How do you open the tailgate with engine running?
Discussion in 'Gen 2 Prius Technical Discussion' started by jackovalltrades, Mar 10, 2007.
  1. jackovalltrades
    jackovalltrades New Member
    45
    I was in my month old Prius (package #5) today and my daughter decided she wanted a drink out of the grocery bags in the back. I had the keys in my pocket, not in dash. I pulled over in a safe area and she walked out to open the hatch. It wouldn't open up even in Park, until I hit the Power button and turned the car off first. Is this the way it's supposed to behave?
  2. Tideland Prius
    16,401
    First, it's a hatch :p
    second, you'll have to unlock it first. When you press the LOCK side of the power door locks, it locks the hatch as well.
  3. Bear68
    Bear68 Member
    373
    72
    West Palm Beach, FLA
    <div class='quotetop'>QUOTE(jackovalltrades @ Mar 10 2007, 02:28 PM) [snapback]403440[/snapback]</div>
    Did you try hitting the "unlock" swith on the driver's master switch? The rear hatch is electrically activated and will not respond if the hatch is locked.
  4. daveleeprius
    daveleeprius Heh heh heh you think so?
    429
    Seattle
    <div class='quotetop'>QUOTE(Tideland Prius @ Mar 10 2007, 02:30 PM) [snapback]403442[/snapback]</div>
    Yep, just hit the unlock all doors button on your armrest and all doors will unlock, including the hatch. On my base 07, then all I have to do is press the button under the latch and lift up. Open!
    Dave
  5. jackovalltrades
    45
    <div class='quotetop'>QUOTE(DaveLeePrius @ Mar 10 2007, 02:32 PM) [snapback]403445[/snapback]</div>
    I thought it was unlocked since the only thing that I could see different then loading earlier is the fact that the car was running in Park. But even if it was locked with my keys in my pocket out there trying to open it, shouldn't it unlock and open?
    Thanks for all the quick responses!
  6. Tom_06
    Tom_06 Active Member
    609
    142
    Newark, Delaware, USA
    I had never noticed this before. You are absolutely correct. If I am in "Ready" mode and have the doors locked, when I exit the driver's door with the smart key in my pocket the rear hatch won't unlock. I can unlock it in Ready mode by use of the driver's door unlock button. Or I have to turn the car off for the rear hatch to unlock via smart key. This is on a 2006.
    - Tom
  7. jackovalltrades
    45
    <div class='quotetop'>QUOTE(Tom_06 @ Mar 10 2007, 03:15 PM) [snapback]403463[/snapback]</div>
    Did you just go out and try it? :p
    I guess I just assumed since the smartkey was in my pocket that it would open up no matter, on or off.
  8. Tom_06
    609
    142
    <div class='quotetop'>QUOTE(jackovalltrades @ Mar 10 2007, 03:24 PM) [snapback]403465[/snapback]</div>
    Yup, the easiest way to find out is go out and try it. The car was in the garage where I couldn't try the passenger door to see if it acts the same way. I'll try that the next time I get the car out of the garage. I'm sure some engineer at Toyota had a reason for doing this, but it escapes me.
    - Tom
  9. Tideland Prius
    16,401
    Well it's working on the same principle as a regular car with a key. Your key would still be in the ignition if the car was running and your remote features (lock/unlock/trunk release) on the regular car won't work.
  10. jackovalltrades
    45
    <div class='quotetop'>QUOTE(Tideland Prius @ Mar 11 2007, 03:40 PM) [snapback]403864[/snapback]</div>
    To an extent yes however most cars have some sort of trunk release button or lever. Weather the vehicle is running or not those button release the hatch. Since I'm still new to the Prius when my hatch wouldn't open, out of habit I reached down beside my seath to pull the release and noticed it wasn't there. Nevertheless it's not a big deal. I'm just amazed that I'm averaging 47-48 miles/gallon compared to my old Mazda which was in the upper 20's.
  11. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    I can confirm that you CAN open the hatch with the car in Ready. I've crossed into the U.S. numerous times, either through Emerson or at Warroad, MN, and when I stop at the customs I put the car in Park and apply the parking brake. They never ask me to shut off the car, because when I creep up the motor is off anyway.
    The DHS folks have no problem reaching for the release and popping the hatch. Though for some reason most of them are so damn curious about my Prius I easily lose 10 minutes patiently opening the hood and showing them the motor. Well, as long as they're happy, whatever ...
  12. Tom_06
    609
    142
    <div class='quotetop'>QUOTE(Tideland Prius @ Mar 11 2007, 04:40 PM) [snapback]403864[/snapback]</div>
    Not true for Audi (at least the A6). But you did say regular car :)
    - Tom
  13. Marlin
    Marlin New Member
    1,407
    Bucks County, PA
    <div class='quotetop'>QUOTE(jackovalltrades @ Mar 10 2007, 05:47 PM) [snapback]403450[/snapback]</div>
    If you were driving through a bad section of the city with your doors locked, would you want someone to be able to just walk up to your car, grab the door handle, unlock the car and climb in? So no, if the car is on, then it shouldn't automatically unlock when someone grabs one of the smart key door handles. That is the only proper behavior for it to have.
  14. Tideland Prius
    16,401
    <div class='quotetop'>QUOTE(jackovalltrades @ Mar 11 2007, 07:21 PM) [snapback]403973[/snapback]</div>
    be careful not to pull the fuel filler door release!
  15. Tom_06
    609
    142
    <div class='quotetop'>QUOTE(Marlin @ Mar 12 2007, 03:29 PM) [snapback]404299[/snapback]</div>
    Why would they have a smart key in their pocket that works for my car? Sorry, I don't buy it. If I have the key (and the car knows inside from outside for key location), there is no reason to keep me from unlocking the back end. After all, it is supposed to be a "smart" key.
    - Tom
  16. jackovalltrades
    45
    <div class='quotetop'>QUOTE(Tom_06 @ Mar 13 2007, 06:16 AM) [snapback]404754[/snapback]</div>
    You took the words right out of my mouth.
  17. rkoska
    rkoska New Member
    16
    <div class='quotetop'>QUOTE(jackovalltrades @ Mar 10 2007, 04:28 PM) [snapback]403440[/snapback]</div>
    Yes it is. That is part of the security system, when you are in the car you would not want some one with out a key to be able to open the trunk. you have to have the key fob close to the trunk. you could hand the key fob to your daughter and she would be able to open the rear hatch.
  18. jackovalltrades
    45
    <div class='quotetop'>QUOTE(Dick K @ Mar 13 2007, 09:32 AM) [snapback]404800[/snapback]</div>
    That's just it, it doesn't work that way. She tried to open it up and couldn't so I climbed out with the FOB in hand and it still wouldn't open up. This was with the car running (READY mode).
  19. MegansPrius
    MegansPrius GoogleMeister, AKA bongokitty
    2,437
    27
    Chicago, IL
    <div class='quotetop'>QUOTE(jackovalltrades @ Mar 13 2007, 10:45 AM) [snapback]404807[/snapback]</div>
    Again, when you have an unlock button on the driver's armrest, I don't understand the difficulty. Just hit that button.
  20. jackovalltrades
    45
    <div class='quotetop'>QUOTE(MegansPrius @ Mar 13 2007, 10:41 AM) [snapback]404841[/snapback]</div>
    Will do... wanted to make sure it wasn't just me.
    Thanks!
