How long can dying battery go on?
Discussion in 'Generation 1 Prius Discussion' started by Allan, Jul 14, 2010.
  1. Allan
    Allan New Member
    Oakland, CA
    2002 Prius
    Once a Gen I battery starts showing signs of dying (overcharging when should be in "sleep' mode, MPH loss, loss of power, etc.), what is the range for how long the battery might go before all the lights go on indicating "now it's really dying"? Thanks for your expertise!
    Allan
  2. TexomaEV
    TexomaEV Member
    154
    Bonham, Texas
    2001 Prius
    I can tell you that when it starts throwing codes, regarding battery imbalance, and low voltages on modules, you'll be pulling to the side of the roadway quite often. You'll have to put it in park, and restart the car, to go again. Did this on a 700+ round trip, and it was quite a pain. Upside, I never had time to get tired, and fall asleep at the wheel.
    But, here's the kicker (SO FAR). The pack had two dead (0.0vdc) modules when it was purchased. Replaced those with some I thought were good, they couldn't recharge/hold above 7.2vdc, so we attempted to rehydrate, helped, but not good enough, still generated error codes. Then we replaced those modules with some we verified would hold resting voltage at above 7.2vdc, and so far, the car is working very nicely, both power and charge seem to be normal.
    Hopefully, you could replace some modules, and get a few more miles out of your original pack, if you desire to go to the trouble and fun of working on the HV Pack yourself.
  3. Allan
    Allan New Member
    Oakland, CA
    2002 Prius
    Thanks for letting me know about your success (I'm not confident to do it myself). My car began showing signs of battery wear (big mileage drop, recharging when stopped, power loss, etc.) before getting any kind of constant codes. Though did get the triangle of death, etc. 20,000 miles ago, after I had symptoms of a bad battery, and they replaced the Engine Control Module. I'm curious to know if a slight leak can increase over a period of 20,000 miles to finally cause it's demise.
    Allan
  4. JimboPalmer
    12,470
    6,875
    Greenwood MS USA
  5. TexomaEV
    TexomaEV Member
    154
    Bonham, Texas
    2001 Prius
    Our pack buss bars were seriously corroded. Cleaned w/wire brush and coated with a protectant to keep that from happening again so easily. You do however need to make sure your low voltage battery is good. Most parts stores will load test it for free, and while there have them test for the codes while there are still errors in memory.
