How to replace the fog lamps?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by TucsonPrius, Mar 9, 2004.
  1. TucsonPrius
    TucsonPrius Member
    167
    16
    Tucson, AZ
    2020 Prius
    While reading the 2004 prius manual, I noticed that it recommends that one bring the car to a dealer to replace the fog lamps, otherwise damage to the bumper may result.
    Has anyone found out what fog light replacement entails?
    Thanks.
  2. kenmce
    kenmce High Voltage Member
    1,543
    514
    NY
    Call me old fashioned, but I liked it back when you could expect a bumper to be stronger than a fog light. I also liked it when you could change a light bulb without making a dealer service visit out of it...
  3. siai
    siai Junior Member
    50
    Florida Keys
    I would take it to the dealer to replace---if the bulb is bad, it should be under warranty. Otherwise the maintenance manual states that the LH and RH front fender liners, the front bumper cover and the radiator grille lower LH or RH side needs to be removed. The lamp assembly is held into the lower grille by three plastic "claws" that need to be disengaged prior to pushing the lamp assembly out. Then you can change the bulb and reassemble the unit. The possible damage come into play when removing the bumper cover. The manual states that you must put protective tape under the front fenders and tape the end of the screwdriver used to disengage the 8 clips that hold the cover on. Sure wish Toyota had made access to the "claws" through the front of the grille which would have alleviated this problem. :(
  4. Lectricar
    Lectricar New Member
    98
    Glenmoore, Pennsylvania
    On an old volvo 960 my foggies were integrated in the front grille brightwork. They were next to the headlights and provided a fill of light that extended side to side such that the road's edges were fully illuminated. In addition a rear foggie was included (most valuable as it warned folks behind that there was a large green swedish brick in front of them to watch out for)
    With the Prius HID lights I have found the foggies to be next to useless. I've only noticed a very small amount of additional light and none illuminating the road edge. I always thought that fog lights help you to see the road edges so you don't go off the road in a pea-souper .... am I missing something.....?
  5. windsurfdog
    windsurfdog New Member
    67
    Northern Gulf Coast of Florida
    Ditto to Lectricar--And I would love to use the fog lights exclusively--possibly as a DRL alternative--but they are "intertwined" with the HID's--YUCK! Maybe the good folks at CoastalEtech can come up with a solution.
  6. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    I'd love a DRL mod that utilized my fogs. I hardly ever use them for driving, so this would be a good alternative.
    Having fogs for DRL's would be just enough to be visible, but not so bright that it's obnoxious :)
  7. randalla
    randalla Member
    370
    Lexington, SC
    Hello Dave at Coastal...any chance for a fog light to DRL modification sometime soon?
