How difficult would it be to create a bike to reverse your electrical meter?
Discussion in 'Environmental Discussion' started by burritos, May 6, 2009.
  1. burritos
    burritos Senior Member
    4,946
    252
    So you can reverse your electric meter by using solar energy. But why stop at that? Does the electric company care where the electricity comes from? Couldn't you just as likely attach a bike where if peddled created electricity that was pumped back into the grid? How great of an invention would that be? Lose weight! Get paid!
  2. fuzzy1
    10,332
    The utility probably does not have to pay you the same rate for human or animal energy that it must pay for renewable energy. So you will be pedaling fairly hard to get paid even $0.01/hour, taking a very long time to pay off the equipment. My bikes cannot be operated and maintained that cheaply.
    If pedaling power is enough to run your meter backwards for any length of time, then you already have a super low consumption house.
  3. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    Ed Bagely rides his bike for about a half hour to toast his bread. When I think of the wee amount of electricity generated by a half hour of peddling, I'm not very motivated.
  4. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    Two things accomplished by doing that. First is you will get a LOT of exercise getting that meter to run backword. Second is learning just how unbelivably energy wasteful modern living is.
    Corwyn likes this.
  5. burritos
    4,946
    252
    More people would do it if they could do it for cash.
  6. SureValla
    SureValla Member
    590
    Shelton, CT
    I've often wondered why gym's dont do this, b/c they have lots of bikes going all the time.
    and why stop with bikes, you could convert weight machines and other stuff too to generate electricity. I think this would be a great selling point for a gym.
  7. hyo silver
    hyo silver Awaaaaay
    15,260
    1,598
    off into the sunset
    An electric load could provide some resistance against pedalling on a stationary bike, but there's not really enough power to feed back into the grid. I hunch most people would struggle to keep a light bulb lit for more than ten minutes. If you're out to lose weight or gain muscle, throw some rocks in the panniers and go find some hills to climb. :)
  8. fuzzy1
    10,332
    Not for long, once they discover that a minimum wage job pays many hundreds of times better.
  9. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    Shouldn't be too difficult to produce about 0.2 hp for a moderate workout. You won't power much like that for long, but if it does something useful with your exercise what is the harm?
    I've long wondered why anyone would pay for a gym membership AND for someone to mow their lawn? A lawn service charges the equivalent of about $50/hr...an hour that one could spend exercising the big muscle groups with a push mower to do the same job. The only time I've paid for yardwork was when I was working half a world a way from my home.
  10. patsparks
    10,664
    567
    Adelaide South Australia
  11. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    Figures like this are a good eye opener. :)
    [FONT=Verdana, Arial, Helvetica, sans-serif]1. How Much Human Energy Is Contained in One
    [/FONT]
    [FONT=Verdana, Arial, Helvetica, sans-serif] Gallon of Gas?
    [/FONT]​
    [/FONT]
    [FONT=Verdana, Arial, Helvetica, sans-serif]From Dr. David Pimentel:
    [/FONT]
    [/FONT]
    [FONT=Verdana, Arial, Helvetica, sans-serif]"That is, the 38,000 kcal in one gallon of gasoline can be transformed into 8.8 KWh, which is about 3 weeks of human work equivalent.(Human work output in agriculture = 0.1 HP, or 0.074 KW, times 120 hours.)"
    [/FONT]
    [/FONT]
    [FONT=Verdana, Arial, Helvetica, sans-serif]He, of course, is accounting for the energy lost in the process of converting the gasoline into usable energy.
    [/FONT]
    [/FONT]
    [FONT=Verdana, Arial, Helvetica, sans-serif]My calculations excluding the energy lost in the conversion process are as follows:
    [/FONT]
    [/FONT]
    [FONT=Verdana, Arial, Helvetica, sans-serif]1 Gallon of Gas = 125,000 BTUs
    [/FONT]
    [FONT=Verdana, Arial, Helvetica, sans-serif]Source: US Department of Energy
    [/FONT]
    [/FONT]
    [FONT=Verdana, Arial, Helvetica, sans-serif]3,400 BTUs = 1 KWH
    [/FONT]
    [FONT=Verdana, Arial, Helvetica, sans-serif]Source: US Department of Energy, Bonneville Power Mgt.
    [/FONT]
    [/FONT]
    [FONT=Verdana, Arial, Helvetica, sans-serif]1 Gallon of Gas = 37 KWH[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]
    [/FONT]
    [FONT=Verdana, Arial, Helvetica, sans-serif](125,000 BTUs in a gallon of gas divided by 3,400 BTUs in 1 KWH)
    [/FONT]
    [/FONT]
    [FONT=Verdana, Arial, Helvetica, sans-serif]1 Gallon of Gas = 500 hours of human work output
    [/FONT]
    [FONT=Verdana, Arial, Helvetica, sans-serif](37 KWH in 1 gallon of gas divided by human work output in agriculture of .074 KW = 500)
    [/FONT]
    [/FONT]
    [FONT=Verdana, Arial, Helvetica, sans-serif]Of course, there is some wiggle room with this number. Construction work, for instance, might yield a slightly different number. The size and physical condition of the person performing the work would also make a difference.
    [/FONT]
    [/FONT]
    [/FONT]
    [FONT=Verdana, Arial, Helvetica, sans-serif]---------------
    [/FONT]​
    [/FONT]
    [/FONT]
    [FONT=Verdana, Arial, Helvetica, sans-serif]2. How Much Human Energy Is Contained in One
    [/FONT]
    [FONT=Verdana, Arial, Helvetica, sans-serif] Barrel of Oil?
    [/FONT]​
    [/FONT]
    [FONT=Verdana, Arial, Helvetica, sans-serif]1 Barrel of Oil = 5,800,000 BTUs
    [/FONT]
    [FONT=Verdana, Arial, Helvetica, sans-serif]Source: Louisiana Oil and Gas Association
    [/FONT]
    [/FONT]
    [/FONT]
    [/FONT]
    [/FONT]
    [FONT=Verdana, Arial, Helvetica, sans-serif]1 Barrel of Oil thus contains the energy contained in 46.4 gallons of gas
    [/FONT]
    [FONT=Verdana, Arial, Helvetica, sans-serif](5,800,000 divided by 125,000 = 46.4 )
    [/FONT]
    [/FONT]
    [/FONT]
    [FONT=Verdana, Arial, Helvetica, sans-serif]Source: Calculations Done Above.
    [/FONT]
    [/FONT]
    [FONT=Verdana, Arial, Helvetica, sans-serif]1 Barrel of Oil = 23,200 Hours of Human Work Output
    [/FONT]
    [FONT=Verdana, Arial, Helvetica, sans-serif](Energy equivalent of 46.4 gallons of gas per barrel of oil x 500 hours of human work ouput per gallon of gas = 23,2000 hours)
    [/FONT]
  12. hill
    8,577
    A non- tri-athlete type bike rider generates about a quarter horsepower. My freebie conversion download software program shows a quarter horsepower to be a bit over 186 watts (per hour). So if you pedal for 30 minutes (a nice workout for most) ... well that'll give you a massive 93 watts ... enough to run your standard incandescent bulb while your peddling ... or maybe a fan to keep you from over heating so it's kind of a wash, except for the exercise. I'd rather pedal around town & enjoy the view imo :p
  13. burritos
    4,946
    252
    It would sell great in San Francisco regardless of the true return.
  14. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    Wow, that is just not very much.
    I'd been thinking about trying to build some sort of exercise bike that my kids would have to pedal while playing video games so they'd at least get some exercise while they pedalled to keep the game powered up. Clearly they couldn't produce enough juice to do that. Hmmm, plan B?
  15. Celtic Blue
    2,224
    139
    Midwest
    Small units correction...not "93 watts": 93 watt-hours = 0.093 kwh. Anyway, 186 watts is enough to run the meter very slowly backward when most stuff in the house is idle. The problem of course is that few would be able to do it for an hour and when one stops the meter would spin as normal, quickly reversing any gains. Plus there would be some efficiency loss, so 125 to 150 watts is probably more realistic. So while it would be possible to run the meter backward for a time, it is still going to be a small part of the day.
    Interestingly this is more than enough power to run my 25 cu. ft. refrigerator's compressor...but only while someone is peddling and the fridge doors are closed (incandescent bulbs inside), and the defrost is not cycling (~390 watts IIRC.)
    Next thing you know folks will be churning their own butter and hand cranking the ice cream maker... Yep, did both frequently when I was a boy. We had a wood burning cookstove (and yes, we cooked many meals on it during winter) and fireplace, and in another home a potbelly stove with a fan behind it for forced air, etc.
  16. hyo silver
    hyo silver Awaaaaay
    15,260
    1,598
    off into the sunset
    What if the game console ran off batteries, and they'd have to charge them up first? If the charge time was longer than the playing time, so much the better. :)
  17. hyo silver
    hyo silver Awaaaaay
    15,260
    1,598
    off into the sunset
    Or walking to work. How pedestrian. :)
  18. efusco
    19,891
    1,194
    Nixa, MO
    I suppose, then you'd need an inverter from the DC batteries to the AC game console...I think you'd still need something like that anyway...at minimum a capacitor to balance charges for when they were pedalling faster or slower.
    In concept it seems so simple, but in practice it quickly became clear this was something way beyond my elementary knowledge of electronics.
  19. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    It's really shocking how puny human output is... or how wasteful most applications are. I think Lance Armstrong has been measured to produce 500W of power. A horse power is 746W. Burritos... the money angle is absolutely futile. You'd make a lot more money taking your bike out and collecting aluminium along paths and roads and then selling it. You'd be saving a helluva lot more energy that way too.
  20. Celtic Blue
    2,224
    139
    Midwest
    Did that too when I was milking cows, gathering eggs, slopping the hogs, and feeding the goats. :D Did it again briefly in college when it was only about a 1 mile walk to the work study lab. But since then work has always been too far to walk.
    I was going to start riding a bike to work at times, until my office mate was hit by a car doing just that (really nasty leg break with surgeries and slow recuperation.) :( Of course, I've been hit by a car while running too...but averted any injury by jumping into the air and pivoting over the hood using my arm, landed on my feet, flipped the startled idiot driver off and kept running (I was closing in on a personal best time for that route and the adrenaline rush put me over the top.) :rockon:
