How Prius detects a passenger/driver?
Discussion in 'Gen 2 Prius Main Forum' started by priusist, Jan 3, 2005.
  1. priusist
    priusist New Member
    27
    Fremont, CA
    The front panel on my 05 salsa red shows passenger/driver light if either one has not handled the seat belt properly. I and my wife were figuring how Prius knows this. We finally concluded that Prius can sense the weight on the seat to proceed to check the seat belt buckle. This is because my wife once put our 3yr (25lb) on the passenger seat for a short errand (50ft). (I know this is not permitted to have a kid at the front seat but it was for an urgency.) In that case, she did not see the passenger light even my daughter was too small to be fasten with the belt.
    Not sure if this is true.
  2. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    Yeah, it's a weight sensor. You can have your wife lift herself off the seat without her seatbelt fastened and the light will turn off. Just use the arm rests to lift straight up.
  3. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    yep weight sensor and a sensor that monitors the seat belt. watch the drivers side icon for seatbelt goes off soon as you click the belt on.
  4. Prius Maximus
    Prius Maximus Senior Member
    954
    806
    Northeastern IL
    I'll chime in and agree on the weight sensor. My lunch box sometimes turns on the warning.
  5. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    lunch box??
    you may need to go on a diet!!
  6. kkister1492
    kkister1492 New Member
    355
    Fremont, CA
    My purse will sometimes set it off when it leans back into the seat back. On the seat alone will not do it.
  7. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    ahhh!!
    very astute observation, so maybe just leaning forward might do the trick?
  8. Prius Maximus
    954
    806
    Northeastern IL
    That's the ticket! I noticed the warning when the lunch box pressed against the back of the seat. When I moved it forward, the warning turned off. The sensor must be in the lumbar area of the seat back, not the butt part.
  9. priusist
    priusist New Member
    27
    Fremont, CA
    Thanks for the replies. Now I admire the cutting edge technologies on the Prius even more.
    Any other car has this similar feature?
  10. montolchik
    montolchik New Member
    33
    Mentor, Ohio
    My roommate's Toyota mr2 has the technology. I did the arm rest lifting thing one day when I sat in the passender seat. I believe his mr2 is a 2001.
  11. knowledgeseeker
    knowledgeseeker New Member
    57
    Walnut Creek, CA
    I just had seat heaters and lumbar supports added by a local upholstery shop. The lumbars go under the foam, the heaters over it, touching the fabric (Alcantara). The installer, who has some experience in these matters, was unwilling to install a heater on the seat bottom portion of the passenger seat (he did install one on the backrest portion). The driver's side has both bottom and back heaters. He said that on the passenger side the occupancy sensor was right under the fabric, and he did not want to do anything that might compromise the airbag behavior. In any event the two seats were different.
  12. Tideland Prius
    16,406
    Is it on the lumbar support? I thought was in the seat bottom like knowledgeseeker says. It's the same on the Camry
  13. flareak
    flareak Fleet Captain
    1,016
    St Louis, MO
    I felt it today. its about 3 inches behind the middle line of the seat. Its also about 4 inches from the left bulgey thingy. you can actually feel the sensor and it doesn't take much to set it off. It is not on the lumbar
  14. Tideland Prius
    16,406
    okay, will check it out tomorrow
  15. Prius Maximus
    954
    806
    Northeastern IL
    Sorry, I checked it out today. It's not on the lumbar. When I moved my lunchbox forward I thought it released pressure from the lumbar, but I must have moved it off the sensor in the seat. And it's actually not the weight of my lunchbox, I usually carry other stuff on the passenger seat. It seems to take about 5-10 pounds to activate, but I haven't tested the weight yet.
  16. Tideland Prius
    16,406
    well I know pressing lightly with just your hand will trigger the sensor
  17. flareak
    1,016
    St Louis, MO
    you can feel it! its less than a centimeter in diameter but you can feel a buldge if you look for it
  18. techogurl
    techogurl New Member
    226
    Fayetteville, AR
    <div class='quotetop'>QUOTE(priusist\";p=\"61210)</div>
    My '01 Rav4 had this feature. The sensor was weight activated. I believe that it was located in the actual seat portion as I would keep different things in the front seat and the indicator was on whether or not the item was touching the back rest.
    Where exactly are the ones in the Prius? I have yet to actually feel for them...but they seem less sensitive than those that I had in the Rav. Perhaps due to placement. Hmm...
  19. Frank Hudon
    Frank Hudon Senior Member
    4,147
    Toyota has had the seat switch since the 70's on the electric forklifts not the ICE ones. If it's broken or no weight on it, no go. My 1993 Toyota T100 pickup had it also on the passanger seat, put a briefcase on it and the seatbelt light came on. it's about 2 1/2" square and is two pieces of plastic cupped and the contact is just 2 pieces of brass sheet one on each piece of plastic, push it together to make contact. Inserted in the foam seat bolster.
  20. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    something as light as a bottle of water can set if off. Mine does it all the time. If i have more than 1 bottle in the seat, it usualy stays lit.
