HID High Beam replacement for V
Discussion in 'Gen 3 Prius Accessories and Modifications' started by nylion, Jul 31, 2009.
  1. nylion
    nylion New Member
    167
    61
    Seattle WA
    I am trying to find out if I can replace the high beam bulb in my V. The owner's manual says it is an HD3. I can find H3's, but not HD3. Are they the same?
    Anyone do this yet? What is the correct lamp?
  2. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
  3. liskipper
    liskipper Member
    373
    79
    Long Island, NY
    Does anyone know if it is advisable to replace the High Beams on a 2010 type V (9005/HB3) with HID? I am concerned that the frequent on and off typical of high beam usage would
    1) shorten their life or
    2) take too long to warm up.
    Any advice would be appreciated.
  4. stream
    2,977
    452
    Long Island, NY
    I wouldn't. Instead I'd upgrade them with higher quality halogens, like I did--see this thread:
    http://priuschat.com/forums/gen-iii...-parking-lights-rear-license-plate-bulbs.html
    I've owned many cars with bi-xenon headlights, which use a single xenon lamp on each side, with a shield that moves to go from low to high beams. They all also had an additional halogen bulb that illuminated when your high beams were on, which serves 2 purposes: for use when headlights are off and you flash-to-pass (since HIDs take too long to warm up to be effective in this application), and to provide supplemental light when the HID headlights are on.
  5. radioprius1
    radioprius1 Climate Conspirisist
    1,355
    155
    Iceland
    HIDs are a bad choice for hi beams for the two reasons you mentioned, and also they would be incredibly blinding to oncoming drivers.
  6. chrisj428
    chrisj428 Active Member
    680
    144
    35
    Vernon Hills, IL
    "Yes" to both, skipper. :)
    I modified my Phaeton with the dual-xenon headlight assemblies available on ROW-spec vehicles. While I didn't have the car long enough to speak towards the longevity of the bulbs, I do know that frequent on-off cycles are very hard on xenon bulbs & ballasts (which is why the bi-xenon with the shutter was developed).
    Additionally, there was a 3-4 second delay between the bulbs firing and full brightness. This rendered them near useless for flash-to-pass and when travelling on two lane country roads where oncoming traffic is sporadic.
  7. liskipper
    liskipper Member
    373
    79
    Long Island, NY
    Thanks to all for your advice - it confirmed my concerns and I will stay with the halogens..
