How critical to replace 12V aux battery?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by iamsaws, Dec 21, 2011.
  1. iamsaws
    iamsaws New Member
    Shelburne, VT
    I see the other threads, but in peoples experience how critical would you change the battery. ( I need ammunition to convince the wife)
    I have a 2007 prius with 62K on it. The car has randomly been dying for a year and half. once every other month, I have never found a pattern. I thought at first it was because I wasn't hitting PARK before I hit Power off, but last night I hit POWER OFF and this morning It started right up. I just got inspected and had the garage do a battery test. it came back as Weak at 10.29 volts. All other aspects tested proper.
    To me its time to replace. Is 10.29 REALLY weak or just getting weak?
    Any other 2007 owners know of any phantom draws?
    I am pretty sure its the battery.
    Thanks!any links to the best deal? I see that the yellow top Optima seems to be the best choice. I was quoted $176 from the dealership.
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    10.29 is dead. Get it replaced now, not later.
    Tom
  3. Patrick Wong
    18,200
    6,491
    The 12V battery replacement is past-due. Unless your wife likes the drama associated with calling for tow truck service or walking home, it would be a really good idea to replace the battery now.
    You may want to call the parts depts at the various Toyota dealerships in your area as 12V battery MSRP should be around $139.
  4. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    Agree, get the Optima! :cheer2:
  5. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    Time to ignore the wife, buy the Optima!
    When you don't break down, she won't even know to thank you....
  6. iamsaws
    iamsaws New Member
    Shelburne, VT
    She somehow becomes a car expert when it comes to spending money.
    Thanks!
  7. KK6PD
    4,003
    946
    118
  8. iamsaws
    iamsaws New Member
    Shelburne, VT
    thanks for the advice. @KK6Dp the link doesn't work.
    I have a 2007 with smart entry. So the battery I need is a
    Optima D51 with the conversion kit?
  9. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
  10. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
  11. KK6PD
    4,003
    946
    118
    Yeah what those guys said!!
    Link fixed to thread!
  12. iamsaws
    iamsaws New Member
    Shelburne, VT
    thanks everyone I ordered one from Elearnaid. seemed like best deal on the net.
    $6.54 cheaper than OEM from toyota
  13. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    My (perhaps confused) understanding is that barring driving your Prius under a cement mixer, badly jumpstarting the 12 volt battery is the most expensive way to break your Prius.
    Replacing the Inverter is over $1000 more than replacing the HV battery, twice as much as replacing the engine, and about the same as replacing the transaxle. All you have to do is mix up the jumper cables.
    You should always replace the 12 volt battery before it needs jumped twice.
    If you are as paranoid as I am, you will own the jumper cables I do
    http://www.amazon.com/Michelin-5100-Jumper-Cables-Protection/dp/B002RRZX06
  14. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
  15. ryogajyc
    985
    165
    Reseda, CA
  16. kenmce
    kenmce High Voltage Member
    1,544
    515
    NY
    Jimbo, what happens if the smart cables are hooked up backwards?
  17. fuzzy1
    10,335
    With those particular cables, what does "backwards" mean?
  18. jdenenberg
    jdenenberg EE Professor
    3,919
    1,917
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Not much meaning as the cables "auto-adjust" polarity. Their only problem may be that the clamps may be too big to attach to the jump point under the hood.
    JeffD
  19. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    The cables are not color coded, as there is no backwards.
    While I have you here, never jumpstart another vehicle from a Prius. (at most, charge while it is off and disconnect the Prius before attempting to start the dead vehicle)
