How common is Gen 2 Head Gasket Failure after 300,000 miles?
Discussion in 'Gen 2 Prius Main Forum' started by PrimalPrius, Feb 6, 2026.
  1. PrimalPrius
    PrimalPrius Member
    138
    America
    The coolant should be at 13 PSI, give or take, so way less pressure than combustion, so should be way less likely to cause a gasket failure than cylinder prssure.
  2. PrimalPrius
    PrimalPrius Member
    138
    America
    I'm guessing that a water pump-to-oil (via timing cover) failure path, if it happens, is likely often assumed to be head gasket and never discovered since the timing cover RTV would likely not be examined in great detail, if at all, and would get replaced when the engine is put back together or never seen when the engine is junked...
  3. PrimalPrius
    PrimalPrius Member
    138
    America
    The timing chain cover, as designed is actually "poor design", except for parts cost/parts count and assembly cost, which is what probably matters the most.
    A separate piece for the water pump would have ensured that any possible leak is external and easily detectable (instead of mixing with oil and taking out the engine).
    I'm not saying that it's what is happening with my car, just saying that it's optimized for cost at the expense of quality and durability, regardless of how common or rare failures there are.
  4. PrimalPrius
    PrimalPrius Member
    138
    America
    Some more data:
    Under the UV light, the inverter coolant already in the car also looks Peptobismol light pink, but cleaner than the coolant (which, I'm ashamed to say, was on my "change ASAP" list when I got the car 50k miles ago...).
    An unopened bottle of (Prestone, I think) coolant marketed as Toyota spec is also Peptobismol color under the light.
    Brand new oil (synthetic) under the light is white, whereas my oil (with only 325 miles on it) is a very light blue or very light purple.
    Interestingly, it looks like with the light I have, dye would not be required, at least not for coolants and oil I have, if searching for an external leak.
    #24 PrimalPrius, Feb 7, 2026
  5. dolj
    dolj Senior Member
    8,630
    4,383
    Wellington, New Zealand
    Excluding your dataset of one, this conclusion is not borne out in the general population of this model world-wide.
  6. PrimalPrius
    PrimalPrius Member
    138
    America
    I believe that they all have the same cover design as my car. I purposely put "poor design" in quotations because it all depends on what the design objectives and constraints were.
    If the objective was low cost though lower parts count, lower assembly time, etc. then using a single cover is a success.
    If the objective was to focus on minimizing potential coolant-to-oil failure paths and some added cost was allowed by the design constraints (which is what I would have picked, but Toyota obviously didn't), then they failed.
    I have no idea if that is the failure mode in my car, but it is a possible failure mode and I believe that a failure there could very often be misdiagnosed as a bad head gasket.
    #26 PrimalPrius, Feb 7, 2026
  7. pasadena_commut
    pasadena_commut Senior Member
    2,969
    912
    Southern California
    I'm getting very confused.
    If there is milky oil collect a small but macroscopic amount of it (like 1 cubic inch), put it in a small capped clear container of some sort, and let it sit for a day at room temperature. It should separate into an upper oil phase and a lower aqueous phase. If it does and the contaminant is coolant the lower phase should be pink, but water from some other source, like combustion gas getting past the rings and into the crank case, won't be that color. This assumes that the pink dye is sufficiently hydrophilic that it stays in the water phase.
    Or just do an oil change and pour all the oil into a container like a PET 1 gallon water bottle. Then wait for it to separate. But don't leave it in that container for a very long time as used motor oil might make the plastic brittle or leak. For long term storage transfer the oil to something like HDPE. HDPE isn't clear though.
    PrimalPrius likes this.
  8. PrimalPrius
    PrimalPrius Member
    138
    America
    Yes. I'm planning on pulling a sample through the drain plug and letting it sit in a tall glass.
  9. PrimalPrius
    PrimalPrius Member
    138
    America
    I took a sample from the drain plug without disturbing the oil (without cranking the engine), about 1 quart. The oil has been sitting undisturbed in the oil pan for about 3 days now. I was expecting to maybe get some coolant or water out first, but I did not notice any at all.
    The oil is light brow, substantially different, of course, from any oil I have drained from the car before. There was a pretty strong gasoline smell I have never noticed before.
    In the container the oil does not respond to the UV lamp at all. when spread thin on the paper it glows the same light blue/light purple under the light as oil obtained from the dipstick.
  10. PrimalPrius
    PrimalPrius Member
    138
    America
    I filled a tall glass with the oil and covered it with Saran wrap. (I'm not very optimistic that it will separate, but time will tell).
    Not sure why the oil this time smells so much like gasoline, especially after only 325 miles.
    I checked again and no misfire or any other engine codes.
  11. Tombukt2
    Tombukt2 Senior Member
    13,733
    2,486
    Durham NC
    Now wait a min . Many timing chain overs across Toyoda have similar water pump mounts to said chain covers . Ascmatter fact most of Toyoda legendary engines use this arrangement . I've had water pumps on 2tc hemi last the life of engine . In other words engine could get internal refresh. And the pump on timing cover do not even get removed . Timing chain tensioner metal guides do.. another 300K plausible . That original belt drive timing cover pumps is headed to 600K . Unless the cover takes damage from the inside gouging the water pump back plate water can never mix at this junction. Even chain wearing case does not get to wet areas . So not sure the design flaw . So for water from pump to enter at chain cover pump mount areas is kinda stretch .
  12. PrimalPrius
    PrimalPrius Member
    138
    America
    It may indeed be VERY reliable, but it's also an unnecessary failure path that could have been engineered even better to completely eliminate a coolant to oil contamination failure mode (at some added cost, every design is a compromise/balancing of design goals. And constraints such as cost.)
    If may happen very seldom, BUT because the automatic assumption will often be "head gasket" AND this issue (if it was present) is also always fixed by changing the head gasket, I know that frequency of this failure is undercounted, but I of course don't know by how much.
    I would be very surprised if a discussion or much more likely a debate over 1-piece vs 2-piece cover didn't take place during the design phase.
    Maybe this could help: A leaky fuel injector could result in very similar "morning knock" symptoms as a leaky head gasket and be misdiagnosed as a head gasket. But in this case after the (unnecessary) head gasket replacement the symptoms didn't go away and (hopefully) the proper cause would be found (although at least some DYIs would probably just assume that they didn't do that head gasket correctly).
    On the other hand, a misdiagnosed timing cover to oil pan coolant leak would likely almost never be discovered because 1) after timing cover removal the evidence is probably not examined and is quite possibly destroyed during timing cover removal and 2) fixing the head gasket also fixes a timing cover leak.
    #32 PrimalPrius, Feb 10, 2026
  13. Tombukt2
    13,733
    2,486
    Durham NC
    How are you getting a timing cover Leak to coolant in. Oil pan?
  14. Tombukt2
    13,733
    2,486
    Durham NC
    Something would have to compromise the back of the timing cover that's running in oil right wer water pump mates . ! I don't think chain can get it . Sooóo. not sure just the aluminum be coming porous? Which is possible but extremely rare I've seen but not on Prius. on older ke engines. The Little engine that goes in the hydrofoil boats 1.1 to 1.4
  15. PrimalPrius
    PrimalPrius Member
    138
    America
    The timing chain cover has a coolant passage that is separated from the crank case with RTV. RTV can fail. Is it likely on a Toyota built engine? Probably not likely, but all it takes is one careless worker to hurt the odds on those engines. Either way the chance is not zero and any data will underrepresent the failures for reasons I have already explained.
    On an engine that has had the timing chain or other components under the cover replaced, or a timing chain cover oil leak fixed by DYI or "shade-tree" mechanic, whether mobile, independent shop, or dealer), the odds are likely much higher (but could still be very low). Any "data" will again underrepresent the failures.
    #35 PrimalPrius, Feb 10, 2026
  16. PrimalPrius
    PrimalPrius Member
    138
    America
    I let the oil drain out for over a day, used a jack to tilt it to get more out, and installed a new filter and new oil and marked the coolant level. oil on dipstick was of course super clean.
    After just a couple of minutes of idling, oil on the dipstick already looks like weak coffee with cream, so it looks like there is a coolant to oil failure. I marked the coolant tank and there is no percieveable change in such a short time.
    It seems that if this was "cold weather condensation" like I was hoping, there would not have been enough leftover contamination inside the engine to contaminate the new oil.
    Hopefully I can find my borescope to see if any piston tops look cleaner than others.
    (The oil that has been sitting in the tall glass has not separated one bit other than a dark ring on the glass at the top).
  17. PrimalPrius
    PrimalPrius Member
    138
    America
    Just to make sure, the only possible ways for coolant to get into oil in a Gen 2 are a head gasket leak, cracked block, cracked head, or timing chain cover leak. That has to be all of them, right?
    On a Gen 2 with 300+k miles, what other things do people typically replace at the same time as the head gasket? Valve seals, timing chain set, oil pump, water pump?
    I have 318k miles and I THINK that I need to get only about 10-25k more miles out of it, What parts would you change?
    #37 PrimalPrius, Feb 14, 2026
  18. PrimalPrius
    PrimalPrius Member
    138
    America
    I suppose there is no Priuschat legend of "Johnny Headbolt" who once fixed a bad head gasket by just replacing the head bolts and doing an extra final 1/8 turn tightening round LOL
  19. PrimalPrius
    PrimalPrius Member
    138
    America
    Well this was a dumb question (I had not looked at the parts). By the time you have access to the head bolts, might as well do the job.
  20. PrimalPrius
    PrimalPrius Member
    138
    America
    I "did" the job, but I failed! The head looked good. I checked with a metal ruler and could not fit 0.003" feeler gauge under it anywhere. The block looked good, but I definitely should have paid more attention to the area around the 3 oil return paths in the rear because the coolant-to-oil (and not into cylinders nor oil-to-coolant) head gasket failure path would be from cylinder water jacket to under head gasket to oil return channel. I used a new Fel-pro head gasket and new Fel-pro bolts and used the correct tightening procedure.
    I was impressed how good the parts looked at 318,000 miles (bores, cam journals, cam lobes, cam followers, cam bearing surfaces on head and caps). I replaced the timing set with a Cloyes set. I have heard that Cloyes no longer is what it used to be, so not sure if that was even a good idea, but at 318k miles it seemed to be.
    Just in case this helps someone planning on doing the job, the head bolt socket is NOT triple-square nor XZN. It is dual hex aka bi-hex size 8mm and you need one that is longer than a typical bit. Performance Tool W83184 Extra-Long Double Hex Head Bolt Sockets for Toyota Engines, 2 Piece, 8mm and 10mm Sizes, S2 Steel worked great. $18 regular price from Walmart. It was shipped, I don't think stores carry it, but I'm not sure.
    Well, I still have the exact same problem. Coolant mixing into oil.
    I drilled out a radiator cap and used a rubber stopper, a valve stem and a couple of washers to make a device that lets me pressurize the cooling system with a bicycle pump and it held pressure overnight. Therefore I can conclude that the RTV at the water pump area in the timing chain cover is not the failure point. I also cranked the motor (engine tries to start) with the plugs out and the injectors disconnected and the coolant pressure held.
    The mixing happens only when the engine is running. Stars immediately, coolant does not need to be warm or under any pressure. But combustion forces clearly need to be present.
    So this definitely means either 1) head gasket still (probably most likely) or 2) block or head crack that only opens under combustion forces. Any other possibilities?
    (I checked the coolant that came out if the engine again and freeze protection went way past the -45F reading and the weather service says -21F was coldest we got all winter, so a freeze crack should be unlikely.)
    #40 PrimalPrius, Apr 22, 2026
