How to tell if Engine Block Heater is working?
Discussion in 'Gen 2 Prius Main Forum' started by cabral255, Nov 7, 2011.
  1. cabral255
    cabral255 Junior Member
    2002 Prius
    How can you tell if the EBH is working? I thing there is a little bit more heat coming from the vents, but its hard to tell. I am thinking of putting the car on ramps and touching the block next to where the EBH is. The gas engine doesn't seem to be shutting off any faster. Thanks, Jay
  2. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    The engine block heater only works when you are parked, then you plug it into the AC, it warms the block so it won't freeze up. When you start the car, you unplug the heater. You might want to investigate the merits of Grill Blocking!
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    When you plug it in it draws power. If it is drawing power, it is generating heat.
    Tom
  4. cabral255
    2002 Prius
    Thank you for telling me how it works, but seeing how I installed it I know how it works. I just am looking for any ez way to test that its working properly
  5. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    After a few hours of plugging in the engine compartment should be nice and toasty. +1 on grill block.
  6. cabral255
    2002 Prius
    My grill has been blocked for a few yrs
  7. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    I used an ohm-meter to check for continuity. You can also use a "Kill-A-Watt" meter. I used both. Or other more sophisticated devices. Or you could just put you hand down there, but be careful, I suspect it could be hot enough to cause a burn. It's a 400 Watt device as I recall.
    You don't list where you are from, but around here it hasn't much effect. At -18C (0F) it's not powerful enough.
  8. fuzzy1
    10,451
    Both a Kill-A-Watt meter (or similar) at the AC plug to see how much it is consuming, and a ScanGauge in the car to measure the engine coolant temperature at startup, should tell you whether the EBH is working.
  9. qbee42
    18,058
    3,079
    Northern Michigan
    As I pointed out in the post before this one, check and see if it is drawing power. The amount of power should be roughly equal to the wattage of the heater.
    Tom
  10. cabral255
    2002 Prius
    I am not interested in buying any type of meter. I want free and ez
  11. Mendel Leisk
    41,451
    Plug it in for say a couple of hours. Feel the extension cord plug itself: it will likely be a bit warm by that time. Then pop the hood, and feel a few coolant hoses: they should also be warm, some more than others. Also see if you can feel the engine block itself, particularly near were coolant hoses are entering/exitting: again you should feel some warmth.
  12. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    I feel your pain. I really do.
    Last winter (or the one before) my EBH stopped working but I didn't know. I wanted a quick, easy and preferably free way to know for sure. Like you, I didn't want to buy anything and like you I am still frustrated that the standard Prius dash doesn't show engine temp.
    The only way I could find to check that was easy and free was to borrow someone else's meter and check it. Seriously.
    The reason you are getting the responses you are is that there is no easy and free way.
    Sorry.
  13. qbee42
    18,058
    3,079
    Northern Michigan
    If you have a non-contact infrared thermometer you can use that to shoot some temperature measurements of the block and other parts of the engine compartment. The engine block should be appreciably warmer if the EBH is working.
    Tom
  14. KK6PD
    4,003
    946
    118
  15. nerfer
    nerfer A young senior member
    2,507
    237
    28
    Chicagoland, IL, USA, Earth
    I found that the ScanGauge improves my mileage at least as much as the EBH does. I can't imagine trying to hypermile without it, now that I'm used to it.
    But for free (not sure about the easy): Plug it on a good cold day, drive it to the end of the block and then see how long it takes before the engine turns off (listen for it, don't go by the arrows on the MFD). On a similarly cold day, don't plug it in, and see if there's a difference in how long it takes. (For the Gen II, the engine won't turn off at a stop until it reaches 100'F, and won't turn off when coasting between 35 and 41 mph until it reaches 157'F).
    You might want to do this a couple times, as minor things can make differences (including how long it was sitting), and it's more noticeable if you do it when it's in the single digits Fahrenheit. Temps in the 40's won't show much difference without a scangauge.
  16. wjtracy
    wjtracy Senior Member
    11,368
    3,608
    Northern VA (NoVA)
    ...how about the ambient temp read-out on the MFD?
    Not sure where that reading is coming from.
  17. fuzzy1
    10,451
    Can you borrow a Kill-A-Watt meter from a public library or from your electric utility? Seattle's libraries lend them, as do many others now.
    Or, watch the speed of the spinning disk on your electric meter as you connect and disconnect the EBH. It should spin faster with a working EBH, though you may have to try the test multiple times to separate this from other loads that could switch on or off during your test, such as a the refrigerator, water heater, range coils, etc.
    If you had a Gen3, I'd suggest trying to enter EV immediately after startup. It should usually succeed with a working EBH, fail without. But that won't work with stock older models, and maybe not even with the user-installed EV switch.
  18. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    I second KK6PD's comment that a Kill A Watt is a great investment. I bought mine a few years ago and it's one of the best cheap gadgets I've bought in a long time.
    It helped me identify some power hogs at home and also gave me a better idea of how much power everything around me was consuming.
  19. stealth_mode
    stealth_mode New Member
    Switzerland
    Hi J,
    It definitely has an effect on reaching S4 faster and thus shutting off the ICE! you have to give it time to warm up the massive aluminum - motor block cylinders and oil (you can to the math@400W). these days it is 10°c in the morning according to SG, if I preheat for 1 h the block is about 25°c which s comparable with a cold start in august during the day.U can fell that by touching some metal part of the block especially on the EBH-side of the block.
    Also consider to use the ECTH-spoofer- it really works great (spec. with PHEV-conversion)and is fully automatic!
    Regards T
