How do I remove the panel to access ODB?
Discussion in 'Gen 4 Prius Main Forum' started by Junepak, Jul 14, 2016.
  1. Junepak
    Junepak Junior Member
    Chicago
    Maybe I'm just blind, but I don't see how the panel below the steering wheel opens to access the ODB port to try out Carista. I played around with the little plastic piece that sticks out and tugged without luck. I could find any YouTube videos either. Can anyone provide some guidance?
  2. booke02
    booke02 Active Member
    391
    415
    Israel
    I did this yesterday without any problem.
    You shouldn't have to remove anything to access the ODB2 port. It is located above your feet, just below where all the plastic covering stops.. Get down on the floor and look up - you should see the white connector about in-line with the steering wheel. You will notice that it is installed at a funny angle.
    Junepak and pakitt like this.
  3. 'LectroFuel
    'LectroFuel Senior Member
    880
    673
    San Juan Capistrano, CA
    The port is right above the parking brake under the dashboard. It's easier with a flashlight.
  4. krmcg
    2,592
    2,392
    Whittier, CA
    There is no panel blocking the port - it is accessable
    Junepak likes this.
  5. Junepak
    Chicago
  6. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    By LAW! ;)
    Junepak likes this.
  7. Junepak
    Chicago
    Thanks everyone. So I tried the Carista app and expected to pay $20 for pro features but it appears they jacked up the pricing. It's $10 for 7 day access or $40 for a year. I feel jipped. Are there any other apps that will work with the Carista device and allow changing customizations
