How badly is Nav crippled??
Discussion in 'Gen 3 Prius Audio and Electronics' started by es, Oct 27, 2009.
  1. es
    es New Member
    I hope to have my 2010 V with advanced tech in a few weeks. I am used to an aftermarket Pioneer Avic with all the constraints bypassed. How badly is the factory nav crippled? What can't I do while driving?
  2. djasonw
    djasonw Active Member
    958
    119
    Coconut Creek, FL
    WELL, that's a tough question. If someone comes up with a bypass method (as in the 2004-2009), then you're somewhat limited. I do think that you'll be able to do MORE than folks with the Gen II though. If you are used to the Pioneer unit and its unfettered access whilst driving, you'll be quite displeased.
  3. jscolieri
    jscolieri New Member
    San Carlos, CA
    aw, just bought a 2010 III, and trying to find a way to bypass restraints ... rats.
  4. RodJo
    RodJo Member
    423
    56
    Boston
  5. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
  6. robinson
    robinson Junior Member
    31
    DC
    I also did the PS nav hack. Works VERY well. I put my control buttons right next to the start button, about an inch from the steering wheel.
    Also, when you remove the console, you can remove all of the plastic parts without using tools. There is space behind the front cupholder to fit your fingers to pop off the plastic around the shifter.
  7. es
    es New Member
    Thanks for Everyone for their replies!! They were definitely helpful!!
