Hood Lock Troubles
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Joe LeVasseur, Jan 30, 2018.
  1. Joe LeVasseur
    Joe LeVasseur New Member
    Budd Lake NJ
    Greetings everyone!
    Having seen how amazing and helpful this community seems to be< i"m hoping for some guidance.
    I have a 2006 Prius and the hood lock is giving me some trouble. The hood is currently in the released position (popped). The secondary safety latch is still working to keep the hood closed, but I would love to be able to fully lock the hood. Pushing it down has not done anything. The release lever on the inside of the car feels like it is in the released position. It isn't completely loose, but its only gives a little resistance. I'm wondering how I might be able to fix the issue. Thanks in advance.
  2. cyberpriusII
    cyberpriusII Prodigyplace says I'm Super Kris
    1,147
    1,665
    Iowa
    My 2008 hood has NEVER totally latched easily. I always have to drop it from a significant height or really smack it down to get it totally secure.
    Not sure if this is a new rig to you or not....if you have had for a longtime and this is just cropping up, I would say try some sort of Tri-Flow or other spray lubricant. If that does not work and slamming it down does not work...well you know where this is going....
  3. Joe LeVasseur
    Budd Lake NJ
    I've had the car for a few months, and this has been going on a few weeks. I shot the latch with some wd 40 and the latch seems to move, but not lock in place.
    I can drive it with not trouble, other than it knocking a little on bumps.
  4. cyberpriusII
    1,147
    1,665
    Iowa
    Not really safe. The double-lock is sort of like a fail-safe thing. You do not want the hood coming up on the road. If dropping from height and/or lube does not work and you don't have the skills yourself, I would take it in as soon as possible.
    In the meantime, there are lots of folks on this site who know lots more than I do, so maybe they will have a quick fix. And if it solves my issue, also, all the better.
    Kris
  5. dolj
    dolj Senior Member
    8,118
    4,132
    Wellington, New Zealand
    You need to remove the cable pull and check that the inner cable moves freely in the outer sheath. If lubricting with a quality dry lube does not get it moving freely when in position, you need to replace it. I'd be incline not to mess around with, just replace it anyway.
    If you are not a DIYer, get it to your mechanic/service center for the cabe to be replaced. You do not want to wait until the cable breaks.
  6. valde3
    valde3 Senior Member
    2,002
    746
    Finland
    You really need to get it fixed. You don’t want the hood to open while driving.
    If you want to DIY just remove the plastic panel under the hood that’s attached with those plastic screw rivets. Then you can lubricate the latch, and the cable. You can use screwdriver to simulate the hood closing and then use the leaver inside to test it opening. Most of time you can get it working smoothly without replacing anything. If you can’t get it to work smoothly you should be able to tell if it’s the latch that’s faulty or the cable. Only close the hood once it works smoothly as you don’t want the cable to break.
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,829
    Clearwater, Florida
    Take off the black plastic cover by unscrewing the black clips while pushing them out from behind.
    You don’t need to put those screws back in mine have been off for years. I look in there all the time to see how dirty the condenser is and to check coolant level.
    Just put the plastic cover back on it’s not going anywhere.
    With cover off take some clear and close pictures of the latch. Let’s see how corroded it is.
    That latch is a maintenance issue. Should be nice and greasy just like 5he door hinges and the hatch hinges
    And latch. And especially the mechanical key lock in the drivers door.
    Sooner or later the 12 volt dies and that’s the only way to get into the car. That’s when people find out it’s hopelessly corroded. Hilarity ensues.
