Does anyone know how to replace Canister Pump for 2007 Prius? I am not sure it needs to drop the fuel tank down or move the rear seat!! Please help.
There is a charcoal canister assembly , looks like you would have to drop the fuel tank to change it. http://www.autoshop101.com/forms/Hybrid13.pdf google docs has a fuel tank removal and installation document http://docs.google.com/viewer?a=v&q=cache:NZa5fW65NtEJ:share.qclt.com/%25E4%25B8%25B0%25E7%2594%25B0%25E6%2599%25AE%25E7%2591%259E%25E6%2596%25AF%25E5%258E%259F%25E5%258E%2582%25E8%258B%25B1%25E6%2596%2587%25E6%2589%258B%25E5%2586%258CPDF%25E6%25A0%25BC%25E5%25BC%258F/Repair%2520Manual/04pruisr/11/20zydc1u/w140001.pdf+prius,fuel+tank+disassembly&hl=en&gl=us&pid=bl&srcid=ADGEESgBCPq1ZzUZ1XN4FloxvKTm-BMY5ojlkehVQhnORK2ahTUrgvJzRIXN4Slh3PmVJLvi1f2J4tQ90BeLz7iTt8nRnxAtprxNZKtD0BM2lB-9up2RvoJs8xDVHBvnxeQZstqMqWJU&sig=AHIEtbRdz0EbYloo5-PQ4Xu4XAPSw5QYsw Care to give more info on what you are dealing with, problems, codes, etc.? Just read your note under 2007 Prius ; EC: P2401 replace Cannister Pump at 68K
ggcc, I too am a little uncertain as to the exact part you are asking about. The same cite given by northwichita says this about the fuel pump on pg.3-2: "The fuel pump module assembly is integral with the fuel tank and is not serviced separately." I think we're talking ~$700 if the fuel pump is acting up. You have to replace the tank, bladder, pump and other internal stuff. There are very few threads on fuel pump failures. That said here is a short one that may be helpful: http://priuschat.com/forums/generat...ump-replacement-caused-12v-battery-dying.html
Thank you very much for the information and the documents. Yes, look like I have to drop the fuel tank in order to replace the canister assembly (pump).
