1. Optical Illusions
    Optical Illusions Junior Member
    42
    16
    Hello everyone.
    I recently installed the DDM Tuning HID kit on my C4 head and fog lights. I'm having flickering issue when the car is not on, one of my light won't turn on. When the engine is on all of them are on. I've come to the conclusion that i need to install a relay for my HID kit.
    The question i have is; where can i find the constant 12v power source under the hood since the battery is inside the car located under the passenger rear seat? Sorry I'm not very mechanically inclined nor electrically inclined. I also don't have a volt meter or know how to use one. So any help would greatly appreciate.
    Thanks
  2. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    In the fuse box under the hood, u will see 2 empty spade terminals (each buy themselves). These are constant 12v
  3. xliderider
    xliderider Senior Member
    8,016
    3,198
    Honolulu, HI
    In the gen3 hatchback it looks like this:
    Where you see the 2 red wires going to the terminals. Additionally, to the right of the heavy white wire I have a cover removed and you can see a bolt that is a 12V positive terminal as well that you can put a spade lug under.
  4. Teddy Ngo
    Teddy Ngo Junior Member
    40
    16
    Mission Viejo, California
    50w or 35w? I have the 35w kit and no issues
  5. DKTVAV
    DKTVAV Active Member
    510
    101
    I have 55W and no issue.
  6. Optical Illusions
    42
    16
    I have a 55W for the low and the 35W for the fog.
  7. Nel
    Nel Member
    174
    84
    SF Bay Area
    Is this a common issue for HIDs in our Cs? I'm considering a set and would like to know prior to taking the dive.
  8. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    Depends on the cheapness of the Ballast. I have no issue in either of my sets.
  9. Optical Illusions
    42
    16
    Most likely not. I just have bad luck with mine that is all.
  10. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    im running 55w DDM withOUT a relay harness and they start up all the time.
  11. Nel
    Nel Member
    174
    84
    SF Bay Area
    Ok, it's nice to have a bit of peace of mind. Seems like there are many DDM guys here. How's your experience with them? Are they quality products? Do they last (I know ztanos uses an eBay supplier, and he mentioned his ballasts have lasted for 8 years now)?
  12. kingnba6
    1,018
    242
    NY
    i have the same ddm 55w kit in my motorcycle. (well different kit then the prius but same company; makes sense? lol) and it is connected thru a harness. but it has been working for around 3 year and around 10k miles of hids being on. so you should be good. they also have lifetime warranty
  13. Optical Illusions
    42
    16
    I have 55w Ballast on my 2000 honda accord, have been using that over 5+ year and it is still going strong. Same goes for my motorcycle 55w ballast over 5+ year on that too.
  14. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    Usually even the crappy ones work at least well when they are connected to the hot lead. They won't last as long, because they are crappy, but they will work.
  15. Nel
    Nel Member
    174
    84
    SF Bay Area
    A bit off-topic, but I must say that I love this forum. The responses and feedback from other members are always so helpful:cry:
    Ok no more sappy $#!#. Onward with better visibility for night time driving:sneaky:
    ztanos likes this.
