How much oil to add…
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by WilDavis, Aug 6, 2018.
  1. WilDavis
    WilDavis Senior Member
    2,493
    2,154
    49
    …to my 2009 Gen II Prius to take the oil level on the dip-stick from the lowest mark to the highest mark? I'm sure this has been answered many times before, but I checked the oil level in the Chuggy Pig today, and the level was about ¼" above the lowest mark. About 7,000 miles since the last oil change, perhaps it's time for the next? Thanks in advance! - Wil
  2. frankv64
    frankv64 Junior Member
    23
    Colonia NJ
    Half a quart or a tad more should do it
  3. Raytheeagle
    Raytheeagle Senior Member
    11,262
    15,506
    Bay Area, California
    2019 Prius Prime
    Distance between the dots is about 1.5 quarts.
    Where did you leave it when you changed the oil?
  4. Mendel Leisk
    40,242
    It also measures about 1.5", which makes the math real easy. (y)
    Raytheeagle likes this.
  5. Raytheeagle
    11,262
    15,506
    2019 Prius Prime
    I like easy:).
    They must have had us simpletons in mind for that design(y).
  6. Patrick Wong
    18,200
    6,490
    I use full synthetic oil and change the oil at around 7,000 miles. If you are not ready to do a change yet, I would suggest adding 1 quart, then see where the level is. You will probably need another 0.2 quart to bring it up to the full dimple. The difference between the two dimples is supposed to be 1.6 US quarts, but I haven't had occasion to test that.
  7. WilDavis
    2,493
    2,154
    49
    Thank you, @Patrick Wong, good call! Hit the nail right on the head! 1 quart brought the level right up to the top mark! :notworthy::notworthy:;)
    Patrick Wong likes this.
