How do I get these off?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Allannde, Feb 25, 2006.
  1. Allannde
    Allannde Just a Senior
    874
    138
    Washington State
    If I can get the cover off the radiator, I am going to try a blocker until the weather warms up.
    Suggestions will be appreciated!
  2. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    Just turn them about a quarter-turn with a Phillips. The center
    will pop up, and then you can just grab it and pull the whole
    thing out of the hole in the plastic cover. Just about like the
    diagram shows, in fact.
    _H*
  3. Frank Hudon
    Frank Hudon Senior Member
    4,147
    Most of them you just push the center in about 1/8" and then the whole unit comes out. To put them back in just push the center up till it sticks up about 3/16" and push the body back in the hole.
  4. Allannde
    874
    138
    Washington State
    Thank you both!
    Allan de
  5. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    Pull them both together or you might break the lower component. Trust me I replaced three figuring that out. Pull up the center then pull both the inner and the outer together.
  6. Allannde
    874
    138
    Washington State
    (edited, Allannde)
