How Hybrid Vehicles Work
Discussion in 'Gen 2 Prius Technical Discussion' started by Tideland Prius, Oct 15, 2007.
  1. Tideland Prius
    16,402
    Don't know whether to post this here or in the News Forum. It's from Toyota Motor Sales, USA.
    October 1, 2007 – Torrance, CA - Mention "hybrid" to people not familiar with current trends in automotive technology and the first thoughts that come to mind might well be of some sort of genetically engineered corn that yields more bushels per acre. But in vehicular terms, hybrid refers to a powertrain that combines two different methods of propulsion, each augmenting the other in a way that enhances the strengths and minimizes the shortcomings of each.
    In very simple terms, a hybrid powertrain, as used today in a variety of applications, utilizes an engine that burns fossil fuel, combined with an electrical system made up of a motor, generator and battery. Depending upon the individual system, the gasoline engine may be able to drive the vehicle by itself, or it may drive the electrical system only (which in turn will actually drive the vehicle). Alternatively, the electrical system might be able to drive the vehicle by itself, or both systems may be able to work together to varying degrees.
    The current automotive internal combustion piston engine has been developed to an impressively high state of refinement. It delivers power levels, meets emissions and fuel economy requirements, while satisfying customer demands for smoothness, quietness, reliability and cost that would have been considered unthinkable just a few years ago. Plus there's a basic problem that faces almost every vehicle on the road: Each of them has an engine that is, most of the time, larger than it needs to be.
    A typical four-door sedan may have an engine rated at, say, 200 horsepower. That vehicle requires the full 200 horsepower very little of the time, normally only for quick passing maneuvers or while climbing steep hills. The vast majority of the time the engine is operating at a small fraction of its fully rated output. Once the sedan is accelerated up to freeway speed, as little as 20 or 30 horsepower may be needed to keep it moving. In fact, many drivers may seldom, if ever, call upon the full power output of the engines under their cars' hoods. What people really need is 200 horsepower every once in a while, maybe 100 horsepower from time to time, and about 30 or 40 horsepower most of the time. The fuel economy and emissions benefits of such a powertrain should be obvious.
    Could an electric car do that? The pure electric vehicle is quiet and smooth and generates none of the smog-forming emissions currently regulated for vehicles with gasoline engines. But after over a century of research, the pure electric car has the same handicap it had 100 years ago—limited range. Exacerbating the limited range are a couple of other major concerns: While a car with a gasoline engine can be completely refueled in a few minutes, literally hours are required to charge up an electric car. And while the gasoline vehicle runs just as well on the last drop of fuel as on the first, the further an electric car goes, the more its performance drops—because the battery is discharging—so the last of its "range" is at a pace that becomes increasingly slow.
    In simple terms, the electric car doesn't have enough when it's needed; the conventional gasoline car has too much when it's not needed. The hybrid helps solve both those issues.
    The road vehicle, because it has to deal with the widely varying speeds and conditions of traffic, has a more difficult duty cycle. Starts, stops, short trips, family vacations, stuck in traffic jams—all these create fuel economy and emissions problems. To deal with this, the typical automotive hybrid system is comprised of a relatively small gasoline engine, which drives either the wheels directly, or a generator, or both. There's also an electric motor, which drives the wheels, sometimes alone, or sometimes in concert with the engine. A battery pack supplies the electric motor, and a generator makes the electrical power to recharge the battery. Sophisticated electronic controls watch over all these parts. As software is to computers, it's the controls that make the whole package work in harmony.
    Hybrid Synergy Drive
    The most sophisticated production hybrid system is Toyota's Hybrid Synergy Drive (HSD). HSD is featured in the second-generation Toyota Prius, which launched in 2003 as a 2004 model year vehicle; the Toyota Highlander Hybrid, which launched in 2005 as a 2006 model year vehicle, and the Camry Hybrid, which made its debut in 2006 as a 2007 model. Camry Hybrid also is the first Toyota hybrid assembled in the United States.
    Hybrid Synergy Drive in the Prius and in the Camry Hybrid
    With its Hybrid Synergy Drive, the Prius provides a case study of how these components work together. The Prius has a 1.5-liter, four-cylinder gasoline engine of 76 horsepower. With both the gas engine and electric motor, the Prius has a combined horsepower of 110. The gasoline engine is linked to the drive wheels and a generator directly via a unique transmission and, whenever it's running, it can also drive a generator that helps keep the battery charged. The generator supplies electrical power to the electric motor or charges the battery, as needed.
    Most of the time when the Prius comes to a stop, the gasoline engine is shut down. This means no unnecessary idling or wasted fuel while stuck in traffic or at stop signs. When accelerating from rest at a normal pace, and up to mid-range speeds, the Prius is powered by the electric motor, which is fed by the battery. As the battery charge is depleted, the gasoline engine responds by powering the electric generator, which recharges the battery. Once up to speed and driving under normal conditions, the engine runs with its power split: part of this power goes to the generator, which in turn supplies the electric motor, and part drives the wheels. The distribution of these two power streams from the engine is continuously controlled to maintain the most efficient equilibrium. If the need arises for sudden acceleration, such as a highway passing maneuver or a quicker start from rest, both the gasoline engine and the electric motor drive the wheels.
    During braking and other types of deceleration, kinetic energy normally lost is converted into electrical energy, which is then stored in the battery. The state of charge of the battery is constantly monitored, and whenever needed the generator is powered by the gasoline engine to provide the necessary charge.
    The result is a vehicle powered by a gasoline engine, in that it's the engine that drives the wheels or drives the generator that supplies (either directly or through the battery) the electric motor. But the engine is only as big as it needs to be. It isn't even running all the time, and if sudden acceleration is called for, both the gasoline engine and electric motor share the load. The engine in hybrid vehicles like the Prius run exclusively on gasoline, while the electrical portion of the power system never needs to be plugged in for a charge. There's no cord and no waiting. You can fill up at any normal gas station anywhere.
    The Camry Hybrid system differs slightly from Prius. Camry Hybrid's Hybrid Synergy Drive produces a combined 187 horsepower.
    The first part of Hybrid Synergy Drive for Camry consists of a 147-hp, 2.4-liter four-cylinder Atkinson-cycle engine coupled to an electronically controlled planetary-gear continuously-variable transmission. The second part combines a small, high-torque 40-hp electric motor, an ultra-small inverter with a specially designed compact battery, and a transaxle to seamlessly combine power from the electric motor and gasoline engine.
    Because there are situations in which the gas engine in a Toyota hybrid completely shuts down, air conditioning and power steering systems are driven electrically. In addition, an "ECO" button helps limit energy consumption by the climate control system and under certain conditions can help improve fuel economy.
    Highlander Hybrid – A More Powerful Hybrid Synergy Drive
    The Highlander Hybrid is powered by Toyota's Hybrid Synergy Drive powertrain specifically developed to meet the load-carrying requirements and performance expectations of mid-size sport-utility vehicle (SUV) buyers. Its all-new high-speed electric motor operates at twice the speed and delivers more than twice the power as the motor used in the Prius, producing 167 horsepower alone. The gas and electric motors combined produce 270 peak horsepower. The Highlander Hybrid has a standard towing capacity of 3,500 pounds.
    There are three motor-generators employed in the 4WD-i Highlander Hybrid. Internally referred to as MG1, MG2 and MGR for the rear electric motor in the 4WD-i, each has a specific function and each does double duty as both drive motor and generator (although MG1 is a starter and provides no motive force). The engine-driven generator (MG1) can charge the battery pack, which powers other electric motors as needed, while the front electric-driver motor (MG2) and rear electric motor (MGR) can charge the battery pack through regenerative braking.
    Power from the gas engine and MG2 is distributed to the drive wheels via a planetary gear-type continuously variable transmission, which eliminates specific gear ratios. Two planetary gear units are used in the system. The Power-Split unit divides the engine's drive force two ways: one to drive the wheels and the other to drive MG1 so it may function as a generator. The Motor Speed Reduction unit reduces the speed of MG2 and increases its drive torque, significantly boosting acceleration performance.
    In addition to its motor-generator duties, the crucial MG1 adds two functions: one as a starter motor for the gas engine; and two, by regulating the amount of electrical power it generates (which varies its RPM), MG1 controls the output speed of the transaxle through the planetary gear set—without clutches or viscous couplings.
    This is one of the key elements of the hybrid powertrain and the reason why Highlander Hybrid eliminates the "shift shock" that can typically be felt as even the most refined modern automatic transmissions change gears.
    The innovative electric 4WD-i system employs a separate 50-kW electric motor (MGR) at the rear that provides up to 96 lb.-ft. of additional drive torque as required. The system electronically varies front and rear torque distribution depending on driving conditions.
    The Toyota hybrid technology also allows extended electric-mode operation during low speed or stop-and-go driving conditions. The permanent-magnet front electric drive motor (MG2) produces peak torque from zero-to-1,500 RPM, giving the Highlander Hybrid powerful and instantaneous response that will be especially felt and appreciated in low- and mid-speed performance and in merging and passing maneuvers.
    Hybrid Synergy Drive Benefits
    The real benefits, to both the owner and driver of Toyota's hybrid vehicles, are the utility and numbers. The Prius is roomy enough inside to meet the Environmental Protection Agency's (EPA) midsize category, while the Highlander Hybrid provides the versatility of a mid-size SUV. The Prius accelerates from 0 to 60 mph in about 10 seconds, roughly equal to a four-cylinder gasoline-engine Toyota Camry. Highlander Hybrid 4WD models have an acceleration time of 7.3 seconds for 0 to 60 mph. Prius has a combined EPA mileage estimate of 46 mpg, giving it the best EPA rating of any vehicle sold in America today. Highlander Hybrid's combined city/highway estimated EPA fuel efficiency rating of 26 mpg is more than double that of most V8 powered SUVs. Camry Hybrid's EPA-estimated ratings are 33 mpg city/34 mpg highway.
    Both the Prius and Highlander Hybrid have been certified as SULEV, or Super Ultra Low Emission Vehicle and the 2008 Camry Hybrid is certified as an Advanced Technology Partial Zero Emissions Vehicle (AT-PZEV). A decade ago, these combinations were unimaginable.
    Source: Toyota Pressroom
  2. D0li0
    D0li0 New Member
    118
    Seattle, Wa
    All in all a fairly good overall explanation of Hybrids, I only have a few problems with it...
    <div class='quotetop'>QUOTE(Tideland Prius @ Oct 14 2007, 11:30 PM) [snapback]525766[/snapback]</div>
    "same handicap it had 100 years ago-limited range"
    Turns out that 100 years ago an EV had more range than a typical ICE vehicle because the ICE vehicle not unlike a horse of the time needed to stop for water in order to cool down. They didn't have radiators nor electric starters and were quite literally reserved for "motor head" type people, Most folks preferred there electrics. (EV History)
    "literally hours are required to charge up an ev"
    This is no fault of the Battery in an EV nor a true technical limitation of EV's. To demonstrate that an EV could be charged in a very short time. Someone with a Prius and the EV-Mode button go out and deplete the battery till the engine starts. Now stop and with the car in "D" press both the brake and accelerator to the floor. The car will enter a forced recharge mode in which it moves up to 80Amps into the battery at ~240v just shy of 20kW. This is far more power than any appliance in your home and probably represents the majority of your grid feed. Notice that your battery will be full in less than five minutes. Now battery technology scales nicely, you could do with with any EV having similarly high rate batteries as those in the Prius. Vehicles like the 10 year old Chevy EV1(gen2) or the Toyota RAV4-EV would take slightly longer, but could be recharged in well under an hour if an adequate grid supply were available. The fact of the matter is that this simply isn't an issue when your car spends "literally hours" in your garage every evening. (GM EV1) (Toyota RAV4 EV)
    "an EV's pace becomes increasingly slow"
    Ask the Tesla and tzero fellas if that is the case, Now I think they are just making things up. No properly designed production EV would ever "slow down" as the battery is discharged. Oh ya, both of these ev's have exotic sports car performance and well over 200 miles of range per charge. The tzero even has a trailer that turns it into a PHEV with "unlimited" gas range. (Tesla) (tzero)
    "never needs to be plugged in for a charge"
    They still don't get it, what they mean to say is that "you never get to plug it in" because you would realize how beneficial it is to your fuel economy and pocket book, eventually you'd want an all electric"...
    from sfeva.org
    "best EPA rating of any vehicle sold in America today"
    Now that the Honda Insight is no longer being sold...
    All in all not a bad explanation of how Hybrids and theirs in particular works, but they are still passing out false information as if it were fact simply to make themselves feel a little better about no longer producing EV's like their RAV4-EV or allowing us to plug in our gas hybrids...
