How to fix the sound of “water sloshingâ€
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Sufferin' Prius Envy, Aug 2, 2006.
  1. Sufferin' Prius Envy
    Sufferin' Prius Envy Platinum Member
    3,998
    This morning the fresh air being vented into the car wasn't so . . . “fresh†smelling . . . kind of moldy.
    So I investigated.
    The holes for the windshield drain were clogged by a smelly mess of biological sludge.
    Checking the passenger side is very easy. The only tool needed is a finger to pry off the cover shown below.
    [attachmentid=4318]
    [attachmentid=4319]
    Unfortunately I didn't take a “before†picture to show the ½ inch plus buildup clogging the drain hole – but if your drain doesn't look like this . . . time to get-a-cleanin'. I used an old paint brush and a garden hose.
    [attachmentid=4320]
    The driver side is not as easy!, but these are the steps I took:
    Tools I used – 14mm socket, straight slot screw driver, flashlight, old paint brush (1.5 inch and preferably with a long handle), garden hose.
    1) Remove driver's windshield wiper arm. Easy to do with a straight slot to remove the plastic cover and a 14mm socket.
    [attachmentid=4321]
    2) Just forward of the driver side hood hinge is this little fastener. Push in the center button (as shown), then reach under and push fastener out – be careful not to lose it in the engine area.
    [attachmentid=4322]
    [attachmentid=4323]
    3) There are a couple of tab clips (part of the cover itself) located on the front edge of the cover. Push the tabs back and gently lift the cover to expose the drain (or bio sludge :eek: ).
    [attachmentid=4324]
    4) I propped up the cover near the hinge side with another paint brush to make for easy access while cleaning.
    [attachmentid=4325]
    5) Before and after pics. (the shiny horizontal bar is the windshield wiper linking arm.)
    [attachmentid=4326]
    [attachmentid=4327]
    Be careful flushing out the area as you have the cover off and there are also fresh air vent holes which I don't think would be a good idea to allow water into. I removed the prop paint brush several times to do a good flush job.
    The drains drain just behind the front wheels, and should be able to flow like this.
    [attachmentid=4328]
    Several other PriusChat strings mentioning water sounds:
    http://priuschat.com/index.php?showtopic=20878&hl=
    http://priuschat.com/index.php?showtopic=20883&hl=
    http://priuschat.com/index.php?showtopic=8171&hl=
    http://priuschat.com/index.php?showtopic=5576&hl=
    http://priuschat.com/index.php?showtopic=21170&hl=
  2. tumbleweed
    tumbleweed Senior Member
    4,067
    690
    Eastern Oregon
    Thank you Envy that is good information to have. Maybe this needs a "sticky"?
  3. ralphh
    ralphh New Member
    100
    I have to try that on the Sienna, we park it outside and I get that "wet" smell in the morning.
  4. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    Please submit this as an article in the FEATURES section. There are instructions there on how to do that.
    Well done, only addition might be a wider shot of the driver's side area so we can see where you are on the close-ups.
  5. richard schumacher
    7,664
    1,042
    United States
    Very nice! Thanks.
    One diagnostic question to help avoid unnecessary work: Was standing water visible from outside, before you started disassembling anything?
  6. Sufferin' Prius Envy
    3,998
    <div class='quotetop'>QUOTE(richard schumacher @ Aug 3 2006, 07:48 AM) [snapback]296942[/snapback]</div>
    You're welcome.
    From the outside, water or sludge is not viewable, but a strong fingernail is capable of pulling off the cover on the passenger's side (second picture down), then it is very easy to see either bio sludge or the drain hole. If/when it is clear, run the garden hose in there and see if it flows out from behind the passenger side front tire . . . it really pours out as depicted in the bottom picture.
    Once that is done you can move over to the driver side and run the water on the windshield so it floods down into the driver's side of the drain system. If the water doesn't flow out equally hard from behind the driver side front wheel, then I would say you have a clog and should go through the steps I outlined.
    If I weren't taking pictures, the whole process would have taken about 15 minutes total. It's very easy to do.
    P.S. My fresh air intake no longer smells musty, and I no longer hear water sloshing. I washed the car the evening after I cleaned the drain clogs.
  7. DaveG
    DaveG Member
    806
    Vancouver, BC
    <div class='quotetop'>QUOTE(Sufferin' Prius Envy @ Aug 3 2006, 02:54 PM) [snapback]297315[/snapback]</div>
    Good tip - I checked mine on both sides and it was clean, however I still get the occasional musty smell, particularly after heavy rain or washing (although I suppose that makes sense).
    I also ran a mild bleach solution through the drains to kill-off any nasties that might be lurking down there. I suppose there's also a possibility that the air conditioner coils inside the heater element may need cleaning as well, but as I recall, those can be tough to get to.
    Dave
  8. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    I dealt with this a while back after the inordinately wet spring in
    New England: http://priuschat.com/index.php?showtopic=20878
    but didn't get into nearly as much detail on how to fix it!
    Taking the whole wiper cowling off isn't hard, and allows access to
    all the goodies behind the engine [and the hole where a block heater
    can go in...] but just for this problem, I'm wondering if there
    might be a better method since it seems to happen fairly often.
    Such as drilling a very small hole in the front of the gutter on the
    driver's side, and having a tool that can reach in through there and
    poke the guk out of the drain holes ... just at the very least to let
    the standing water out, not necessarily clean everything. Really,
    I don't want a full remval and cleanout to become a *yearly* ritual,
    but given where I park it might have to.
    _H*
  9. Lola&#39;05
    Lola&#39;05 New Member
    147
    Southeastern PA
    <div class='quotetop'>QUOTE(Sufferin' Prius Envy @ Aug 2 2006, 03:24 PM) [snapback]296476[/snapback]</div>
    Now you just know I am not going to do this. Baby will continue to sloosh.
  10. Sufferin' Prius Envy
    3,998
    <div class='quotetop'>QUOTE(Lola'05 @ Aug 3 2006, 05:34 PM) [snapback]297385[/snapback]</div>
    Sloosh . . . Is that how it is pronounced in Pennsylvania? ;) :lol:
    Someone here on PriusChat mentioned that they were not going to have the work done for the steering recall because they didn't see the need, and were willing to accept the risks. :huh:
    It's not so much the sound of the sloosh, or the smell which bothered me, but more what the slooshing and smells can lead to. The water has to go somewhere. I'd rather have clear drain holes and not have the water spill over into who knows where. The smell was kink of icky . . . but my worry about the smell aspects were geared more toward the possible health consequences.
    If you wish to take on those risks, who are we to tell you how to live your life. :mellow:
    P.S. [friendly advice] When you are adding a comment to the batch of posts, and not responding to any one thing in particular, you can click on the “Add Reply†button at the bottom of all the posts and prevent duplication of prior posts.
    If you do wish to respond to a particular item, click on the “Reply†button at the bottom of that particular post. At that point, for clarity sake, you can also remove parts of the post not relevant to your comments.
    With the post you did, I feel sorry for the PriusChatters who are on a dial-up internet connection and had to wait twice as long for the pictures to download.
    If you care to, you can go back to your post and “Edit†out the quoted pictures, etc.
  11. DaveG
    DaveG Member
    806
    Vancouver, BC
    <div class='quotetop'>QUOTE(Sufferin' Prius Envy @ Aug 3 2006, 11:54 PM) [snapback]297540[/snapback]</div>
    A bit off-topic, but you need not worry - as long as you have caching turned-on in your web browser (and they almost always are), it will only load an image from a given URL once - if it's re-used in the page elsewhere (or even on multiple pages), it's just redisplayed from the cache data and not re-downloaded as long as it's still available.
    But you're right about trimming-down replies :p
    Dave
  12. omahajim
    omahajim New Member
    <div class='quotetop'>QUOTE(Sufferin' Prius Envy @ Aug 4 2006, 01:54 AM) [snapback]297540[/snapback]</div>
    The other poster is correct, when the images cache, they could be displayed 100 times on the same page and it won't hit your internet connection.
    Plus, anyone on dialup that concerned about bandwidth would be viewing the lo-fi version of the pages anyways (sans pictures). ;)
  13. hobbit
    4,089
    468
    Bahstahn
    Still, it's simply poor practice to re-quote the ENTIRETY of a
    previous message, INCLUDING all its graphics. Buy a clue.
    _H*
  14. Tideland Prius
    16,402
    Just checked it. Mine's empty and rather clean. I'm at 32,000kms
  15. Betelgeuse
    Betelgeuse Active Member
    1,460
    24
    New York, NY, USA
    <div class='quotetop'>QUOTE(hobbit @ Aug 8 2006, 12:18 AM) [snapback]299470[/snapback]</div>
    Ah yes. Why say it nicely (like Sufferin' and DaveG) when you could be obnoxious? Well done. <_<
  16. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Patrick
    Disgusting what you found in there. I'll have to check my Prius when I get it back from the shop. Since I always park in the climate-controlled underground parking at my condo, it should be fairly clean.
    BTW: even nastier things can grow, breed like crazy, and poop in your central A/C evaporator. It's also a good idea to check your home A/C evaporator once a year or so.
    Indoor Air Quality is a serious conern for many folks. To kill the things that grow in air ducting or evaporators, you can use laundry bleach but that leaves a nasty smell behind. You can get little tablets from Nu Calgon that protect for long periods of time
    http://www.nucalgon.com/nucalgon/nucalgon_...F1?OpenDocument
    j
  17. Sufferin' Prius Envy
    3,998
    <div class='quotetop'>QUOTE(jayman @ Aug 8 2006, 10:50 AM) [snapback]299686[/snapback]</div>
    I think, as this thread matures, and we see more people checking their cars, we will find that people who park outside and under messy trees will be the ones who suffer most from sloshing water syndrome.
    I think I park in a worse case scenario. No garage, and I park under several Sumac trees.
    http://en.wikipedia.org/wiki/Rhus
    These trees have to be the messiest trees in the world!!! They are evergreen, which really means “ever-messy.†Depending on the season, they constantly drop copious amounts of various combinations of leaves, small flowers, seeds, pollen, fruit, bark, or twigs. Some mornings there is a half inch or more of fallout trapped on the windshield above wiper blade.
    I'm wondering if this mess is making its way into the gutter system via the holes for the windshield wiper arms. (see fourth picture from top)
    And the worst season of all?
    S***y Little Bird season!!!
    - when hoards of little birds eat the massive amounts of fruit, then perch in the trees and defecate all over the neighborhood. :eek:
    I really don't want to go the car cover route.
  18. jayman
    13,439
    641
    Winnipeg Manitoba
    <div class='quotetop'>QUOTE(Sufferin' Prius Envy @ Aug 8 2006, 02:33 PM) [snapback]299742[/snapback]</div>
    Patrick
    I really do like nature and trees and cute little chirpy birds ... just not in my backyard. That's why I chose to live in an ugly concrete highrise condo, and at my hobby farm the trees are a good 500m back from the house and shop.
    My plump cat makes quick work of the poopy little birds too
    j
  19. Salsa Red 2004
    Salsa Red 2004 New Member
    None of the pictures in this posting seem to work. Im guessing they were lost in the server crash. Does anybody have them saved to their hard drive? I was hoping to check out the drains on my car this weekend....
    Thanks
  20. jayman
    13,439
    641
    Winnipeg Manitoba
    In September I did take the cowl off at the hobby farm to check if my Prius was gunked up. Clean as a whistle. It really helps to have heated underground parking at my condo, no leaves or seeds or annoying poopy little birds.
    Sorry I never thought of saving any of Patrick's photos. They were pretty disgusting though. There was this slime like muck clogging his drains. Sure hope he washed his hands after cleaning it out ...
