how to remove road tar
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Much More Better, Mar 27, 2010.
  1. Much More Better
    Much More Better Active Member
    655
    163
    This is the curse of rolling in Blizzard Pearl. I have about 23,000 little black specks and I want to know what the best way to remove them. The larger specks like this . can be picked off with my fingernail but it is time consuming. I also don't want to do too much elbow grease for fear of introducing swirl marks.
    Any mild solvent? Clay bar helpful? Never used a clay bar before.
  2. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    Clay bar works great for road tar. If it's really bad, try RainX bug & tar remover.
  3. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    691
    151
    Seattle, WA
    Try paint thinner on a paper towel. If that doen't work, try lacquer thinner, a more agressive solvent that won't hurt auto paint but will strip wax.
    Once the tar is off, wash and wax the car to make road tar easier to get off.
  4. ALS
    ALS Active Member
    590
    294
    Pittsburgh
    Go to your local parts store or Walmart and buy the correct product for the job. I used a product called Trax that I got at Advance Auto. (Stream) recommended RainX bug & tar remover which is an excellent product.
    Use the correct product made specifically for the job of removing tar.
    The last thing you want to do is use something that could ruin your finish or soften up the paint. Blizzard Pearl is very expensive to repair for the reason it is a three step paint.
    I have a post below (I feel like the Karate Kid) on my enjoyment of cleaning the tar off my Blizzard Pearl.
  5. vinnie97
    vinnie97 Whatever Works
    1,430
    277
    Somewhere out there
    peanut butter on the cheap. :D
  6. lunabelgium
    lunabelgium Member
    269
    Belgium (Liège)
  7. Bob64
    1,540
    93
    Virginia
    claybars don't remove tar very easily - it sorta smears it around.
  8. Dark_matter_doesn't
    691
    151
    Seattle, WA
    Forgot to mention - if you have the clear bra film, be VERY careful when cleaning the tar off those surfaces. Very easy to damage & replacement is the most likely fix.
  9. toyolover
    toyolover Member
    441
    67
    toronto, canada
    I always use a bottle of Bug and Tar Remover. Be generous when using it. Soap the spots for a minute or two. Then use a soft cloth to rub it off in circular motion. You may need to apply a few more time to get it shine like new. I also use the electric buffer to take buff off the tar. It saves a lot of work and time. Works wonder for me every year. (I won't risk it by using paint thinner.)
  10. Much More Better
    655
    163
    Thanks for everybody's responses. I decided against harsh solvents for fear of what to might do to the clear coat. These spots are not stubborn, just tiny flecks of tar, rust, or whatever.....You can feel it when you run you hand over the paint.
    After a thorough hand washing, I decided to try some Mother's clay. Overall I'm fairly satisfied. Our Prius's tinny doors actually served a purpose! When the clay goes over an untreated area, you can hear the clay pulling surface contams off. After a few strokes, the sound stops. The more stubborn flecks still needs more rubbing or the occasional fingernail. After I was done, I ran my hand over the body and was happy. Finally, I sealed the car with Meguiar's Ultimate Quick Detailer. It's supposed to bead water which my car does not do. I'm hoping this spray wax will make future washings easier.
    I know this isn't the full pre-wax/polish/carnauba wax job but I don't think my car needs to have the prep stages right now. It is almost swirl/spiderweb free and after the detailers, it does look wet in the light. I'm just interested in prolonging the oem shine.
  11. PriusCrazy
    PriusCrazy Blizzard Pearl for Me
    213
    28
    Triad, NC
    MMB,
    If you like the Meguiar's product line (good stuff, btw), you might want to use the Ultimate Quick Wax instead of the Ultimate Quick Detailer for your "after wash sealer". It will do a better job of sealing your oem finish.
    Meguiar's has a great "car crazy" forum that explains the particulars in "much more better" detail. :)
    Check it out at:
    Car Care Forums: Meguiar's Online
    2 people like this.
  12. Joe166
    Joe166 New Member
    720
    97
    South Florida
    There are a lot of really fine products for protecting your car's finish. A detailer is not one of them. The purpose of a detailer is to clean the surface of water spots or very mild dust (although you are risking scratches or swirls).
    In my opinion (and yes, I know everyone has one), you should use a bug and tar remover. There are several good ones. Stoner has a particularly good one, but I think mineral spirits would work just fine. I would never use clay to remove tar, it would contaminate the clay so quickly you would probably have to discard it after each use, and most clay will work for several uses. After you have removed the tar with the remover, wash it thoroughly and use a polymer. It is almost as easy to use as the detailer and lasts a really long time. Beads beautifully too.
    Meguiars has several really nice "waxes" that are polymers. I prefer the NXT product, but there are several others that work nicely too. I think the Zaino products probably bead longer than any others, but only marginally and I can't ever plan ahead enough to mail order them. Just don't go for the store brands, the difference is minimal in price but not in results. Turtle Wax has a couple of nice products like "Ice" but I find it more trouble to remove than NXT. Mothers has a couple of nice products too. For tar you might want to use Meguiars Cleaner Wax. It is nice and long lasting too.
    It depends on what you want and sometimes on the color of your car. Some "waxes" look better on dark colors, some on light.
  13. Tideland Prius
    16,559
    peanut butter. No seriously. Peanut butter (I learned this tip from another PCer a few years ago). Of course, smooth is better.
  14. KenzoTH
    KenzoTH Member
    70
    38
    Rhode Island
    I also have the blizzard pearl. I just did the first of two sealer/polish applications-- "Nu Finish" ( directions say 30 days apart). I like this finish because it is easy to apply and wipe off. It contains no waxes, but cleans and seals the clearcoat. It says the clearcoat is not adversely affected- in other words it uses not abrasives but chemicals to clean and seal. It leaves a great shine and bead.
    It also made small tar bead removal easy! Orange bottle- Target.
  15. darelldd
    6,059
    389
    Northern CA
    Stop the madness.
    Yes, "tar remover" will work. Several other products will work (like peanut butter).
    Want to know the easiest, cheapest and safest?
    WD-40.
    Easy to find, cheap to buy. Will NOT harm anything on the car. Works as well if not better than "tar remover" and certainly better than anything else on the market.
    And if you want to go a bit further in the cheap department, just buy what WD-40 mostly is, and use that: kerosene. Super cheap in a 1 gallon container. And if you use it from the bottle, you also don't add propellants to the atmosphere.
    Again, will NOT harm the paint or anything else on the car. Makes cleaning up any gooey tar mess a snap.
    Follow by washing the car so there are no oily spots, and you're good to go.
    Personally, I'd stay away from the clay - I only use that on an otherwise CLEAN car.
  16. Joe166
    Joe166 New Member
    720
    97
    South Florida
    I have used NuFinish and I still have some of it somewhere in my garage. You are right, it does not use abrasives but it uses a very strong chemical and is not highly regarded in most of the detailing forums. If it continually removes part of the finish to make it shiny, it makes sense that it will eventually remove lots of the finish.
    If you like it and have good luck with it, great, but take some time and read some of the comments on various detailing forums. Some of those people are really talented and very experienced.
  17. vinnie97
    1,430
    277
    Somewhere out there
    As I myself and several others have recommended, peanut butter will do it but still requires some elbow grease (i.e. a fair bit of rubbing), so be prepared. The smooth hydrogenated stuff does the trick (makes you have a second thought about eating it ;)). For fear of scratching, I'd not use the crunchynutty stuff.
  18. PriusCrazy
    213
    28
    Triad, NC
    This got me to thinking about a good website for checking the chemical makeup of products... Check it out at:
    Consumer Product Information Database
    I was a bit surprised to find that WD40 does indeed contain kerosene.
  19. cossie1600
    cossie1600 Active Member
    903
    94
    CT
    Rain X works
  20. tonyl
    tonyl Junior Member
    27
    Avon skin so soft works great, wash with shop and water after using skin so soft.
    tl
