How do I set the NAV clock?
Discussion in 'Gen 2 Prius Technical Discussion' started by jdjeep98, Aug 12, 2006.
  1. jdjeep98
    jdjeep98 New Member
    211
    Wilmington, DE
    I like using the ETA display on the NAV, but it's an hour off since we're on EDT, not EST.
    I'm sure there's some way to adjust the clock or time zone, but I can't find it.
    My wife's Sienna reads correctly.
    (By the way, the 2006 Sienna has the same NAV as my 2006 Prius, but the screen lockout bypass works on the Sienna!)
  2. jdjeep98
    jdjeep98 New Member
    211
    Wilmington, DE
    So... nobody knows, huh? Wow! :eek:
    In fact, I figured it out myself! B) I'm not going to tell *you*, though... :p
    So there! :p
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    This has been covered many times in other posts. You don't set the time for the NAV system, as it is derived from the GPS. You can change the daylight savings settings under setup.
    Tom
  4. Charles Suitt
    Charles Suitt Senior Member
    1,637
    17
    Dallas TX
    :unsure: QUOTE: "I'm not going to tell *you*, though..."
    jdjeep98 is definitely *NOT* in the spirit of PriusChat. Most PriusChaters are helpful. Hope this person doesn't find himself needing information again.
