HID - initial burst on turning on
Discussion in 'Gen 2 Prius Main Forum' started by sas0611, Apr 27, 2008.
  1. sas0611
    sas0611 Member
    230
    On my 08' with HID headlights, should I be concerned if when they are turned on they seem to surge for a brief instant and then quickly return to normal intensity ? It's almost like they are starting up in high beam mode and then quickly stabilize. Is this some kind of 'lighting up' phenomenon like sodium street lights.
    Thanks in advance - was wondering if anyone else has noticed this.
  2. ceric
    ceric New Member
    1,114
    Fremont, CA
    It is normal.
    It starts up bright for a second, dims down, and slowly builds up brightness in a 1-2 minutes. All HIDs do that.
  3. john1701a
    john1701a Prius Guru
    12,793
    5,275
    57
    Remember that HID bulbs don't actually have a filament. Instead, the light comes from an arch of electricity. That initial burst will be different from sustained operation afterward. Think of the startup as a mini lightening strike.
  4. kcpistol
    kcpistol Byte Stylist
    51
    Independence, MO
    2019 Prius
    Just thought I would chime in - mine do it too, if that helps any.
    Love the color of those HID lamps :)
  5. tmanson
    tmanson Geetar-playin' Traveler
    71
    Frederick, MD
    Yeah, mine too. I assumed it was normal.:)
  6. canesfan
    canesfan Culture shocked...
    544
    Jacksonville, NC
    Same thing happens on my Chrysler 300C.
  7. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    That's it exactly.
    Tom
  8. statultra
    statultra uber-Senior Member
    798
    31
    Edison,NJ
    2001 Prius
    it could also be the auto leveling mechanism, the auto leveling system goes through an initial check, i think.
  9. qbee42
    18,058
    3,076
    Northern Michigan
    That doesn't make them flash, just move a bit.
    Tom
