High Na level in oil resolved
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jayman, Jan 14, 2006.
  1. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    You folks may recall about 1-2 months ago I posted the results of a UOA (Used Oil Analysis) on my 2004 Prius. I had run Mobil 1 0W-30 for a bit over 8,000km, and the wear metals were remarkably low. The TBN was still +7, so the oil was clearly good for much longer intervals.
    The only concern was a high Na level, around 78 ppm. A "normal" reading would be under 20 ppm. I followed up with another UOA at half-interval (4,000km) and the Na was 15 ppm. ?? That didn't make any sense.
    I then managed to talk the dealer into filling the 120ml sample bottle with their bulk Mystery Oil 5W-30 from the tote bin dispenser system. I had the results back almost a month ago, but was in China on business, and then had to deal with a family tragedy.
    Long story short: the dealer oil, which the car ran on for the first two oil changes, had a virgin Na level of 398 ppm! The testing lab had quite a few issues with that oil, including a bit of moisture, some dirt, Fe (Iron), and even some sulfur. Clearly, this is a VERY poor quality oil.
    This turned into a wild goose chase for me. The testing lab naturally assumed a slow coolant seep, but the usual indicators were not there. After chasing some dead ends, including a few VOA of Mobil 1, they suggested I try to get a sample of the oil previously used.
    This is another lesson of why empirical data is all that counts. You can’t depend on “gut feeling†or “I heard from my pappy†or whatever. You need cold hard numbers ie data. To think some folks probably trust the oil put in their car because “it has to be good.â€
  2. MarinJohn
    MarinJohn Senior Member
    3,945
    304
    Jay welcome back.
  3. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    you mean the stock oil from Toyota is bad?? i am getting Castrol Syntec 5-20 i believe...should i change?
  4. tochatihu
    tochatihu Senior Member
    9,467
    3,656
    Kunming Yunnan China
    2001 Prius
    Sorry you had to do all the legwork, Jayman. There may be a good lesson here for those who leave engine oil decisions to others.
  5. Frank Hudon
    Frank Hudon Senior Member
    4,147
    Glad to have you back Jayman Sorry for to hear of the loss of your mother.
    man was that good quality bulk oil. That's almost a law suite right there. And people ask my all the time "why do you use that expensive synthetic oil" need I say more.
  6. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    i hear ya Frank, i may just go to synthetic and double my intervals
  7. jayman
    13,439
    641
    Winnipeg Manitoba
    John:
    Thank you, it’s good to be back. I needed the quiet introspective time with family. Now I can go back to being an introverted mean Type A workaholic.
    Jay
  8. jayman
    13,439
    641
    Winnipeg Manitoba
    Hi Dave:
    Yep, that's exactly what I mean. There really is no such thing as "Toyota" oil, with the bulk lube dispenser system it's whatever bulk oil dealer that claims to meet minimum API specs.
    Here is an example of an automated shop lube dispersant system:
    http://www.benfordfueling.com/shop/page305.html
    Jay
  9. jayman
    13,439
    641
    Winnipeg Manitoba
    Frank:
    Thanks. You've "been there and done that" at least I didn't have to watch somebody linger for years.
    Oh I doubt there is any grounds for a lawsuit. That crap they were using probably barely met minimum API requirements.
    Perhaps that is why some folks complained of sludged-up motors, with oil as lousy as this garbage was, no wonder.
    Jay
  10. jayman
    13,439
    641
    Winnipeg Manitoba
    Oops.
    Thanks to the forum member for actually asking me *what* the results were. Sorry, I claim Junior Alzheimers.
    All results in ppm, except water which is %. The numbers the lab flagged as out of range have an asterisk.
    Toyota Bulk 5W-30, at dispenser point:
    *Fe 7*
    Cr 0
    Mo 127
    Al 4
    Cu 0
    Pb 0
    Sn 0
    Si 6
    *Na 398*
    Zn 686
    K 9
    Water 0.8%
    The lab comments: "Urgent levels of Na detected. Na reading is unacceptably high for a new oil. Particle count also unacceptably high. Su detected. Possible contamination of bulk oil system, recommend investigating distributor of bulk oil, inspection of bulk oil dispensing system, and filtration of bulk oil at point of use.â€
    I've seen the tote bin that holds the mystery oil, it's a poly tank so it can't rust. The Fe must be from the bulk distributor.
    Scary.
  11. jayman
    13,439
    641
    Winnipeg Manitoba
    Actually, I didn't mind it at all. I learned some of this already from the industrial work I do, as most large industrial machines do point-of-use monitoring and inspection of the lube system.
    I just never thought I'd have to do it with my own car. Around $100 Cdn later I certainly feel a lot better, it's cheaper than a new motor.
  12. Frank Hudon
    4,147
    looking at the printout from the lab, have you taken that to the dealership and presented it to the service manager. I think a copy to corp. would also be in order.
  13. jayman
    13,439
    641
    Winnipeg Manitoba
    Frank:
    Yes, and yes. I'm in full CYA mode here, in case the motor should happen to have an "unforeseen" future problem, and Toyota Canada tries to blame it on my use of Mobil 1.
    Jay
  14. tochatihu
    9,467
    3,656
    2001 Prius
    Wowee, you can get it with a 5 gpm pump! Maybe *that's* how oil gets into the intake manifold.
  15. jayman
    13,439
    641
    Winnipeg Manitoba
    Hmmm now that you mention it ....
  16. Frank Hudon
    4,147
    I'm on my fourth Mobil 1 change so will probably get a UOA done at the next change and use it as a standard. Then every fourth change do it again. It was pretty dark at 8,000 km's so I'm going to stick with that interval for now. New air filter too so don't understand why but I'm not worried just curious. I've see a lot blacker in forklifts running on propane, mind you 15/40 dino. Ya I know, most in warehouse operation with the air temp at 65-70 all the time and lots run 24\7 so really 175-190 ICE temp continous.
  17. jayman
    13,439
    641
    Winnipeg Manitoba
    Frank:
    Actually I've noticed that Mobil 1 is sort of "dark" while new in the bottle. I did notice that sample of "Toyota" mystery oil was very pale color, like honey.
    If you remember from that UOA I did on my Prius, the wear metals and insolubles were very low - good - and the TBN was still quite high. The oil looked almost black at 8,000km, but it still had a lot of life left in it.
    Jay
  18. Frank Hudon
    4,147
    stick the nozzle in and aim it to the flywheel end of the cam cover and pull the trigger and the back end of the cover is completely full of oil. Aim it to the front of the engine and pull the trigger and it runs down the timing chain cover and never gets into the breather system which comes out of the back end of the cam cover. Pour the oil in 1 quart/liter at a time and it probably will never fill the topend to the point of it getting into the breather.
  19. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    Jayman nice bit of sleuthing. I am now glad I have been using my own oil. I look around and find Mobile 1 at the lowest case price I can find at the time.
  20. jayman
    13,439
    641
    Winnipeg Manitoba
    See? There are *many* advantages to having no social life!
    :blink:
