Hit a pothole - godawful sound - now its gone!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by bracket12, Sep 6, 2007.
  1. bracket12
    bracket12 New Member
    Tucson,AZ
    The other day, I was driving through a construction area and hit a pothole. Immediately after, I heard an awful scraping, grinding noise, so loud I couldn't even tell which side of the car it was on. I pulled over a couple blocks later when it continued to get worse. The brakes seemed to be operating normally and no lights showed up on the dash. I turned off the car and did a little inspection of the wheel areas. Didn't see anything out of the ordinary. Turned the car back on to try to continue home as I was only 2 miles away. Everything seemed to be working normally then, no abnormal sound whatsoever.
    Any idea what happened here?
    I am due for an oil change next week, so I'll have it inspected then anyway.
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    Are you sure it wasn't a construction worker? Maybe he crawled away when you stopped.
    Tom
  3. jdenenberg
    jdenenberg EE Professor
    3,910
    1,908
    Trumbull, CT
    2020 Prius
    LE AWD-e
    <div class='quotetop'>QUOTE(bracket12 @ Sep 6 2007, 02:46 PM) [snapback]508040[/snapback]</div>
    One of the plastic lower parts may have been rubbing and then fell off, but at least get an alignment.
    JeffD
  4. Michgal007
    Michgal007 Senior Member
    1,321
    98
    Macon, GA
    I was listening to 'car talk' on NPR one day and some lady had the same question about her Accord. They told her that it's the ABS working properly and you don't have to worry. May be it's the same thing happened to you. Get it checked anyway.
  5. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    <div class='quotetop'>QUOTE(bracket12 @ Sep 6 2007, 11:46 AM) [snapback]508040[/snapback]</div>
    It was probably just a rock that was rubbing on the rotor and then fell off. It has happened to me several times and also reported here several times.
  6. westex39
    westex39 New Member
    60
    You might want to get the alignment checked.
