Hot Seat
Discussion in 'Gen 3 Prius Main Forum' started by PSVerona, Jan 29, 2011.
  1. PSVerona
    PSVerona New Member
    Verona WI
    The drivers side seat in my 2010 heats up to 98 within a mile of driving and is quite uncomfortable. While the passenger side seat warms to an acceptable range. Has any one else had this problem, if so has it been fixed.
  2. ETC(SS)
    6,841
    Greetings and Welcome! :welcome:
    I'm not aware of any common problems with the factory heated seats, but I have the old-fashioned "derriere heated" seats. Sorry. :(
    I did a search for the terms "heated" + "seats" and 'limited' my returns for the G3 only portion of the forum.
    I got 288 hits, but I don't have time to pick my way through them.
    PriusChat Forums - Search Results
    If you don't get a good answer in the "main" portion of the G3 forum, you may want to pop a flare over the Maintenance or the Technicial discussion areas.
    Good Luck!
  3. Tickwood
    Tickwood Active Member
    334
    101
    San Diego
    2020 Prius Prime
    Sounds like You have the seat heater turned on. Do you have a little red/orange light on under the flying bridge? That is the switch,
  4. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    I thought I had a problem too when I first used the seat heaters. Unlike other cars I had heated seats on, the Prius will blast heated seats up, then cycle on and off. I'll feel it cool off then heat up again before I remember to shut them off. It's nice to have them on as I turn my car heater off during the first couple miles to let the ICE warm up faster.
  5. Tideland Prius
    16,403
    I don't know about the actual temperature of the seats but I have noticed that the driver's side will heat up faster than the passenger side. It's the same on the Camry so maybe it's a Toyota thing.
  6. Paradox
    29,110
    8,591
    201
    2014 Prius v wagon
    Mine does get hot when first turned on but if left on it settles out. I've seen others say the same thing. It can get a bit hot but only for a very short time IMO and something I can live with to have heated seats throughout the rest of my drive.
  7. tumbleweed
    tumbleweed Senior Member
    4,067
    690
    Eastern Oregon
    It is controlled by a thermostat that turns it on and off to maintain a comfortable (sort of) temperature. I usually end up turning mine off after 10 or 15 minutes though. If it is getting really hot you may have a bad thermostat, dealer should be able to check it for you.
  8. creativeguy
    creativeguy Member
    301
    17
    CA
    The driver seat in most every car will heat your body more efficiently since there is a pad in the seat and seatback, while the passenger seat has only a seat pad... and even that may be compromised by the airbag sensor.
  9. Tideland Prius
    16,403
    Depends on the manufacturer. Toyota puts heating elements in both the seat bottom and seatback on both front seats.
  10. jayrider
    jayrider Member
    163
    17
    southwest illinois
    The seats on my IV heat up fast and are too hot to leave on for more than 5 minutes. That's the bad news. The good news is that I love the smell of bacon frying.
  11. Lottamoxie
    Lottamoxie Member
    403
    28
    Southeast US
    Mine heat up quickly and I too have to turn them off within about 2 or 3 min as they feel way too warm for me. Hot crossed buns are nice, but I happen to be wearing mine and don't need burn marks!
  12. Kutanks
    Kutanks Member
    118
    MA
    im so jealous, one thing i miss in my prius is heated seats (had them in my 2001 sienna)
