How to turn wifi on and off so I can connect to my dashcam app
Discussion in 'Gen 5 Prius Audio, Electronics and Infotainment' started by Jon Watkins, Sep 30, 2024.
  1. Jon Watkins
    Jon Watkins Active Member
    131
    114
    Bluffton SC
    2024 Prius
    24 LE. Just got my dashcam installed today. I need to connect the dashcam to its app to change several settings. The car wifi takes over the wifi connection on my iphone 13 and I can’t connect the dashcam to the phone app. It keeps kicking me off for the cars wifi.
    How do I turn off the car wifi so I can connect my dashcam to the app?
  2. BiomedO1
    BiomedO1 Senior Member
    2,568
    1,380
    SacTown, Ca
    I don't know about your 2024, but cars usually connect trough Bluetooth. Kill the Bluetooth connection either on your phone or through the gear icon on the car. That should release controls.
  3. Jon Watkins
    131
    114
    Bluffton SC
    2024 Prius
    Ended up having to turn the car off so its wifi disconnected from my iphone. Then I was able to turn the car back on and quickly connect the wifi on my phone to the dashcam before the car wifi was able to connect. Made the updates to the dashcam app and disconnected the wifi. Restarted the car and it connected its wifi to my phone automatically. Kinda kludgy way to have to do it but I’ll know for the next time.
  4. purplePriii
    purplePriii Active Member
    270
    118
    You could most likely also turn off the multimedia display and I don't think it'll connect to wifi. I believe it's the one controlling the loading for profiles, android auto/carplay, etc
  5. Jon Watkins
    131
    114
    Bluffton SC
    2024 Prius
    Do you know how to turn off the multimedia display?
  6. purplePriii
    270
    118
    Just hold down the volume button next to it for 5 seconds or until it shuts off.
  7. Jon Watkins
    131
    114
    Bluffton SC
    2024 Prius
    Unfortunately that doesn’t disconnect the wifi.
  8. Hammersmith
    Hammersmith Senior Member
    1,874
    1,870
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I'm confused. A Prius doesn't use wifi to connect with a phone unless a person pays for the AT&T hotspot plan. The Prius uses bluetooth for Digital Key, Android Auto, and Apple CarPlay connections.
  9. Jon Watkins
    131
    114
    Bluffton SC
    2024 Prius
    New purchase so I’ve got the temporary att hotspot that comes with all new cars.
  10. Hammersmith
    1,874
    1,870
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Okay, then did you try:
    >Settings (the gear icon)
    >Wi-Fi
    >Hotspot
    >Toggle the hotspot slider off
  11. Sarge
    Sarge Senior Member
    1,321
    775
    Milton, Ontario, Canada
    2023 Prius Prime
    XSE Premium
    Wireless CarPlay uses local Wifi, not Bluetooth. I believe the reason is that Bluetooth does not support a fast enough data connection to support CarPlay, which is why the phone nor the car can connect to a wifi signal when wireless CarPlay is connected. I don’t have an Android so I am not sure if AA is the same, but I assume it would be.
  12. AndersOne
    AndersOne Active Member
    334
    193
    Europe
    2023 Prius Prime
    The inital handshake is done via bluetooth - after that it switches to wifi. So if bluetooth is off, carplay will not take over the wifi.
  13. Zeromus
    Zeromus Active Member
    468
    240
    Ottawa Canada
    2024 Prius Prime
    SE
    wireless carplay / android auto is initiated by a bluetooth connection, but then the car communicates using a dedicated private local wifi connection after that :)
  14. BiomedO1
    2,568
    1,380
    SacTown, Ca
    He should be able to choose which WiFi to connect to on his phone; but once the car grabs the phones Bluetooth connection - it takes primary control over the phone. That's how your car's touch screen activates your phone apps. To stop that from happening, kill the sequence either at the phone or car. Easy Peasy.....
    You gotta know how things work, in order to fix it....:p
