't matter if it doesn't go far enough for a person's use. Would be different with plenty of fast charging stations on the ground, or extremely energy dense batteries, but we aren't there yet. Fortunately, the adjustments for goal #3 have evolved to the point of being close to real world results to appease public expectations. Just turns out getting an official EPA EV range is more involved than multiplying the efficiency results by battery capacity.
    drash, bisco and Zythryn like this.
  8. drash
    drash Senior Member
    2,530
    1,284
    Upstate NY
    Other companies are testing EVs at highway speeds which is one of EVs range weak spots (as well as acceleration and winter driving). Consumer Reports started testing all of the EVs they own at 70 mph:
    Consumer Reports EV Range Testing Highlights - Consumer Reports
    They admittedly did their testing between 70º and 90º F (21º to 32ºC), preconditioning their cars in a garage and setting climate controls to 72ºF (22ºC). It's a baseline for further testing so they can suggest to the EPA ways to report EV range values that may matter to the consumer and/or make sense without cluttering up the window sticker. Interesting results on the 22 different EVs they own and yes you can read it without a subscription.
  9. mikefocke
    3,859
    1,739
    Sanford, NC
    But what mix of stop and go, 35 MPH, 55 MPH and 65-75 MPH speeds are appropriate? How much should the mix of 2 mile, 5 mile and 50 mile trips be a factor? How should temperature, rain, snow and tires plus inflation be factored in? What should the HVAC be set to? How many passengers of what weight and how much baggage/weight in the trunk/frunk/bed? With or without roof rails? Racks? Tire inflation? Size of wheel? Size of tire? Type of tire? And what method of driving? How quickly should the acceleration from a complete stop be performed? And how much should cruise control be used?
    I want a resultant figure that matches my use case. And I want it adjusted as my use case changes.
    You can't please everyone.
  10. drash
    drash Senior Member
    2,530
    1,284
    Upstate NY
    Pretty sure Consumer Reports doesn't know themselves and are using this initial testing as a baseline for more testing. For instance they set their tire pressure to factory specs, not something some of us Prius Chatters normally do, but at least it's a baseline. Can't put everything on the window sticker. I'll bet they'll follow up this testing with winter driving, etc. and then figure out what else needs testing. As for specific variable like you listed, that's what this forum is for.
  11. Trollbait
    12,227
    Just including the EPA window sticker adjusted city and highway EV ranges in addition to to the published combined one would be useful to consumers. Plus would be manufacturers providing efficiency/range vs constant speeds. Once upon a time Tesla had range calculators that took into account temps and climate control use.
    Rmay635703 likes this.
  12. Zythryn
    6,388
    4,379
    I don’t care what speeds, weights, stop & go travel amounts, etc are used.
    As long as the test methods are transparent (they are) and consistent from car to car (the sort of are).
    I know better than to think the test results will match my driving patterns.
    My two issues are:
    A) They have two methods for testing electric cars, they should only have one.
    B) They don’t have the budget to spot check more vehicles for accuracy.
    Trollbait likes this.
  13. bisco
    50,800
    it's no different from gassers, and how many have complained on priuschat over the years that they don't get the epa mileage
  14. Trollbait
    12,227
    Except the range testing for EVs adds an additional layer of, um, involvement on top of the efficiency testing they all have to do.
  15. Tideland Prius
    16,401
    And also EVs even more fickle than the Prius in changing environments and driving style to efficiency. (I've seen my trip range from 11-18kWh/100km. That's a big range for the same trip). And city driving (and tests) favour EVs so the 55/45 city/hwy break down will result in skewed higher range ratings for more efficient EVs. And those EVs will suffer on the "highway range tests" by YouTubers, media and vloggers because of the EPA test's slight weighting towards city driving.
    If the EPA continues to do the city/hwy blend, they should also list city/hwy range rather than the current blended range figure.
    bwilson4web and drash like this.
  16. bwilson4web
    15,929
    I agree:
    I found that comparing the city and highway mileage was the best way to determine if a car is efficient or 'mock'. For example, the alleged 'mild hybrids' were a fraud as easily seen in worse city numbers than highway numbers. But the Prius proved out by the superior city numbers relative to the highway performance.
    EPA numbers are not perfect and they keep trying to tweak them. So my 2003 Prius initially had 52 MPG city and 45 MPG highway. But there have been at least two revisions that masked these original figures. Eventually, I figured out how to make my own MPG vs mph graphs and for me, the problem was solved.
  17. drash
    drash Senior Member
    2,530
    1,284
    Upstate NY
    There are other companies that are trying improve EV range predictions:
    https://www.motortrend.com/news/ev-range-prediction-improvement-here-factors/
    As pointed out in the article many EV Navigation systems will only give you a (somewhat) accurate prediction when an end point has been entered into the car's navigation system. Carte blanc trips that most people don't put in a destination, like to work or a known store, has the EV fall back on approximating EPA into its guess-o-meter range.
    Looks like Tesla owners are complaining about unrealistic overly optimistic range estimates forcing Tesla to drop some EV range estimates:
    https://www.motortrend.com/news/tesla-model-y-model-x-model-s-range-estimations-reduced-doj-probe/
    Apparently they did so without any announcements or they simply added EPA est. after certain figures. I've played with those range calculators a long time ago and while they did allow you adjust outside temperature, speed, their own tire sizes, and other internal factors, they didn't take into account hills, lousy road conditions, driving patterns, etc.., but maybe they should reintroduce their range calculators. Of course people will probably complain it doesn't fit their driving patterns.
  18. Zythryn
    6,388
    4,379
    What an interesting hit piece!
    Perhaps the connection between the lower ranges and the required EPA changes to range was too much of a leap for MotorTrend?
    Here is an article by Road & Track that explains it, complete with link to the EPA letter informing manufacturers.
    https://www.roadandtrack.com/news/a46296899/tesla-epa-range-estimates-drop-2024/
    I guess if I am looking for actual reporting I have a better idea which outlet actually does some research.
    #18 Zythryn, Jan 8, 2024
  19. drash
    drash Senior Member
    2,530
    1,284
    Upstate NY
    Hmmm, actually I think it was using the Tesla "adjustments" to eventually needle Hyundai and Lucid about their range estimates. At least that's the way I read it and they just used Tesla because they are the most recognized.
  20. Zythryn
    6,388
    4,379
    See edit above for more info.
