How do you tap the dome lights in a Prius C?
Discussion in 'Prius c Accessories and Modifications' started by col127, Mar 29, 2013.
  1. col127
    col127 Member
    345
    Illinois
    Quick question - how do you tap the dome lights in a Prius C? Any writeups/instructions anywhere? Wanted to install some footwell lights and would to tap the dome lights to make sure they turn on/off as the rest of the lights in the car. :) Thanks!
  2. col127
    col127 Member
    345
    Illinois
    Any help would be greatly appreciated!
  3. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    i think in the cargo area, on the left panel, you will have access to a wire harness. in that harness there will be wires that are connected to the dome. since you have the c3, the wires are used for the cargo area light. you can always tap into that. or if you cant or dont want that, then you can simply tap into the front dome light and run wire from the headliner to the side and then to the footwell
  4. col127
    col127 Member
    345
    Illinois
    do you know wires to tap in the front dome light for that? like specifically (what colour, etc.)? same for the cargo area? thanks for your help!
  5. kingnba6
    1,018
    242
    NY
    sorry i dont know exactly what color as i have not done this mod yet. im sure somebody else will be able to chime in
  6. kingnba6
    1,018
    242
    NY
  7. LordsII
    LordsII New Member
    16
    To my understanding, the cargo connector on the back isn't 100% functioning as dome lights which can be manually turned on or just shutting off. In fact, it just turns on when hatch door opens or off when door closes.
