How to clear the check engine light
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by gwcisme, May 22, 2007.
  1. gwcisme
    gwcisme New Member
    Does anyone know if we can clear the check engine light without having to go to a dealer or mechanic. The darn thing came on when I ran out of gas!
  2. Swanny1172
    Swanny1172 New Member
    666
    You can buy an OBD II tester on eBay for about $30.00. This will allow you to scan any fault codes and also clear them. The other (cheaper) option is to just take it to your nearest AutoZone, Pep Boys, etc. and have them scan and reset it for you.
  3. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    Four reboots. If a problem isn't still present, that should do it.
    _H*
