Hid's on the way!
Discussion in 'Prius c Accessories and Modifications' started by Jonnie256, Dec 27, 2013.
  1. Jonnie256
    Jonnie256 New Member
    Athens,AL
    Ordered some 55w 6000k hids last nite. Hope the look good and not a pain in the arse to install?. The low beams are h11 right?lol kinda late to double check.lol anyone else installed hids on a prius c?
  2. xliderider
    xliderider Senior Member
    8,016
    3,198
    Honolulu, HI
    Consider installing them with an HID relay wiring harness that draws power from the fuse box instead of the OEM lowbeam wiring.
    Hooking 55w ballasts directly to your factory headlight wiring may result in flickering or failure to ignite 100% of the time.
    SCH-I535
  3. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    I've had my 55w ballasts direct for almost a year now and no issues, but he is right, this is when you get iffy. They are H11, yes. Good luck, they are simple to install.
  4. Jonnie256
    Athens,AL
    Thanks! Also ordered led bulbs to go in the driving lights.
  5. xliderider
    8,016
    3,198
    Honolulu, HI
    You mean parking lights?
    SCH-I535
  6. Jonnie256
    Athens,AL
    Yea parking lights haha my bad.
  7. Jonnie256
    Athens,AL
    Well installed my hids and they look really good! But didn't really know where to put the ballasts. Just kinda shoved them down between some other wires in there where ever I could. Where have any of yall installed hids put the ballasts? Thanks
  8. xliderider
    8,016
    3,198
    Honolulu, HI
    I think The Retrofit Source has an installation video online that shows slim ballasts being located behind the plastic front fender liners.
    SCH-I535
  9. B2FiNiTY
    B2FiNiTY Active Member
    979
    227
    I mounted mine with double sided velcro tape on the shock towers for easy access in the future. Not as pretty as a hidden setup though.
  10. xliderider
    8,016
    3,198
    Honolulu, HI
    Sorry, the video was from xenonsupply.com:
    Toyota Prius HID Xenon Installation How To Guide
    SCH-I535
  11. Jonnie256
    Athens,AL
    Yea I did the drivers side on the shock tower. That vid is of a regular prius. The C engine bay is slightly differ.
