How much mpg would be affected if i change the rim size to 16x7
Discussion in 'Prius c Accessories and Modifications' started by ranz, Aug 1, 2012.
  1. ranz
    ranz New Member
    does anyone here have change their stock 15x5 to 16x7?
    i want to know How much mpg would be affected if i change the rim size to 16x7.
    tire recommendations as well would be appriciated.
    Thanks in advance!!!
  2. Mik1
    Mik1 Member
    333
    Houston, TX
    Good question. There was a lot discussion about it, and many people have said that 16" rims deliver lower mpg compared to 15" rims. I have original 16" rims - can't complain about my mpg. My morning 14 miles commute without AC is about 63-67 mpg. The same route on the way back during 100F day with ac set on 78F auto gives me between 53-57 mpg. I have nothing to compare with, but as I mention above, I can't complain about my mpg on 16" rims.
  3. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    It depends on which tires you choose. Going from a LRR 15" tire to a non-LRR 16" could drop you quite a bit (4mpg+). Since there are no LRR alternatives in the OE 16" size it makes this a tough choice.
  4. Ryephile
    Ryephile The Technophile
    418
    151
    24
    Metro Detroit
    You'd have to go with either the Yokohama Avid Ascend in 185/55-16, or something in a 195/55-16 or 205/50-16 in LRR to not noticeably affect FE... assuming going that wide won't also markedly impact economy.
  5. ranz
    ranz New Member
    thanks for the replies, its weird that i dont get 60 mpg even on stock 15, i always end up roughly around 45mpg to 47mpg, and i have my eco mode on, and im really light on the throttle,is something wrong? thats the whole reason why i ask if its going to drop the mpg,cause i dont want it to get worse, again thanks for the replies
  6. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    Why do you expect to get 60mpg? Maybe your commute length and other driving conditions are not conducive to high fuel efficiency. High speed driving can also tank mileage as can heavy use of A/C. :)
  7. Mik1
    Mik1 Member
    333
    Houston, TX
    Ranz, many factors are involved into your total mpg. F8L gave a very good example. Your average is different to some other people average, but it does not necessarily means that there is something wrong with your car. Short trips, higher speed limits, hills, ac lower your mpg. I live in Houston, and we don't have any significant hills overhere. I can tolerate 82F during my early morning commute to work in order to be more fuel efficient, and I keep my ac at 78 on the way back. I could take highways on my way to work, but I don't. First of all my commute will be a little bit more than a mile longer, second of all my back roads are giving me the speed limits comfortable for FE. The speed limits on my way are between 30 to 45 mph.
  8. ranz
    ranz New Member
  9. ranz
    ranz New Member
    thats a good point f8l. i do drive 63miles back and forth w/ac. ill try to turn it off this morning commute.as far as my rim question, mik1 are oe 16"rims are they 16x7's? ill post some pics and mpg's soon as i get them,thanks guys!
  10. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    Long distance commutes are good for mpg if you can keep your speed at 60mph or lower. Keep the A/C off or set the temp to 78F or higher to minimize the mpg hit. Also try and glide to every stop and on every offramp. With a few tweaks to your driving style I bet you could get killer fuel economy if you have a long commute like mine (49miles one-way).
  11. Mik1
    Mik1 Member
    333
    Houston, TX
    They are either 7 or 7.5, I need to check on that, but I am more leaning towards 7. The tires size is 195/50R16
  12. WD0AFQ
    WD0AFQ Active Member
    619
    152
    Dexter, Mo.
    I can't answer your question but we are switching to 15x7 wheels in the morning.
    dan
