How to Safety Retorque Nuts on Battery Terminal?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Taz43, Sep 1, 2022.
  1. Taz43
    Taz43 Junior Member
    47
    Los angeles
    Hi All,
    If i need just retorque my nuts on all positive and negative modules. If i leave the battery in the car connected but remove the orange safety,
    Is that good enough to be safe? Or do i need to disconnect it from the car too?
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,135
    Tampa, FL
    If you're putting your hands and tools on the battery module terminals, disconnecting it from the car with the safety plug is only going to make sure the negative side of the battery is not connected to the car's frame. You'll still need to use lots of caution to avoid touching more than one terminal at a time. Once they are all connected by the bus bars, there's over 200V difference from end to end.
    Others with experience in rebuilding batteries will hopefully be along soon with more detail.
